KitSmith wrote:One such thing is this. On page 274 she talks about how pilots were always so cheap and then says the following
"They were even cheap with the oxygen that we had to consume on the flights, especially on those trips to Tokyo over the North Pole were we flew so high up that it was always difficult to breath properly, and that was because they would switch off the air-packs which provided constant new air..."
Lpbri wrote:Problem is, when you shut down one pack, the remaining pack has to work harder. Nothing saved.
KitSmith wrote:I tried to get the complete book but, sadly enough, was unable to find it anywhere for a reasonable price.!
Woodreau wrote:KitSmith wrote:I tried to get the complete book but, sadly enough, was unable to find it anywhere for a reasonable price.!
Why don't you go to your local library and see if they can get a copy through the interlibrary loan for you to borrow?
GalaxyFlyer wrote:40+ years of professional flying and her comment is rubbish. You don’t normally fly with the packs off.
GF
747classic wrote:Lpbri wrote:Problem is, when you shut down one pack, the remaining pack has to work harder. Nothing saved.
On the 747 classic series three packs are normally installed (on some freighters only 2 packs for weight saving).
After the fuel price escalation in the late seventies one pack was switched off below a certain passenger load (company policy, stated in the aircraft operation manual.)
This adapted operating procedure is saving fuel, because the remaining two packs are not able to operated more than 100% open.
Later the pack valve control was changed from on/off to a three position switch : on, 1/2, off. In the 1/2 position the pack valve was partly opened, reducing the pack flow.
After this modification optimal adustment of the airconditioning flow was possible in line with the actual number of passengers on board.
BravoOne wrote:It was not uncommon in the 707 to turn the turbo compressors off and just run on bleed air. Can't recall if we left one TC running or not but bleeds produced better fuel specs.
N766UA wrote:I’ve never met a flight attendant, veteran or otherwise, who knew what they were talking about vis-a-vis aircraft systems.
stratosphere wrote:N766UA wrote:I’ve never met a flight attendant, veteran or otherwise, who knew what they were talking about vis-a-vis aircraft systems.
Seen a pilot or two that are pretty ignorant of aircraft systems too. I have been in this biz 30+ years I found the old timers the 727/DC-9 steam gauge guys had far more system knowledge than today's pilots. I have sat in class with new hire pilots they do not even touch things they did years ago systems wise. Pilots today are system managers nothing more.
Ryanair01 wrote:747classic wrote:Lpbri wrote:Problem is, when you shut down one pack, the remaining pack has to work harder. Nothing saved.
Bingo! From what I understand Pan Am had the same policy of reducing the number of packs that were switched on below a certain load. This worked on the 747-100, but when first introduced there was a problem with the 747-SP because it flew at a higher altitude. This caused breathing and light headedness problems for cabin crew, although not passengers because they were just sat there and not working, shifting trolleys, lifting in the galley etc etc. The sectors described by the book's author were operated by the 747-SP.
The only reason I've heard about this is that early 777-200s had a similar problem, as it was underestimated what the optimal levels required for different passenger loads at different altitudes are.
I think a lot of the posters above owe the nice lady an apology.......
