TWA302 wrote:Probably one of the most awkward questions I have seen posted here, but I guess the answer to your question is here?? I say that with a question mark too.
https://en.wikipedia.org/wiki/Tuninter_Flight_1153
Another subject of controversy is the relative seaworthiness of high-wing versus low-wing airplanes and fixed gear versus retractable gear. Most pilots contend that the ideal airplane for ditching is a low-wing aircraft with landing gear retracted. Statistics, however, do not substantiate this. Aircraft geometry and landing gear configuration do not appear to affect survivability appreciably.
Although low-wing aircraft do offer superior planing and buoyancy (especially with empty fuel tanks), they should not be landed in water with flaps fully extended because this can cause pronounced nose-down pitching and make the aircraft behave like a submarine. Also, flaps hanging from a tow wing may be torn away during touchdown, which might create gaping holes in the wings and have a disastrous effect on buoyancy. Consequently, low-wing airplanes typically land faster, increasing the probability of damage and injury.
Since the flaps of high-wing aircraft are less susceptible to water damage, they should be used to the maximum extent possible to reduce impact speed.
Whether an aircraft sinks or floats does not appear to effect the excellent survival rate. [...] Although less than 15% of all ditchings involve fatalities, the U.S. Coast Guard points out that most of those who perish usually survive the procedure itself.
skipness1E wrote:Sully showed that ditching a low wing airliner is possible safely. However if my day went wrong and the ATR or Dash 8 I was on was forced to ditch, would it float on the wings with the cabin submerged and me drowned or roll inverted with the weight of the engines?
GalaxyFlyer wrote:One thing it wouldn’t do is roll over, wings will ensure that happen. Gear down likely pitchpole, though. The C-5 ditch modeling showed it would float somewhat nose low. IIRC, aft gear extended to act brakes on impact.
GF
Erebus wrote:What is a typical approach speed for a turboprop like the ATR or Dash 8?
Okie wrote:skipness1E wrote:Sully showed that ditching a low wing airliner is possible safely. However if my day went wrong and the ATR or Dash 8 I was on was forced to ditch, would it float on the wings with the cabin submerged and me drowned or roll inverted with the weight of the engines?
There were multitudes of high wing aircraft long before airports that were called "flying boats"
Sort of started with Pan Am.
While they had sponsons on outriggers on the wing to prevent the wings from water contact, I do not remember any stories about sinking.
On the other hand I do remember video of the Ethiopian airliner, (767?), that was hijacked and ran out of fuel and ditched. It caught a wing low into the water while ditching and cartwheeled and disintegrated. There was a lot of loss of life even being a very short distance from shore and many volunteers to help with the rescue.
Okie
EChid wrote:Okie wrote:skipness1E wrote:Sully showed that ditching a low wing airliner is possible safely. However if my day went wrong and the ATR or Dash 8 I was on was forced to ditch, would it float on the wings with the cabin submerged and me drowned or roll inverted with the weight of the engines?
Okie
My recollection on the Ethiopian flight was that there was an ongoing struggle in the cockpit which, in turn, caused the wing to tip and caused the disaster. But this fact doesn't change the statistics you're taking about.
skipness1E wrote:However if my day went wrong and the ATR or Dash 8 I was on was forced to ditch, would it float on the wings with the cabin submerged and me drowned or roll inverted with the weight of the engines?
ELBOB wrote:Certification requires submission of ditching & floating modelling data, either physically or computationally obtained. That's also how manufacturers determine which doors to indicate for use on the safety cards. Check those and you'll deduce how the aircraft is expected to float, for high-wingers it's usually tail-down and one wing low.
