Martinlest
B777 EICAS question
Thu Apr 05, 2018 2:23 pm
Wondering when you would see the air system info on the EICAS, (cabin alt, ldg alt, duct press etc.). Is the information visible even when cabin pressurisation is set to automatic? With the PMDG a/c I sometimes get a yellow LDG ALT warning on the instruments (not sure why - the flight plan loaded up OK). Trying to reset the landing altitude is impossible as I don't have the current setting showing on the EICAS.
How does this work in the 777 (real-world, or PMDG!)? If I should be seeing this information, how do I bring it up? Tried various EICAS/MFD combinations to no avail.
Thanks.
Lpbri
Re: B777 EICAS question
Thu Apr 05, 2018 2:43 pm
The synoptics page for AIR should have most of this info.
aeropix
Thu Apr 05, 2018 3:08 pm
Whenever the air synoptic is displayed on the lower DU, the cabin altitude “pop up” will display simultaneously. Under normal operations you would not manually change the landing altitude as it is correlated with the origin and destination airports in the FMC. The origin altitude will be used in the event of an air turn back early in the flight.
If you pull the LDG ALT selector you can manually change the landing altitude and the EICAS will then display the landing altitude followed by “MAN” as a reminder. This is useful in controlling the cabin pressure in case of a suspicious device found on board which may be triggered by cabin pressure changes, but I’ve never encountered any other SOP requiring its use.
Are you trying to use your flight simulator to do touch and goes at some airport which is neither the origin or destination in the flight plan? That may result in the EICAS advisory message you’ve described. Or maybe you’ve accidentally clicked on the selector with your mouse, thus activating it?
BoeingGuy
Thu Apr 05, 2018 3:19 pm
aeropix wrote:
Whenever the air synoptic is displayed on the lower DU, the cabin altitude “pop up” will display simultaneously. There is no way to manually change the landing altitude as it is correlated with the origin and destination airports in the FMC. The origin altitude will be used in the event of an air turn back early in the flight.
Yes you can. The 777, and all other Boeing models, has a Landing Altitude (LDG ALT) Selector on the overhead panel that lets you manually select a landing altitude for pressurization.
aeropix
Thu Apr 05, 2018 3:22 pm
Unfortunately my incomplete submission was picked up by the system before I had finished writing it. You are correct BoeingGuy.
Also to add to my original post there is a supplementary procedure requiring the LDG ALT if the departure / destination is not in the NAV database but as I’ve never had to operate to such an airfield I have never had occasion to use that functionality.
Martinlest
Sat Apr 14, 2018 3:45 pm
Thanks for the replies.. not sure how accurately the b777s I have reflect this. I don't seem to get the information up.
Users browsing this forum: SuperAzusa and 5 guests
