notaxonrotax
777 empennage question. What is it, please?
Fri Jan 26, 2018 5:12 pm
Hi,
I feel silly for asking this question, but what is this "thing" sticking out of this 777 tail?
Parked rather close to me at Libreville, I couldn`t help noticing this little detail for the very first time.
No Tax On Rotax
For anybody that happens to be wondering:"yes, owning your own aircraft is a 100% worth it!"
113312
Re: 777 empennage question. What is it, please?
Fri Jan 26, 2018 5:19 pm
APU air intake scoop
Flow2706
Fri Jan 26, 2018 5:24 pm
Not rated on 777, but I think this is the APU Flap (where the APU gets the air from)
mmo
Fri Jan 26, 2018 5:29 pm
Correct. It is the air inlet for the APU.
LU9092
Fri Jan 26, 2018 6:15 pm
Are there situations where the 777 flies with APU running? If so, is there any range penalty for extra drag from that intake, or is it negligible?
77west
Fri Jan 26, 2018 7:33 pm
Yes, if one of the electrical generators and/or hydraulic pumps is INOP I believe they need to fly with the APU running. I think the fuel it uses would have more impact on range than the inlet flap itself
77West - AW109S - BE90 - JS31 - B1900 - Q300 - ATR72 - DC9-30 - MD80 - B733 - A320 - B738 - A300-B4 - B773 - B77W
PhilBy
Fri Jan 26, 2018 8:17 pm
I expect that the drag on the intake is slightly reduced if the APU is running!
LU9092
Fri Jan 26, 2018 8:24 pm
I don't think it's open when the APU isn't running.
BravoOne
Fri Jan 26, 2018 9:11 pm
In flight you can feel a slight rumble when this door is open.
LH707330
Sat Jan 27, 2018 12:46 am
I'd assume that the door doesn't open all the way when in flight, otherwise the ram pressure would be pretty high.
Redbellyguppy
Sat Jan 27, 2018 1:46 am
The 737 max has a similar door as opposed to the previous vent style on the NG and classic. It does not have a speed limit even if it is inop and deferred open, however, there is a 1% burn penalty and a few hundred pounds performance penalty.
BravoOne
Sat Jan 27, 2018 2:56 pm
[threeid][/threeid]
I'm pretty sure if goes full open. I get what your saying, so I assume they modulate the ram effect.
notaxonrotax
Sat Jan 27, 2018 10:47 pm
Thanks, folks!
Is it that visible on other airliners?
No Tax On Rotax
Florianopolis
Sun Jan 28, 2018 6:46 pm
747, 757, 767, CRJ, etc
DL_Mech
Sun Jan 28, 2018 10:14 pm
But not on the DC-9, MD-80/90. Unless you are underneath the airstair.
This plane is built to withstand anything... except a bad pilot.
Former AMT on A220,A310,A319/20/21,A330,A350,B707,B717,B727,B737,B747,B757,B767,B777,DC-9,DC-10,L-1011,
MD-80/90,MD-11
7673mech
Mon Jan 29, 2018 3:14 am
On the majority of flights, when APU is not needed it is fully closed in flight.
It is only open when APU is needed in flight and running. Full open. It does not modulate.
BravoOne
Mon Jan 29, 2018 1:14 pm
ETOPS operators are required to make a cold soak start every so many flights/hours/cycles. Usually done near the end of the homeward bound flight after being aloft for at least six+ hours, or at the specific request of Maintenance. The results are recorded in the log book. Usually the starts are limited to 3 attempts.
Specific operators may have different procedures or requirements and results may vary.
The fuel penalty for an APU door stuck open is rather large at 2.5% for the 777.
LU9092
Mon Jan 29, 2018 3:27 pm
Wow, that's pretty significant! Thanks for the info.
