blacksoviet
How does LATAM fly the 787 between AKL and SCL?
Fri Jan 11, 2019 10:37 pm
Don't ETOPS regulations require a quad-jet on this route? Is there a island where they can land a 787 in an emergency?
Apprentice
Re: How does LATAM fly the 787 between AKL and SCL?
Sat Jan 12, 2019 1:45 am
B787 will be certified for 330 minutes. (5 1/2hours).
Not been a pilot, my calculation give me that plane will be always between 51/2 hours of Auckland or Santiago, been distance between them
Around 11:00 (direct flight)
As I understand, mayor concern is Jet lag. But, with higher humidity and cabin pressure, expectation are...
“An4; IL18; IL6; Tu5; D10; MD11; MD83; B32; B34: B37; B744; B748; B752; B763; B772; B773; B77W; A320; A332; A333; A342; A343.
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
“CUBANA” 90 years Flying”
Stitch
Sat Jan 12, 2019 1:59 am
The 787 has been certified for ETOPS-330 since 2014 and using Great Circle Mapper it looks like they can fly a direct routing. The FAA has reduced ETOPS for the Trent 1000 family in certain situations, but those might not reply to a Chilean-registered airframe or if they do, LATAM might be using frames powered by RR engines not under the FAA restrictions.
blacksoviet
Sat Jan 12, 2019 2:14 am
Did the Lan Chile 767-200ERs have enough range to fly from SCL to AKL?
Stitch
Sat Jan 12, 2019 4:20 am
Perhaps if they were empty. :)
I think the 767-200ER is limited to ETOPS-180/207 and that means it would need to take a far more northerly track to stay within range of alternates and that would significantly increase the total flight time / distance to the point it would certainly impact available payload due to the need to load more fuel.
Apprentice
Sat Jan 12, 2019 11:49 am
Are We talking about a B767-200 or B787?
Stitch
Sat Jan 12, 2019 5:32 pm
Both.
The 767-200ER and 787-9 have the range to make the trip with their design payloads flying a direct path, however ETOPS routing considerations allow the 787 to fly direct under ETOPS-330 while requiring the 767 to fly farther north as there are no available alternates within ETOPS-180/207(/240) minutes to allow a direct path.
Flyingdevil737
Sat Jan 12, 2019 10:16 pm
They also fly the 789 between SCL and MEL, and that’s even longer.
And this, ladies and gentlemen, is the very first Fokker airplane built in the world. The Dutch call it the mother Fokker.
Users browsing this forum: No registered users and 26 guests
