is a fault indication. Something is wrong with one of the reversers. You cannot depart with that light on."a thrust reverser light"
trijetsonly wrote:Could it also have been because of rejected takeoff requirements at Reno?
green12324 wrote:At my airline the thrust reverser can be put on MEL and flight released in most cases. Going to LGA both thrust reversers are required, and going anywhere with a short runway (DCA, BUR, etc) both would be highly desirable.
BoeingGuy wrote:green12324 wrote:At my airline the thrust reverser can be put on MEL and flight released in most cases. Going to LGA both thrust reversers are required, and going anywhere with a short runway (DCA, BUR, etc) both would be highly desirable.
Just out of curiosity, why are both reversers required for LGA? The runways aren’t that short. As you know, the auto brake settings command a given deceleration rate, with or without reverses.
Are they required for SNA?
JAGflyer wrote:With one T/R inoperative you're performance is as good as if both were inoperative since you obviously would not be activating only the remaining serviceable T/R.
trpmb6 wrote:The main concern with using only one T/R is asymmetric thrust which would need to be countered with rudder. Since we're talking a small amount of thrust being reversed I don't think it requires much rudder deflection to be honest.
aklrno wrote:I was under the impression that some aircraft do not require that the thrust reversers to be operational, and that the 737 was one of them.
On September 16 my Southwest flight RNO-LAX was about to pushback when the jetway was moved back to the door and the pilot announced that he had "a thrust reverser light" and we couldn't go to LAX without that functioning. Considering the length of 24R at LAX (the usual runway) I suspect that brakes would have been enough. Is the thrust reverser always required on a 737-700, it is a Southwest company rule, is the light in question more serious than just an inability to use the reverser?
I was very worried because I needed to make in international connection at LAX and every flight on every airline to every airport in the LA area was sold out. After about a 1 hour delay a contract mechanic called out by Southwest had resolved the problem.
This maybe the wrong form for this comment, but the Southwest pilot did a superb job of explaining the function and operation of the reversers and kept us informed of the test procedures. It seems that something called "built in test equipment" showed the reverser to be working correctly.
trpmb6 wrote:BoeingGuy wrote:green12324 wrote:At my airline the thrust reverser can be put on MEL and flight released in most cases. Going to LGA both thrust reversers are required, and going anywhere with a short runway (DCA, BUR, etc) both would be highly desirable.
Required for landing at LGA or for take off? Could be RTO that is the issue?
