GianiDC wrote:As an aftermath, spoilers now automatically retract when giving max power.
ilovelamp wrote:GianiDC wrote:As an aftermath, spoilers now automatically retract when giving max power.
Not on all airliners; however, it became required procedure to verify speedbrakes are stowed for go-arounds, and TCAS and wind shear escape maneuvers.
Newbiepilot wrote:ilovelamp wrote:GianiDC wrote:As an aftermath, spoilers now automatically retract when giving max power.
I think there was a service bulletin to change the logic so spoilers automatically retract if TOGA is selected
GianiDC wrote:Didn´t they also had the spoilers up and didn´t retract them while applying full thrust, thus resulting in worse than normal climb performance? As an aftermath, spoilers now automatically retract when giving max power.
FrmrKSEngr wrote:Didn't that accident hasten the introduction of EGPWS, with the terrain data base?
PSAatSAN4Ever wrote:GianiDC wrote:Didn´t they also had the spoilers up and didn´t retract them while applying full thrust, thus resulting in worse than normal climb performance? As an aftermath, spoilers now automatically retract when giving max power.
The speed brakes were on and it was configured for landing.
Max Q wrote:FrmrKSEngr wrote:Didn't that accident hasten the introduction of EGPWS, with the terrain data base?
It did
However the 757 /67 were not modified
to retract speed brakes in flight
with application of full power
OTOH they will retract on the ground
It did
2140:40 Captain: It's that [expletive] Tulua I'm not getting for some reason.
2140:44 Captain: See I can't get, OK now, no, Tulua's [expletive] up.
2140:48 First Officer: OK. yeah.
2140:49 First Officer: But I can put it in the box if you want it.
2140:52 First Officer: I don't want Tulua. Let's just go to the extended centerline of uh....
2140:55 Captain: Which is Rozo.
2140:56 First Officer: Rozo.
2140:56 Captain: Why don't you just go direct to Rozo then, alright?
2140:58 First Officer: OK, let's...
2140:59 Captain: I'm goin' to put that over you.
The speed brakes were on and it was configured for landing. Full thrust was applied, but the configuration of the wings prevented it from gaining altitude.
In addition to the above-mentioned TOGA-power-application/stowage-of-spoilers and beacon/waypoint-selection-protocols, I'm sure there were changes as well to approaches in Colombia, given the FARC-led violence and damage to infrastructure in the country - one of the issues that, although relatively minor, was a link in the chain that led to the accident, wherein a non-operational beacon had a designation that was way too similar to the desired one (with its designation being changed after the accident, IIRC).
Can you provide a link to the SB you referenced? You know, the one "you think" there was?
Also please advise of your total time flying the 757 as it would make your credibility that much more respectable.
I don’t have any flying time on the 757, but I can state with accuracy what Boeing airplane models do and do not have auto retract in the air, and what Boeing models have warning alerts for speed brakes up and thrust past a certain level.
However, as I stated in a previous post, the statements made by each person who you replied to are not correct. Boeing looked at adding an auto retract speed brake function in the air on all models, but the mechanisms don’t support it without a large infeasble redesign on models that existed at the time. The 787, 777X have it.
bhill wrote:This discussion has me thinking....granted, not real accepted piloting, but as many have said the 757 is a rocket, and as I read here gear and flaps were up and only speed brakes were deployed, "would" the airplane at FULL power managed enough energy to maintain climb, or was there just not enough energy to begin with to maintain flight? Or is the design of the wing/lift surfaces such that I am way off base?
trpmb6 wrote:For the aircraft that do have auto retract features when TOGA is selected, do they impact roll spoilers? Or are their systems separated (as I hope they are).
Starlionblue wrote:trpmb6 wrote:For the aircraft that do have auto retract features when TOGA is selected, do they impact roll spoilers? Or are their systems separated (as I hope they are).
As GalaxyFlyer says, the roll control function is separate.
I can only speak for 330/350 but roll control has priority over speedbrake. For example, if the flight control system requires more deflection from a spoiler than the sum of simultaneous speedbrake and roll order, it will retract the opposite surface until the difference between the symmetrical surfaces is equal to the roll order.
