StereoTechque wrote:But all this sounds somewhat minor, considering the 30+ years of progress and innovation. I mean, if you compare a PC or any piece of electronics from the 90s with the one we have today, it's a huge difference. Shouldn't they have more automated monitoring of various parts and more redundancy also?There are a few namely-
LCD screens.
Standby horizon, standby ASI, RMI replaced by ISIS (digital)
Old ones had floppy driver for data loading in the center pedestal.
New ones especially Neo's have LED lighting in the cockpit.
Francoflier wrote:Pilots who possess an A32x rating need to be able to operate a 1988-built A320 (if there were any left) and a 2018-built A321NEO seamlessly on the same day.
Flow2706 wrote:There were a few changes - one „package“ was EIS 2, which are basically the LCD screens. There were a few changes to the hydraulic architecture over the years and in other systems as well. Since a few years there is a BUSS (Backup Speed Scale) for unreliable airspeed procedures. There are several different weather radars and FMGCs available. The newest weather radar is really nice as it is able to display the weather at any selected level without the need for setting a tilt (it’s even possible to select different levels on the FOs and CPTs side). There is a simpler fuel system since a few years as well on A320s (it’s now more similar to the one used on A321s). Since a few years the Autopilot is able to follow TCAS RAs automatically - I’ve never flown an aircraft with this feature until now but apparently it’s a nice feature for this kind of stressful situation. As you see it’s really only minor things, the most significant in day to day operation is probably the new FMGCs (the old FMGCs don’t have a fix Info Page not the ability to show Abeams when getting shortcuts so it’s a bit annoying to do fuel checks on these...PM will have to select the secondary flightplan to see the waypoints and to do the fuel checks when passing abeam...it’s much more comfortable on the new ones with the abeam function).
greg85 wrote:At my airline (probably everywhere else too), the DDRMI is now gone (the old fashioned backup VOR needles). But their is still a cut out in the plastic fascia for it. There is literally an empty hole in the panel.
Elshad wrote:Presumably the CPUs have been updated as well. The early aircraft used Intel chips with just a few megabytes of memory
Woodreau wrote:I guess option to not have the floppy drive costs extra.
I just flew a 320 that was manufactured earlier this month and delivered last week from Airbus and the floppy drive is installed with a full set of twenty 3.5” floppies and 15 CD-ROMe stored in the flight deck media storage compartment.
Kindanew wrote:Lol, is that for when you need to reinstall Airbus OS?
Flow2706 wrote:Amazing answer with so many technical details. Thank you!There were a few changes - one „package“ was EIS 2, which are basically the LCD screens. There were a few changes to the hydraulic architecture over the years and in other systems as well. ...
VSMUT wrote:Francoflier wrote:Pilots who possess an A32x rating need to be able to operate a 1988-built A320 (if there were any left) and a 2018-built A321NEO seamlessly on the same day.
The ATR -600 series upgrade is the perfect example of why not to do it. Pilots rated on old ATRs had to do a simulator course to fly the -600. Pilots who do the type rating on the -600 can't fly the older variant at all, unless they do the entire type rating course over again. This resulted in overbooked simulators with month long waiting lists, and airlines sending their crews halfway across the world for that single available sim slot in Singapore or Miami. Now that the -600 is becoming more predominant, operators of older ATRs are having increasing troubles finding crews to fly the old cockpit variants, because more pilots are being type rated directly to the -600.
LimaFoxTango wrote:VSMUT wrote:Francoflier wrote:Pilots who possess an A32x rating need to be able to operate a 1988-built A320 (if there were any left) and a 2018-built A321NEO seamlessly on the same day.
That's due to the way ATR designed their training program. They have a -500 to -600 course which is like a week long that allows pilots to fly both. They do not offer a -600 to -500 course. A -600 only rated pilot would have to to an entire -500 course from scratch, which incidentally is probably about 90% similar as the only difference between the aircraft is the cockpit avionics.
