nine4nine
Slot Controlled Airports
Tue Mar 13, 2018 5:12 pm
If flight from a slot controlled airport are impacted by a natural disturbance, how are flights worked out to accommodate passengers to get them to the destination?
Let’s say a Nor’easter impacts BOS and JFK and both airports are closed or or flights are cancelled by the airline, let’s say B6 for example out of LGB. Since the airline was unable to use the slots on a schedled day can those roll into the next operational day for the airline to have multiple flights out to accommodate stranded passengers on the affected/cancelled flights on the previous day(s)?
717 727 732 733 734 735 73G 738 739 742 748 752 753 762 763 772 773 DC9 MD80/88/90 DC10 319 320 321 332 333 CS100 CRJ200 Q400 E175 E190 ERJ145 EMB120
OH-LGA
Re: Slot Controlled Airports
Tue Mar 13, 2018 5:24 pm
Slots are for the assigned period for that day only - the sole intention of slots is to meter runway/airport capacity so it's not a massive traffic jam. Slots cannot roll over from day to day. Slots are simply unused if the flight is cancelled - most slot controlled airports have a small set of unallocated operations but approval from FAA must be granted before any additional operations are flown.
Head in the clouds... yet feet planted firmly on the ground.
MO11
Tue Mar 13, 2018 5:29 pm
The slots are for scheduling purposes. If a flight is running two hours late, it doen't need to get another slot.
A different example, if an ATC imposed arrival rate is less than the number of issued slots, you go when ATC tells you. You don't need to request another slot.
MIflyer12
Tue Mar 13, 2018 6:25 pm
It's another utility for travel waivers, where carriers waive change fees & difference in fare to rebook people into (later) available capacity.
Users browsing this forum: Lpbri, stratosphere and 6 guests
