acjbbj wrote:But you can't just expect shortest takeoff with full flap, right?
Max Q wrote:Disagree on the static start
Turn on, keep it rolling and set
thrust without delay, then you have
10-20 knots in hand already
Why stop and have to accelerate
all that mass from a dead start ?
flyboy80 wrote:Does a higher flap setting decrease the initial rate of climb despite getting the airplane airborne faster?
GalaxyFlyer wrote:How did you line up, have 10-12 knots and not compromise (start the roll) the line up distance used by performance engineering?
From Boeing Jet Performance Training Manual:
These lineup allowances are published in the Flight Planning and Performance Manual and another document called the “Takeoff Safety Training Aid”. The allowances are provided for a 90° turn onto the runway, and for a backtrack followed by a 180° turn. It should be noted that these are the minimum possible line-up allowances for these maneuvers. Actual line-up allow- ances will depend on flight crew technique but will not be less than these published minimum val- ues.
GF
acjbbj wrote:How could one get a fully-laden (at MTOW) 773ER up in the air with zero ambient wind speed and using the absolute shortest runway length? What is that shortest possible distance?
BA777FO wrote:Only other thing to consider with the 777 and a rolling takeoff run is that you need the main gear steering to center otherwise uou'll get a takeoff config warning if you set takeoff thrust before it's centered and locked.
And that slows everything down!
AirKevin wrote:BA777FO wrote:Only other thing to consider with the 777 and a rolling takeoff run is that you need the main gear steering to center otherwise uou'll get a takeoff config warning if you set takeoff thrust before it's centered and locked.
I assume this is also the same with the 747.
