aklrno
Does 737-700 require thrust reverser to be operational
Tue Sep 18, 2018 4:38 am
I was under the impression that some aircraft do not require that the thrust reversers to be operational, and that the 737 was one of them.
On September 16 my Southwest flight RNO-LAX was about to pushback when the jetway was moved back to the door and the pilot announced that he had "a thrust reverser light" and we couldn't go to LAX without that functioning. Considering the length of 24R at LAX (the usual runway) I suspect that brakes would have been enough. Is the thrust reverser always required on a 737-700, it is a Southwest company rule, is the light in question more serious than just an inability to use the reverser?
I was very worried because I needed to make in international connection at LAX and every flight on every airline to every airport in the LA area was sold out. After about a 1 hour delay a contract mechanic called out by Southwest had resolved the problem.
This maybe the wrong form for this comment, but the Southwest pilot did a superb job of explaining the function and operation of the reversers and kept us informed of the test procedures. It seems that something called "built in test equipment" showed the reverser to be working correctly.
fr8mech
Re: Does 737-700 require thrust reverser to be operational
Tue Sep 18, 2018 4:58 am
I can't speak to the B737 specifically, because I don't have access to its MEL.
But, a few things that can keep an aircraft from departing with an inop reverser. Weather at origin or destination. Other items on the aircraft that may be on MEL (speedbrakes, auto-brakes, etc.).
Further, there's a difference between an inoperative reverser and an indication system that's inoperative (thrust reverser light). There are some aircraft where the light can be put on MEL if it does not illuminate when deployed...this would include EICAS indication, but the reverser will have to be rendered inoperative. But, if the reverser shows "in-transit" or "full reverse" even with the reverser deactivated per the MEL, that tends to be a no-go item.
Again, this varies form aircraft type to aircraft type.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
Tue Sep 18, 2018 5:02 am
In this case maybe they go a warning of some kind on the reverser just before pushback. Or an actual light wasn't working.
While you can go without the reverser, it has to be locked out physically on the engine (at least on the planes I fly), and the fault has to go in the tech log, and the MEL has to be consulted. Not a massive deal, but it will cause a delay if it happens right before pushing.
Tristarsteve
Tue Sep 18, 2018 8:33 am
is a fault indication. Something is wrong with one of the reversers. You cannot depart with that light on.
So you test the reverser and check the BITE indication and see what it says. Then either the reverser is now serviceable, or it needs to be deactivated for departure. In good weather most airliners can depart with one reverser inoperative, as long as it is deactivated.
To deactivate a reverser, you mechanically lock it in fwd thrust position, and deactivate the operating mechanism. This is a job for a mechanic.
green12324
Tue Sep 18, 2018 8:55 am
At my airline the thrust reverser can be put on MEL and flight released in most cases. Going to LGA both thrust reversers are required, and going anywhere with a short runway (DCA, BUR, etc) both would be highly desirable.
The views expressed in this post are my own. They have not
been reviewed or approved by my employer.
trijetsonly
Tue Sep 18, 2018 9:00 am
Could it also have been because of rejected takeoff requirements at Reno?
Happy Landings
barney captain
Tue Sep 18, 2018 10:06 am
As Tristarsteve correctly pointed out - this was not a TR that was inop, but a fault in the system. The potential for an uncommanded inflight deployment makes this a no-go item.
Southeast Of Disorder
aklrno
Tue Sep 18, 2018 10:45 am
The usual runway , and the one we used that day is 16R, and it is 11,000 feet long. I think several other posts answered my question explaining that the cause of the error had to be resolved and the reversers could have been locked out if necessary. I was watching the mechanic through the window and he operated the reverse thrust mechanism several times before declaring it resolved. The pilot never said if it was a faulty indicator or if something had to be fixed. Reverse thrust worked at LAX. I easily made the flight to Auckland, where I am writing this post.
trpmb6
Tue Sep 18, 2018 1:38 pm
Yes, able to depart without reversers but as others have noted, they need to be deactivated (physically on the reverser). I actually know the person(s) who did the engineering on those parts.
stratclub
Tue Sep 18, 2018 2:11 pm
A very real possibility is that on the last landing, the pilot did not stow the T/R in a timely manner and a maintenance message (fault) was set which probably illuminated the "light" the pilot was referring to. To clear the maintenance message and light, the ground crew used BITE (Built In Test Equipment) to perform a ground test. The BITE test must of passed because If the BITE test had failed, the ground crew would have locked out the T/R if the MEL allowed the T/R to be deferred.
Example of an EEC BITE test after EEC change : http://www.sjap.nl/eec-bite-test-channel-b-737-678900/
Some good reading: https://www.boeing.com/commercial/aerom ... 01txt.html
pikachu
Tue Sep 18, 2018 3:06 pm
The Master MEL specifies one reverser required for dispatch on the -700.
Performance penalties can be quite restrictive.
BoeingGuy
Tue Sep 18, 2018 3:43 pm
Just out of curiosity, why are both reversers required for LGA? The runways aren’t that short. As you know, the auto brake settings command a given deceleration rate, with or without reverses.
Are they required for SNA?
trpmb6
Tue Sep 18, 2018 4:14 pm
Required for landing at LGA or for take off? Could be RTO that is the issue?
Lpbri
Tue Sep 18, 2018 4:57 pm
As was stated above, most T/R faults on a 737 are stow faults. These can usually cleared on the Engine Accessory Unit while operating the T/R on the ground. As was stated earlier, on inop T/R imposes operational restrictions. Dispatch concurrence is required for an MEL. The MAX has a different system. The EEC controls operation and may be less prone to nuisance fault messages.
CanadianNorth
Wed Sep 19, 2018 1:57 am
We don't operate -700s but on the 737s we do operate the MELs say the thrust reversers can be inoperative, however the more usual issue is the reverser unlocked indicator lights in the cockpit. If the light comes on during pushback or taxi it would normally be a return to the gate to find out why its indicating the reverser is unlatched when the pilots had not selected reverse thrust. Usually an indication issue however always worth checking as having a reverser unexpectedly deploy during flight has caused airplanes to crash before.
Either way indication issue or actually MELing a reverser requires calling maintenance anyway as in both cases the book will say to have a mechanic go inspect the reverers to confirm they have properly latched closed, and depending on the MEL it may also have maintenance go in and physically lock out that reverser.
HS-748, like a 747 but better!
JAGflyer
Wed Sep 19, 2018 3:57 am
With one T/R inoperative you're performance is as good as if both were inoperative since you obviously would not be activating only the remaining serviceable T/R.
If you flew today, thank a Flight Dispatcher!
pikachu
Wed Sep 19, 2018 5:30 am
I disagree...
mmo
Wed Sep 19, 2018 5:39 am
Why not???
trpmb6
Wed Sep 19, 2018 4:57 pm
I think utilizing one T/R with the other inoperative is up to the operators and would certainly impact operation restrictions (runway length for landing changes). Would also impact RTO operations.
The main concern with using only one T/R is asymmetric thrust which would need to be countered with rudder. Since we're talking a small amount of thrust being reversed I don't think it requires much rudder deflection to be honest.
JustAnFO
Wed Sep 19, 2018 10:06 pm
It doesn’t. I’ve used one reverser on the 737NG because on the other T/R inop many times, and the asymmetric effect is minor and easily offset with gentle rudder pedal steering inputs.
strfyr51
Thu Sep 20, 2018 7:02 am
It might have been a thrust reverser UnLocked light meaning that the reverser was not fully stowed or the reverser interlock was inop. .
The reverser can be inop as long as it's locked in the stowed position Mechanically. It could also have been a faulty or dirty Proximity sensor .
Passedv1
Thu Sep 20, 2018 11:27 am
Dispatch with TR inoperative usually has minimal impact in normal operations because performance is not predicated on TR use most of the time.
green12324
Fri Sep 21, 2018 7:03 am
Sorry, I should have specified. Required on the 737-800/900/900ER/MAX9 for landing. 737-700 would technically be allowed to go to LGA w/ T/R deferred (based on CA/dispatcher discretion).
Users browsing this forum: boeing767322er, Drucocu and 14 guests
