hem
What does ground scanning mean?
Mon Jul 02, 2018 3:06 am
we were practicing some troubleshooting procedure , where its says do ground scanning and refered some reference. What does this ground scanning means?
c933103
Re: what does ground scanning means?
Mon Jul 02, 2018 4:56 am
VSMUT
Mon Jul 02, 2018 7:26 am
Perhaps the ground mapping function in the weather radar?
Apprentice
Mon Jul 02, 2018 7:41 am
Hem, Good Morning,
May You provide us the Manual (?) reference received?
Re: What does ground scanning mean?
Mon Jul 02, 2018 1:23 pm
On the Airbus using the CFDS ground scanning tests various systems and computers, it is like providing the system/computer with known fake inputs via the CFDS test and seeing the system or computer generates the correct outputs or a fault.
strfyr51
Tue Jul 03, 2018 3:35 am
Correct! The Ground scan is ti Verify the faults and look for any related Faults. Many Airbus faults might be seen from more than one component.
Apprentice
Tue Jul 03, 2018 8:08 am
Hi:
Ground Scanning, for Airbus, is a test were flight conditions are not simulated. It’s simlest test.
Very simple (although I do not remember is this test are available):
Brake # N Ground Scanning, provides brake with hyd pressure for leak check.
A Brake Test, will simulate all conditions during a flight for Brakes, pressure in, antiskid release etc.
Normally, task will indicate which test You must performe, and it depends on previous condition: normal brake wear - ground scanning, wheel with a wear spot: antiskid full test.
Please remember those are just examples, I do not have Manuals with me.
Complete description should be found in front on troubleshooting manual.
(Mechanics don’t use to read this “Introductions”, for neither Boeing nor Airbus Manuals, but I recomend to do it)
strfyr51
Tue Jul 03, 2018 11:21 am
Apprentice wrote:
Hi:
The Airbus TSM will give you all the requirements for a Ground Scan. As not every fault reqires a Ground scan to verify it.
Apprentice
Thu Jul 05, 2018 9:27 pm
Hi: Out of Memory, Ground Scan been the simplest test, is the one You perform most comom, for other tests, like Pitch System, with involve several system, hidraulics, ADIRUS etc, there are specific instructions about when are mandatory.
Rgd#
Users browsing this forum: Max Q and 14 guests
