MatthewDB wrote:Is there even an oil pump on N2, such that N2 rolling backwards would even matter?
Starlionblue wrote:Not fast enough to cause issues.
Redbellyguppy wrote:I usually see 1.5-2.0 n1 when it is windmilling in a stiff wind which amounts to about a hundred rpm.
fr8mech wrote:N2 doesn’t typically windmill. There just isn’t enough velocity to do it. What you’re seeing is N1 or the Fan. I’ve never seen a prohibition against, nor an inspection required for windmilling on the ground due to surface winds.
MatthewDB wrote:fr8mech wrote:N2 doesn’t typically windmill. There just isn’t enough velocity to do it. What you’re seeing is N1 or the Fan. I’ve never seen a prohibition against, nor an inspection required for windmilling on the ground due to surface winds.
Cleary I reversed the terminology... Yes, all I could see is the fan and it's the fan that is rolling backwards. I didn't think N1 had a pump hooked to it. Do any designs have any accessories driven by N1?
MatthewDB wrote:But rolling dry will kill a bearing regardless of speed. I'm guessing that there is enough retained oil at all times that this isn't an issue.
Starlionblue wrote:Then again, this being aviation, there always seems to be some weird exception.
