B727Learn
B737NG Cockpit Oxygen Masks
Tue Oct 02, 2018 12:46 pm
Hi Everyone,
1) Anyone knows the flow rate of the O2 mask for the B737NG as per different mask settings and ambient pressure?
2) How much time is the minimum dispatch amount suppose to provide you?
Thank you in advance.
B727Learn
Reason: Title edited for clarity
BravoOne
Re: B737NG Oxygen
Tue Oct 02, 2018 8:10 pm
Are ypu talking about crew O2 or Pax O2 generators which of course only have one setting?
B727Learn
Re: B737NG Oxygen
Wed Oct 03, 2018 3:28 am
Hi, sorry, yes flight crew masks... Thanks.
Re: B737NG Cockpit Oxygen Masks
Wed Oct 03, 2018 3:45 am
I thought it was 2 hours regardless of type. But I could be wrong.
B727Learn
Thu Oct 04, 2018 3:48 am
Based on the minimum dispatch amount??
Thu Oct 04, 2018 3:55 am
When I wrote my reply I only remembered the number. But it is based on regulations. Minimum dispatch is a pressure value because that's the figure we have, and that pressure must give us 2 hours. Some routes require higher pressure than others, presumably because they have additional crew members and/or fly over high terrain that will preclude an immediate descent to 10000 feet.
14 CFR 121.333 - Supplemental oxygen for emergency descent and for first aid; turbine engine powered airplanes with pressurized cabins.
(b)Crewmembers. When operating at flight altitudes above 10,000 feet, the certificate holder shall supply enough oxygen to comply with § 121.329, but not less than a two-hour supply for each flight crewmember on flight deck duty. The required two hours supply is that quantity of oxygen necessary for a constant rate of descent from the airplane's maximum certificated operating altitude to 10,000 feet in ten minutes and followed by 110 minutes at 10,000 feet. The oxygen required in the event of cabin pressurization failure by § 121.337 may be included in determining the supply required for flight crewmembers on flight deck duty.
https://www.law.cornell.edu/cfr/text/14/121.333
Lpbri
Thu Oct 04, 2018 12:19 pm
Minimum flight crew oxygen pressure for dispatch on a 737NG non-etops is 450-500 psi for 2 occupants. 640-700 psi for 3 occupants. Im seeing 830-900 for 4. Not sure how you get 4 people into a 737 flightdeck.
barney captain
Thu Oct 04, 2018 1:20 pm
Two cockpit seats and two jumpseats. It happens every day - and yes, it sucks.
Southeast Of Disorder
DL777200LR
Sat Oct 06, 2018 8:01 am
Doesn’t 1 jumpseat take the space at the door? Where is the 2 jumpseat located??
Nothing better than the sound of a 77W GE90-115B on engine start.
Lpbri
Sat Oct 06, 2018 1:44 pm
To the right is a luggage rack. Someone figured out you could put a seat there. The FAA actually approved it. There is a provision for an O2 mask there. I've never seen it, but you can put 4 people in a Volkswagon
barney captain
Sat Oct 06, 2018 4:00 pm
7BOEING7
Sat Oct 06, 2018 6:26 pm
The photo makes it look like there's more room than there really is -- if the captain is tall you better not bring your legs if you want to sit there.
JAGflyer
Mon Oct 08, 2018 8:52 pm
My airline has deleted the #2 jumpseat (behind the captain) on the 737NGs so there is no seatbelt/padding. The one that folds down however is used periodically and I have flown numerous 4+ hour flights in it with no issue. I am 5"9 and 140lbs though so that may help. It's possible to stand up and stretch easily.
If you flew today, thank a Flight Dispatcher!
barney captain
Tue Oct 09, 2018 12:13 am
Absolutely. Even an average sized Capt will leave just a few inches between seat back and the JS - causing you to straddle the seat on either side.
Awesome.
Users browsing this forum: Hosta, RetiredWeasel and 11 guests
