wjcandee
Why Do Condor 767-300ERs Have The Small Cargo Door
Mon Apr 09, 2018 4:27 am
Something that came up in a thread in CivAv that surprised and mystified me. (Not that unusual.)
It appears that all 11 of the 767-300ERs that Condor received direct from Boeing have the 70" front right lower cargo door that was standard on the non-er 767-300 and 767-200, rather than the 134" door that is standard on the 767-300ER (and optional on the non-ER version).
Presumably, this was at the airline's request, but that leads me to two questions, for which I have no answer after an extensive search:
(1) WHY? This means that Condor intentionally ordered a non-standard asset that would necessarily have a reduced resale value down the line. It then acquired almost an equivalent number of standard 767-300ERs from other carriers, all of which have the standard door.
(2) Can anyone think of any other airline that ordered the -ER with the narrow cargo door? And, again, why?
Ultimately, this makes these aircraft non-desireable for cargo conversion, although that's hardly an issue that a purchaser would consider when ordering new-build frames.
ha763
Re: Why Do Condor 767-300ERs Have The Small Cargo Door
Mon Apr 09, 2018 5:12 am
Most likely answer is that Condor, being a leisure airline, weren't concerned about cargo and saved money by ordering it without the large cargo door.
LTU, formally a leisure airline, also ordered several 767-300ERs with the small forward cargo door.
stratclub
Mon Apr 09, 2018 8:09 am
The cargo on a cargo aircraft is for the most part is carried in LD's (cargo containers) on the main deck so really having a small door on the fwd baggage pit would be of no real hardship for an aircraft converted to cargo.
Max Q
Mon Apr 09, 2018 10:29 am
[quote="stratclub"]The cargo on a cargo aircraft is for the most part is carried in LD's (cargo containers) on the main deck so really having a small door on the fwd baggage pit would be of no real hardship for an aircraft converted to cargo.[/quote
And if the customer wanted a larger cargo
door it could be incorporated during the
conversion
wjcandee
Mon Apr 09, 2018 1:24 pm
One of the significant benefits of the 767-300ER freighter is the 4 88x125 containers that it can carry in the cargo hold due to the large cargo door, so your observation is a little off here.
wjcandee
Mon Apr 09, 2018 1:25 pm
conversion
That's an interesting observation. I would have thought that it would require an additional STC and significant additional engineering -- i.e. big investment -- not worth it for 15 or fewer potential conversion frames.
wjcandee
Mon Apr 09, 2018 1:32 pm
Thanks! Looks like the later-build LTU originals have the bigger door, and several of the original-LTU ones with the smaller cargo door have been broken up, rather than be converted.
I wonder whether one saves money by ordering something non-standard, and how much money one could possibly save with this modification. I wonder if it isn't some other reason, but it is interesting that both German charter airlines did this...
stratclub
Mon Apr 09, 2018 10:24 pm
conversion
I would agree, The added revenue would not justify the cost. However, the LCD is already approved in the original TC for the aircraft so converting would be a matter of shopping for the engineering data that's already written by Boeing and conforming the mod to the appropriate data. Not cheap either but certainly cheaper than a "from scratch" STC.
wjcandee
Tue Apr 10, 2018 12:40 am
Very interesting! Thank you. Still wondering if there's anything out there from the time that explains this somewhat-odd choice...
CCGPV
Tue Apr 10, 2018 12:57 am
Does anyone have access to the sort of "options list" airlines have when they buy planes like this? Are there different wiring types or options of better/cheaper materials used in specific areas of the plane for example?
Stay curious
stratclub
Tue Apr 10, 2018 2:30 am
It's very doubtful data like that is released to the public. For good reason an "option list" is held very close by a customer because other carriers could use that list in ways that could effect competitiveness.
stratclub
Tue Apr 10, 2018 2:53 am
If you got a hold of the cargo carriers Air Operators Certificate, you might find something that would explain how the carrier uses the lower cargo holds in their freight operation. I think AOC's are publicly accessible on the F.A.A's website. Otherwise, it would be just plain old ask the carrier.
airxliban
Wed Apr 11, 2018 6:56 pm
The difference between the 70" door and the 134" door is what exactly...the 70" door allows you to load your choice of LD2 / LD8 containers but the 134" also allows you to carry PAG style 88x125 pallets?
Users browsing this forum: marcelh, stratclub and 12 guests
