stephen88
Approach Ban
Thu Jul 19, 2018 5:43 pm
Now from I understand from the approach ban is that if the RVR at the airport you've commenced an approach at fall below minimums...
If above 1,000ft, don't descend below this, below 1,000ft, continue until the missed approach point.
If I was above 1,000ft, do I have to stay at 1,000ft until the MAPt or can I start climbing to the MAP stop altitude and then carry out any turns once I get to the MAPt?
ChrisKen
Re: Approach Ban
Thu Jul 19, 2018 6:04 pm
Depends where in the world you are (and company policies).
Re: Approach Ban
Fri Jul 20, 2018 6:57 am
As ChrisKen says it depends on national regs and company policy.
Having said that, if RVR goes below minimum and you are above 1000 feet, you go around and climb to the missed approach altitude. Since you can't continue down the glidepath, staying level would put you above profile. So it's not like you can descend again. No reason to stay that close to the ground, especially in low viz.
Any turns would be carried out as per the procedure, and may be before or after you reach the MAA, depending on how far along the horizontal path you have traveled.
BTW if RVR falls below minimum and you are below 1000 feet, you MAY descend to the DA/MDA. You don't have to if you really don't think conditions will improve enough.
IAHFLYR
Re: Approach Ban
Fri Jul 20, 2018 1:17 pm
Isn't the object to land? :))) Seriously, once you're issued the RVR outside the final approach fix and it is at or above minimums is it not completely legal (within the U.S.) to continue the approach as long as no further RVR is issued by the tower should it go below landing mins? When I was a tower controller we would issue the RVR's before the final approach fix and that was it. I'm pretty sure those rules have changed since I was in that position well before jet fuel was discovered.
SaveFerris
Re: Approach Ban
Fri Jul 20, 2018 1:56 pm
When operating in the US this is almost correct. Prior to the Final Approach Fix we have to have at least the required RVR to conduct the approach. However, once we are past the Final Approach Fix we are allowed to continue the approach regardless of what happens to the RVR. In theory the RVR can go down to 0 and if we are past the FAF we can legally fly the approach down to minimums.
As Starlion said, this does vary around the world. The above example is how the US regulations are worded.
GalaxyFlyer
Re: Approach Ban
Sat Jul 21, 2018 12:13 am
Outside the US, the 1,000’ floor is common, in the US, for air carriers and air taxi; it’s the FAF.
GF
Re: Approach Ban
Sat Jul 21, 2018 1:59 am
If the RVR is below your landing minima no need to descend to 1000, you can give it away earlier and make other plans. Or you can keep going to 1000 ft and try and get an updated RVR.
In most cases if the RVR is that low, you will be descending to a DH (ie Cat2/3) not to a missed approach point. This can be on the runway if the DH is zero.
When doing a missed approach regardless of approach type you are expected to carry out the standard missed approach. Unless there was a specific constraint in the procedure, the expectation is you will follow the lateral guidance on the chart and climb to the missed approach altitude/level via the published speed and altitude constraints.
The FAA has not implemented the ICAO approach ban procedure. ignore a lot of the posts above as they are not relevant to your question.
kalvado
Re: Approach Ban
Sat Jul 21, 2018 2:30 am
And a traditional remotely related question: when flying internationally how do pilots keep track of national regulation details? Some briefing cards for destination and all possible enroute diversion points? Or company/country of origin rules have priority over the rules of destination country?
FlyHossD
Re: Approach Ban
Sat Jul 21, 2018 5:48 am
As I recall, this was the case for CAT I and II approaches in the U.S. But for CAT III, if the RVR went below minimums any time inside the FAF, a missed approach was mandatory.
Re: Approach Ban
Sat Jul 21, 2018 8:02 am
Every port in our charts comes with a set of company notes containing local particularities. Normally a few pages with things like unusual comms procedures, noise abatement, cautions for narrow taxiways or tight turns, local APU regulations, target time regulations, etc... Even without the notes, local port regulations are published as part of the charts package. Review before approach and before departure, and highlight anything of note in the briefing.
Example: Barcelona. See pages 2-5. http://www.fly-sea.com/charts/LEBL.pdf
It's not normally that different, to be honest. The important stuff like "hold short runway xx" is the same. And ATC tends to be patient if you're not familiar.
Heard in HK the other week from what I think was a charter operator. In HK ground uses colours to designate pushback directions, and there are charts for it.
- "Flight 123, you are cleared push and start colour red."
- "Cleared push and start colour... ummmm... red, flight 123."
30 seconds later.
- "Ground, flight 123. Sorry, first time here. What does 'colour red' mean?"
- "Flight 123, just tell your ground engineer."
- "Ok thanks..."
Woodreau
Re: Approach Ban
Sat Jul 21, 2018 3:12 pm
ICAO publishes it's rules of the air which is the starting point. Then every country publishes an AIP which is the "rulebook" for what the rules are for the country and specifies differences from ICAO. For example in the US there is no Class F airspace but under ICAO rules there is. Each countries AIP will also publish regional procedures and also local airport procedures.
There are companies like Jeppesen and similar that collect all of the disparate national procedures and they are published as a general airway manual in addition to regional airway manuals like north America, South America, Atlantic Europe,etc which pilots can refer to specific countries or airport procedures.
Then for airlines their flight operations department will publish company procedures and summarize everything in a 10-7 page. Sometimes it's just a page or could be a small 20 page pamphlet for larger hub which discusses catering, maintenance or local ramp procedures
Generally you use the more restrictive rule that applies in a situation.
IAHFLYR
Re: Approach Ban
Sun Jul 22, 2018 7:08 pm
Not if you don't know about it!! :D :bigthumbsup:
FlyHossD
Re: Approach Ban
Mon Jul 23, 2018 8:41 pm
A true statement if ever there was one.
SaveFerris
Re: Approach Ban
Wed Jul 25, 2018 9:20 pm
Interesting point as I double checked our manuals and there is no differentiation between CAT II and III approaches if the RVR goes below published minimums. For both types of approaches it allows us to continue the approach so long as we are inside the FAF (assuming we are operating in the US). Might be time for me to do some digging.
Users browsing this forum: j2a2b2 and 11 guests
