Page 1 of 1
Refuelling time question
Posted: Sat Oct 06, 2018 7:39 pm
by ro1960
A friend of mine recently flew from DFW to CDG. His flight was delayed 2,5 hours on departure. I tracked the flight and the aircraft used (AA B772 N766AN) and noticed that it was schedule to land in DFW from NRT at 4:25pm for a 5:15pm departure to CDG:
https://www.flightradar24.com/data/aircraft/n766an
It seems way to short to turn around an aircraft after an 11-hour flight. I know refuelling can take quite some time with wide bodies and it must have certainly played a role in the late departure.
So I came to wonder how long it takes to fully refuel an aircraft like a 772? I'll be curious to know for other current aircraft as well.
Re: Refueling time question
Posted: Sat Oct 06, 2018 7:42 pm
by Tristarsteve
Fuelling is not the problem. You can always refuel an aircraft in the time it takes to offload pax/clean cabin/recater/load pax. The critical path with a quick turnround is always the cabin.
Re: Refuelling time question
Posted: Sat Oct 06, 2018 11:02 pm
by zeke
Probably looking at around 35 minutes to refill from empty to the required level at 2.4 tonnes per minute, however they would still have the fuel onboard from the inbound sector so closer to 30 minutes.
Posted: Mon Oct 08, 2018 9:22 pm
by ro1960
I imagine but I was interested to know if on such a short turnaround the refueling of a wide body had an impact.
Posted: Mon Oct 08, 2018 9:27 pm
by ro1960
Thanks for the info. Are both sides refueled at the same time to gain time? How many nozzles are used?
Posted: Mon Oct 08, 2018 11:39 pm
by Starlionblue
I think the only real "impact" is on operational procedure, but the procedure would probably not need to be changed.
Typically fueling starts well before we get the final zero fuel weight, with a standby figure a few tons lower than the preliminary required fuel quantity. That way when we get the final zero fuel weight and work out the final fuel figure, all that is needed is a top up for the last few tonnes.
For a short turn, just give the fueler the standby figure as early as possible.
In some cases, for example at airports where fueling with pax onboard is not permitted, fueling will begin before the crew even arrives.
Posted: Tue Oct 09, 2018 1:42 am
by Woodreau
It's most likely a single point fueling. The fuel is distributed by the fuel computer into the appropriate tanks.
As an off-topic fueling topic - my ship could accept two-dual STREAM fueling rigs from the replenishment tanker. So through 4 simultaneous fueling connections, it takes about 14 hours to take on 1.5 million gallons of fuel. 1.1 million for the ship and 400k JP-5 for the jets and helos.
Posted: Tue Oct 09, 2018 6:30 am
by wpnstroop
You also need to factor in the fact that a large percentage of people that work at airports are in no hurry to do much of anything.
Posted: Tue Oct 09, 2018 7:37 am
by Starlionblue
That hasn't been my experience in most of the most places I fly to. There tends to be quite a "get things done" attitude in the air.
Posted: Tue Oct 09, 2018 8:57 am
by Tristarsteve
Not often. You need to be filling over around 90 tonnes of fuel before using two fuel vehicles becomes worthwhile.
One hydrant dispenser with two hoses is quite adequate for most refueling operations.
The only time that two vehicles becomes necessary is maybe a B744 transit. I used to refuel B744 at ARN for Malaysian which were on transit, JFK-ARN-KUL. If they were running late we had 75 min transit time, and departure fuel load of 130 tonnes, and then we found that using fueling vehicles on both sides helped. Doing the same transit with a B777, which needed much less fuel, a single vehicle was adequate.
Posted: Tue Oct 09, 2018 3:25 pm
by ro1960
What do you call a large percentage? Do you have a source for that? Or is it just a baseless judgment on a certain kind of aviation workers?
Posted: Tue Oct 09, 2018 4:30 pm
by stratclub
Really. In any mix of professions there will always be a mix of all types of people all with different capabilities and motivations. Your comment is a slap in the face to the majority of people that are dedicated and motivated to being a valued asset to their employer.
Posted: Tue Oct 16, 2018 6:33 pm
by exFWAOONW
Quit feeding the troll and get back on topic. You hope the single-point wasn't MEL'd. Filling by gravity takes even longer.
Posted: Tue Oct 16, 2018 11:01 pm
by stratclub
That could be a long miserable afternoon of sitting on top of the wing especially if weather was terrible. In 30 some odd years, I've never gravity fueled a heavy. The 787 did away with drip sticks and over wing fuel caps.
Posted: Thu Oct 18, 2018 4:47 am
by Max Q
Which ship was that WD ?
Posted: Fri Oct 19, 2018 10:16 am
by Woodreau
Just a tiny amphibious assault ship
Carriers don’t have to worry about fuel for itself other that what it needs for emergency generators and portable damage control equipment. It just uses JP-5 from what is allocated for its aircraft for that purpose.
Posted: Fri Oct 19, 2018 4:39 pm
by LH707330
Where do other heavies have the gravity-feed caps? Are they out near the tips due to the dihedral?
Posted: Tue Feb 05, 2019 7:07 am
by wpnstroop
I base it on personal observations from the last 29 years of my life spent on commercial airports as a mechanic for major airlines. Feel pretty qualified to make that statement regarding airport personnel and their demeanors.
Posted: Tue Feb 05, 2019 8:56 am
by stratclub
Ah, no. The 747 has over wing fuel caps near the wing root. With the aircraft fueled to VTO (Volumetric Top Off), if you removed the over wing fuel caps, most likely fuel would come pouring out.
Posted: Fri Feb 08, 2019 6:26 pm
by Balerit
When SAA had to fly around the bulge of Africa we would fuel the 747-200's to max which was s about 162000 kg's and it would take about 2 hours. The dispenser would have two hoses connected and often one of the other dispensing trucks with a bit of spare time would hook up on the r/h wing for maybe 30 minutes. We would often just finish before doors closed.
