Ruddman
TWA / Pan Am 747-100 engines?
Mon Jan 29, 2018 8:10 pm
HI, I was wondering what engines were used in the 741 fleet by these two airlines? Did any use the JT9D-3/A engines? I've read somewhere that many of the 741's with -3 engines were replaced with the -7's. Was this the -7's or -7A's?
Any help greatly appreciated!
mmo
Re: TWA / Pan Am 747-100 engines?
Tue Jan 30, 2018 6:54 am
IIRC, both PA and TW upgraded the -3A to the -7A due to the increased reliability. I could be wrong, but I can't remember a -7 on any 747. I know NW upgraded their 100s from -3A to -7A also.
Apprentice
Tue Jan 30, 2018 8:29 am
Hi: And with this heavy nacelle, very difficult to close!
“An AME, with just a Mechanic Role”, as per one of our pilots
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
“CUBANA” 90 years Flying”
mmo
Tue Jan 30, 2018 9:10 am
Forgot about that.. That was done to fix the fan rubbing problem.....IIRC, the first commercial flight was delayed by 4 hours as the result of aircraft change due to fan rubbing on the original aircraft planned.
Max Q
Tue Jan 30, 2018 12:31 pm
How was this upgrade accomplished and did this particular change increase thrust st all ?
mmo
Tue Jan 30, 2018 3:16 pm
There was about a 2,000lb increase in thrust from the 3A to 7A. The fan section was redesigned to eliminate the bowing of the fan which was the problem with the initial 3A.
Ruddman
Tue Jan 30, 2018 6:17 pm
Ok thank you. I’m guessing the -3A wasnt used for any length of time.
And does anyone know what gross weights either used? I’m trying to find some information on them but it’s a little difficult. I guess both airlines having many airframes, they could’ve had several different GW aircraft in the fleet. I think the -100’s ranged from 730,000 to a max of 750,000lb?
mmo
Wed Jan 31, 2018 6:39 am
IIRC, and it's been a while, the 100s originally had a MTOW of 730 or 735,000. I know NW had their 100s up to 775,000 MTOW. I am pretty sure, the increase was just a paper mod introduced after the original 100s were delivered.
fr8mech
Wed Jan 31, 2018 1:43 pm
Back in the -90's, we took our -7A's to -7AH with a "simple" change of the fuel control. Not really sure what the difference between the 2 were.
When seconds count...the authorities are minutes away.
timz
Wed Jan 31, 2018 6:39 pm
Didn't the 747 enter service at 710000 lb?
strfyr51
Tue Jul 10, 2018 12:40 am
Pan Am, TWA, Northwest and United upgraded their JT9D-3A's to the later -7A's, The reliability reportedly Improved greatly.
TransAmerica's B747-200's came with the CF6-50 engine. The British B747-200's were equipped with the Roll RB-211-524's.
At one point or another we got to see all of their airplanes in our Dock 2 Hangar at United's MOC , And at American's "Superbay".
