JAGflyer
Packs and Supplementary Air Supplies
Mon Jul 30, 2018 1:27 am
Is it possible for the air conditioning packs (Environmental Control System) to be run off the bleed air supplied by a supplementary source (air start cart)? I have seen several references to air start carts that have an "ECS Mode" so that presumably they can supply air to run the packs for heating/cooling/pressurization testing. I've never heard of an air cart being used to run packs on the 737 during normal operations. Obviously in most cases where the APU is not usable/serviceable, there would be a pre-conditioned air source available for use in cooling/heating the cabin.
If you flew today, thank a Flight Dispatcher!
Francoflier
Re: Packs and Supplementary Air Supplies
Mon Jul 30, 2018 1:56 am
Technically, you can. It is however not recommended, and forbidden by most operators as the cart's air might be contaminated by oil and such... They are not designed to provide breathable air, that's what ground air con is for. :wink2:
arcticcruiser
Mon Jul 30, 2018 8:26 am
You wish... amazed at how difficult that can be at both European and US major airports. I really hate operating with an inop APU to the US. EUR is not much better, with all them limitations on running APUs you would thank they had a good alternate option. But no.
Mon Jul 30, 2018 8:43 am
As Francoflier says, you can do it but it isn't recommended.
There are some situations where you'd consider it. For example, if you're at a diversion port and there's no low-pressure air available. You get on board and the cabin is over 30 degrees.
Quite. And even if there's low-pressure air available, in many cases it doesn't really keep up with demand.
Dalmd88
Mon Jul 30, 2018 9:11 am
We use air carts or hangar shop air to run the packs for mtc tests. The packs never run at their best with that air source. The volume and temp are lower than engine bleed air.
Mon Jul 30, 2018 9:28 am
Indeed. Which is why when you start the engines on external air you have to check the available pressure.
Since those are "your" air carts, you can guarantee the quality of the air, and you don't have to worry about contamination. A bit of a different story if you end up at a minor port somewhere in diversion-land and they roll up with their rusty old cart which has been sitting outside in the rain for three years doing nothing and started service cranking De Havilland Comets... ;)
fr8mech
Mon Jul 30, 2018 11:25 am
Forbidden? With my operator, It’s actually standard procedure when the APU is inop. We don’t use or own conditioned air carts, since we are a cargo operator. And, in 28’ish years with cargo operators, I’ve never come across an air cart that contaminated a pneumatic system. Can it happen? Sure, just like an engine or APU can contaminate the system.
As stated, air carts aren’t really as efficient as the APU, but they are a suitable substitute for PACK operation and operational checks. It’s how we do it when the aircraft is in the hangar.
Mon Jul 30, 2018 11:38 am
Despite what my colleagues above have written we do at times run the packs at some ports off HP external air. The issue with those units at some ports is the equipment is not designed for delivering HP air for extended times.
It works well when used.
arcticcruiser
Mon Jul 30, 2018 7:11 pm
Agreed
fr8mech
Mon Jul 30, 2018 8:49 pm
Not to be pedantic, but it’s not HP air, it is low pressure air at high volume.
Florianopolis
Mon Jul 30, 2018 9:11 pm
Is this hooked up to the HP engine start air source, and routed to the pacs instead of to the engine starter? Or is there a separate HP air hookup for PAC feed air, in addition to the fat yellow hoses that hookup air conditioned air right to the distribution system downstream of the PACs?
Mon Jul 30, 2018 10:32 pm
It is called “HP Ground Air Supply” in the FCOM. LP Air in FCOM is external PCA that is connected directly to the mixing unit.
Connected the same way as an external start, once the system is pressurised the systems downstream do not know how it is being supplied, external HP, APU, or engines. LP air is not used at the same time as the packs as it is possible to get back flow.
fr8mech
Tue Jul 31, 2018 1:44 am
The max pressure produced by those carts is about 50psi, in jet start. Hardly high pressure. Yes, higher than a conditioned air source, but not high pressure, by any definition of the word.
I just looked at the AMM (B757), and the max pressure allowed at the pneumatic ground connection is 45psi.
Max Q
Tue Jul 31, 2018 4:07 pm
We used to have a centralized built in high pressure air system at every gate in one of our hubs
We ran the packs off it and could use it for an external start if the APU was inop
If most gates were occupied and all aircraft were using the system pressure would drop off and so would the effectiveness of the packs
Several airlines had this built in system including AA at DFW, don’t know if theirs still exists, ours was removed
GGg
Users browsing this forum: kalvado, vhqpa and 20 guests
