flapsdown40 wrote:There are a couple of videos on Youtube where a passenger who was sitting in an overwing exit seat popped the window panel out, then jumped out of the plane while still on the ground.
Naturally, the planes needed to return to the gate so the passengers could be loaded onto a replacement aircraft.
Regarding the aircraft on which the overwing exit window/panel was removed, does the aircraft need to go through a complete pressurization system check before it can be designated as safe to resume flight?
Somewhat related to the aircraft's pressurization system, are *all* of the emergency drop-down oxygen masks replaced for sanitary reasons if they were actually used during the flight? I've heard of those odd occasions when the masks dropped for no reason- no pressurization problems, no other emergency conditions on board, etc. I've heard that some really hard landings have caused the masks to drop.
In a case like that, where none of the oxygen masks were used after a hard landing, does the maintenance crew simply come through the plane after it has landed (and after all of the pax have de-boarded) and stuff the masks back into the overhead panel? It must take a couple to several hours to do this, depending on whether the aircraft in question is a B737 or a B777 or an A380.
Thanks in advance for any replies.
Flapsdown40
strfyr51 wrote:flapsdown40 wrote:There are a couple of videos on Youtube where a passenger who was sitting in an overwing exit seat popped the window panel out, then jumped out of the plane while still on the ground.
Flapsdown40
To answer each question.
if the over-wing door is opened? you just inspect the door for damage and reinstall the door after checking the off wing Slide has not been Deployed (on acft with an off wng slide)
The Emergency masks are mostly if not ALL powered by Chemical oxygen generators. If the masks are dropped the passenger still has to deploy the generator by pulling on the mask. In that case the airplane cannot be dispatched at any altitude above 10,000 ft. with passengers on it. In my 35+ years I've seen that happen once. The airplane (A B737-300 w)as out of service for 28 hours as we replaced all the Oxygen Generators Trucked up from Southern California. The Generators cannot be air shipped anymore.
Lpbri wrote:737s do not have wing slides. If an over wing door is opened, it just opens upward, driven by a spring.
TSS wrote:Lpbri wrote:737s do not have wing slides. If an over wing door is opened, it just opens upward, driven by a spring.
I thought 737s had simple "plug" doors in the over wing positions that in the case of an emergency you unlatched, pulled inwards, and laid across the exit row seats. Am I confusing the MD80 procedure with the one for a 737?
yeelep wrote:737-100 through -500 has a plug type door that is removed from the opening. All NG/MAX have a door that is hinged at the top and pivots outward and up.
Max Q wrote:Those newer exits on the NG are a much neater solution ...
These are a big advance, in fact I think Boeing was mandated to make that change by airworthiness authorities
Max Q wrote:Those newer exits on the NG are a much neater solution than the old
plugs which required lifting out and then finding a place for in a crowded cabin of panicked passengers
stratclub wrote:Max Q wrote:Those newer exits on the NG are a much neater solution than the old
IIRC, with the old style, you were suppose to throw them out on the wing, I would guess preferably forward so people wouldn't trip on them. The spring loaded ones are an improvement, but the springs in them are very strong and it takes some brute force to close them.
stratclub wrote:I can'r remember which one, but the instruction to throw it out on the wing were on an airlines passenger emergency card. I don't think they wanted you to hand it to the little old lady that was behind you.................
