BWIAirport
A320 family aileron droop
Mon May 07, 2018 10:33 pm
Recently I have noticed A319, A320, and A321 aircraft's ailerons do not "droop" when parked at a gate or when the engines are shut off. Right now I'm at BWI and I can see an NK A320, A319, and WW A321. The A320 and A321 have sharklets and their ailerons are not drooping. The A319 has the old fences and they are drooping. Is that just a coincidence, or does either the wingtip device or aircraft model determine whether the ailerons droop?
SWA, UAL, DAL, AWE, ASA, TRS, DLH, CLH, AFR, BAW, EIN, AAL | E190 DC94 CRJ2 B712 B733 B737 B738 B739 B744 B752 B753 B762 B77W A319 A320 A20N A321 A333 A343 A388 MD88
AirKevin
Re: A320 family aileron droop
Mon May 07, 2018 10:37 pm
Pretty sure it's just a matter of whether the hydraulics are turned on or not.
Captain Kevin
Antarius
Mon May 07, 2018 10:38 pm
I doubt the sharklets matter. Especially given they are a bolt on option for existing aircraft.
The droop is due to the hydraulic pumps being off. Is it possible that on some (the non drooping) the engines or APU were on?
2020: SFO DFW IAH HOU CLT MEX BIS MIA GUA ORD DTW LGA BOS LHR DUB BFS BHD STN OAK PHL ISP JFK SJC DEN SJU LAS TXL GDL
sixtyseven
Mon May 07, 2018 10:43 pm
No hydraulics equals droop. After engine shut down it takes a bit for the hydraulic pressure to dissipate and the ailerons will sag. You see it on Big Boeings as well the inboard ailerons will sag after hydraulics are removed post engine shut down.
APU does not supply hydraulic power. Only electrical and pneumatic.
Stand-by for new ATIS message......
BWIAirport
Mon May 07, 2018 11:14 pm
Thank you for your answers
thepinkmachine
Mon May 07, 2018 11:19 pm
I have noticed older airframes droop the ailerons earlier - perhaps seals getting worn, or something
"Tell my wife I am trawling Atlantis - and I still have my hands on the wheel…"
nws2002
Mon May 07, 2018 11:26 pm
Dumb question maybe, but don't the cargo doors require hydraulic power? Or is that a completely separate system that uses an electric pump?
I've never had to ask for hydraulic power on the A320 series. We used to lower the aft stairs on the MD-80s though and then we'd frequently have to ask the flight deck for hydraulics to raise them again towards the end of the turn.
windy95
Mon May 07, 2018 11:30 pm
The ailerons are used for the Load Alleviation Function ( LAF) and when on the ground and not pressurized they may droop down to the servocontrol stop depending on wear.
windy95
Mon May 07, 2018 11:32 pm
Yes the Cargo doors operate on a closed system and only pressurize when actuated.
sixtyseven
Tue May 08, 2018 12:16 am
The cargo doors are powered by the yellow hydraulic system, and Is energized When the ground crew utilize the switch irrespective of whether the pump is powered by the flight deck controls. If the yellow system pump is inop the doors can be moved by a crank.
Tue May 08, 2018 1:11 am
Adding to the cargo door discussion, on the 330 they are also on the yellow system. With the engine driven pump off, the electric pump provides pressure when the cargo doors are operated. In order to isolate the cargo doors from the rest of the yellow system, thus ensuring the related flight controls are not powered, the yellow system leak measurement valve closes. If electric power is off, a hand crank can be used.
Users browsing this forum: Newark727 and 19 guests
