akb88 wrote:Is that possible with all the regulations in place?
Flow2706 wrote:Airplanes are designed with redundant systems, so even if something fails there will always be an other system that will substitute for the failed system. Most single failures don't have any effect on the flight and even if two redundant systems fail (which is highly unlikely) the airplane will still be under control.
akb88 wrote:So are all my worries unfounded then? Do I need to worry about poor maintenance in let's say Norwegian airplane. Surely it must be the case that if there is even a slight hint of doubt regarding the planes airworthiness that it's pulled from service. No matter what airline or country it comes from.
fr8mech wrote:akb88 wrote:So are all my worries unfounded then? Do I need to worry about poor maintenance in let's say Norwegian airplane. Surely it must be the case that if there is even a slight hint of doubt regarding the planes airworthiness that it's pulled from service. No matter what airline or country it comes from.
I wouldn’t say any aircraft or operator, but I wouldn’t be concerned about any aircraft maintained under FAA, EASA, JAA, etc., oversight.
fr8mech wrote:While, I understand the sentiment, the redundancy designed into an aircraft doesn't factor into my decision making process one bit when I exercise my authority to release.
akb88 wrote:fr8mech wrote:akb88 wrote:So are all my worries unfounded then? Do I need to worry about poor maintenance in let's say Norwegian airplane. Surely it must be the case that if there is even a slight hint of doubt regarding the planes airworthiness that it's pulled from service. No matter what airline or country it comes from.
Alright. Every airline I travel with is under these regulatory bodies. So an airline operating in Europe and North America should be a safe airline.
I feel so weird and pathetic asking all this cause I never had this issue until my late 20s
Starlionblue wrote:The first step is to understand that rationally speaking, there is no basis for these particular fears. That won't make them go away by itself, but it is the beginning of the process of removing the fears. Since your fears seem to be stopping you from enjoying something you wish to do (travel), I would highly recommend taking a fear of flying class. These are offered by many airlines.
fr8mech wrote:Starlionblue wrote:The first step is to understand that rationally speaking, there is no basis for these particular fears. That won't make them go away by itself, but it is the beginning of the process of removing the fears. Since your fears seem to be stopping you from enjoying something you wish to do (travel), I would highly recommend taking a fear of flying class. These are offered by many airlines.
Years ago, pre-9/11, one of my wife’s coworkers mentioned to her that he and his fiancée were scared of flying, but were looking at a honeymoon in the Bahamas and were scared to book it. One thing led to another and I took them out to our facility on DFW to walk them through some aircraft and watch some maintenance in work.
They got more than they bargained for...a DC-8 engine change, a B727 aileron change, along with our normal package of lubes and service.
They were fascinated and watched, with great intent, the mechanics hoist, bolt-up and torque the engine.
On the way to dinner later, they remarked how impressed they were with the care taken by the mechanics on the cargo aircraft, and that surely ‘passenger’ mechanics took even more care in their work.
Starlionblue wrote:Side note: The old "cargo" vs "passenger" thing seems to be endemic. Almost every non-industry person I meet thinks that cargo and pax ops are different and have different safety standards.
fr8mech wrote:Starlionblue wrote:Side note: The old "cargo" vs "passenger" thing seems to be endemic. Almost every non-industry person I meet thinks that cargo and pax ops are different and have different safety standards.
I felt I had pushed my amateur psychology session far enough, so I didn’t correct their perception. I really didn’t see any upside to it.
747Whale wrote:It intrigues me that the bent of this conversation (and thinking in general) leans toward blame. If there's a mechanical problem on board, it must be bad maintenance. The mechanic must be at fault. Airplanes don't fail or crash if the mechanic has done his job. This is a fallacy. Every bit as much as the idea that there is so much redundancy in aircraft design that an error or a failure won't cause a problem. Or a mishap. Equally fallacious is the notion that fears of mechanical failure are unfounded. Of course such fear is valid.
Can the airplane break? You bet.
Over the course of my career, I've had engines catch fire, lose all the oil, fail to partial power, compressor stall, pour fuel, overspeed, or simply fail. I've had hydraulics rupture, actuator seals blow out, landing gear fail down, fail up, flaps blow up, bleed down, an aircraft filled with misted hydraulic fluid, smoke in the cockpit, onboard fires, pneumatic failures, two explosive depressurizations and another rapid one, ice failures controls, fuselage, and engines burned through with lightning, electrical fires and electrical failures, blown tires, brake failures, runaway trim and autopilots, failed instrumentation, total electrical failures, and cracked wings. Five aircraft that I've flown have had the wings crack completely through, and in two cases the wings separated from the aircraft, killing all aboard (I wasn't aboard at the time, quite clearly). These things to name a few on the tip of the ice berg.
Lest some idiot quip "remind me never to fly with you" as idiots are wont to do, these occurred in all kinds of aircraft and all kinds of operations over the course of many years, and are a few of the things I've experienced personally, but a drop in the bucket compared to the things I've seen in aviation, and those who would suggest that these are isolated or don't happen to aircraft they fly are either willfully blind or so foolishly naive as to have no credibility. This is the reality of things. Whether it's a 737 blowing its top or one exploding on the ramp due to tank vapor (or a 747, for that matter) or a gear collapse on a runway, these things can and do continue to happen. Aircraft are mechanical objects and they're complex, and often due to the fault of no one, they do break. We work hard to mitigate this, we maintain well, we fly carefully, but whether it's the collective stress of landings or pressure cycles or a stress riser in an unseen place (even from manufacture), parts, and assemblies of parts can and do fail. That's the reality. It is never a matter of if. It is always a matter of when.
The other reality is that the when doesn't occur often. The when occurs more often in some operations than others, in some types of equipment than others, and in some situations than others. It occurs less frequently in most airline operations than other areas.
Radial engines fail with some regularity. We don't use radial engines in the airlines. Engines that are used irregularly and inconsistently fail more often than those that are operated the same way and operated frequently, and airline operations are very standardized and constant, and maintenance occurs between almost every operation (for some airlines). Instruments and avionics that sit tend to experience far more failures than those that are used frequently, and airline operations use them constantly, and replace them immediately when a problem occurs.
Many aircraft get inspected once every 100 hours, some only once a year. Airline inspections are daily, weekly, and have large-scale, complex phase inspections that dismantle entire sections of the aircraft to examine every component. Every pilot that flies the aircraft writes up each discrepancy, after each flight, which is attended to by maintenance before the aircraft can fly the next flight. Airline operations fly to and from airfields with multiple instrument approach procedures, in nearly all cases accompanied by experienced controllers and excellent radar. Guidance is by satellite, internal gyro and solid state navigation, ground beacons, and radar services. Weather reporting is available in advance and is very good, in flight in real time, and by weather radar advanced enough to predict and warn of wind changes on an approach, and which can color code the amount of precipitation and activity 80 or 160 miles ahead of the aircraft, enabling avoidance and navigation around dangerous weather. Mechanics have access to tools, diagnostic and informational, far more advanced than what we once had, including aircraft that sense, sometimes diagnose, and present their problems, and systems that are modular and separated in some cases to isolate a problem and fix. Pilots have available the best simulation and training possible in the history of aviation, so that by the time a new pilot reaches the seat in the actual aircraft, he or she has already experienced and handled everything from onboard cargo fires to hydraulic, flap, and system failures, successfully, while graded and evaluated, instructed and trained, and has been the subject of tests, inspections, checkrides, and evaluations dozens or hundreds of times, and will continue to be throughout his or her career. That's the reality of climbing into an airliner today.
Yes, mechanical problems can occur. It really is possible to fly into volcanic ash and lose four engines; it's happened three times in the past. It really is possible to have an engine catastrophically fail and take out not one, but all three hydraulic systems, rendering all flight controls inoperative. It really is possible for the top third of a 737 to blow off the aircraft in flight. Or a 747 to explode. Or have a cargo fire. It happens, and has happened.
Airline operations move millions of passengers daily, operate thousands of hours, and span the globe, and are airborne around the clock. When we view these mishaps, these incidents, they do occur, but are so infrequent as to assure you that if it happens on your flight, it's your time and always was...but are so rare as to be experienced by few. There are many pilots who will go their careers, for example, and not experience but a fraction of this. Think of that; a pilot who dedicates his entire lifetime to. not just an occasional flight, but daily flight, and is exposed to flying at a rate many orders of magnitude over that of any passenger, and yet looks back without every having seen a hiccup. Indeed, most of the events I related above didn't happen on airline flights, but in other kinds of flying, many of which put the aircraft to considerably more hazard and stress than airline flying.
Are your fears valid. Absolutely. It does no good to suggest fear has no basis. It's like telling a child not to be afraid of the dark. It doesn't make the fear go away. You can tell me all day long that spiders are harmless. It won't help. You can tell me the hotel won't catch fire. It doesn't change the way I feel. And you can tell me that heights aren't a problem so long as I don't fall down. It doesn't matter. I'm fascinated by spiders but they paralyze me, I was caught in two burning buildings as a kid, and I've been in intensive care as the result of a fall. I don't care what the rational explanations are, and my pet kid fears will be the same fears in old age (the only difference being that as I get older, it matters less and less what happens to me). Your fears are valid, and they're your fears.
You can go on your flight, however, armed with the knowledge that while your fears are valid, and while nobody can talk you out of them, and while you're going to arrive at your destination safely and without incident, there's plenty to worry about, and worry you will. Don't let anyone talk you out of it. Those are your fears and you're entitled, and justified. Aircraft are complex; most have no concept of just how much there is that can go wrong on an aircraft. Big, thick stacks of books contain that information, and the books and manuals and diagrams and charts and guides and references and handbooks are incredibly complex and technical; so complex that they spell out the diameter and placement of every rivet in the aircraft, and they really do account for literally anything that can happen to or go wrong with that aircraft, as do the checklists and quick reference handbooks in the cockpit.
Try this. When I get in the door of an airplane, I'm full of trepidation; when I go out the door of the airplane into freefall (yes: I'm afraid of heights. This is true. But I also pick up spiders, fly into forest fires and jump out of airplanes. We face our fears to deal with them, rather than running away), there's nothing more I can do about height and I certainly can't prevent the fall at that point, as my decision was made when I left the airplane. I've made my choice, so I don't focus on height any more. When you get on board your next flight, you've made your choice. There's nothing you can do about the turbulence, or about a mechanical problem. Focus on watching the scenery out the window. Or reading a good book. Or watching the inflight movie.
I recommend Deadpool.
akb88 wrote:I understand that Europe has the most severe safety regulations but after having seen a news segment from America about airline bosses forcing airline mechanics to hurry with the turnarounds and cutting corners during their checks. This was with AA and Southwest but it made me worry about the same thing going on in Europe. Is that possible with all the regulations in place?
akb88 wrote:So as the title says I have developed a fear of flying. Which sucks. I have another thread going elsewhere on here that has really helped me alleviate some of my turbulence based fears . But I'm still unsure about the mechanical side of flying. Especially maintenance and I thought maybe someone here could help me.
I'm flying from Iceland to Greece and back with 3 large European airlines, Icelandair, Norwegian and Condor, in April and May to visit my girlfriend. I'm having anxiety regarding airplane maintenance, I understand that Europe has the most severe safety regulations but after having seen a news segment from America about airline bosses forcing airline mechanics to hurry with the turnarounds and cutting corners during their checks. This was with AA and Southwest but it made me worry about the same thing going on in Europe. Is that possible with all the regulations in place?
Is there anyone here with experience in this field or some knowledge about it that could help me with my fears?
VSMUT wrote:akb88 wrote:So as the title says I have developed a fear of flying. Which sucks. I have another thread going elsewhere on here that has really helped me alleviate some of my turbulence based fears . But I'm still unsure about the mechanical side of flying. Especially maintenance and I thought maybe someone here could help me.
It definitely is possible to cheat. Inspectors can only do so much. The industry relies on trust, and some airlines, even in the EU, misuse it.
That having been said, Icelandair and Condor are extremely competent airlines, and I would never hesitate to set foot on them. The planes return to a central maintenance base every night, they don't hop around Europe for several weeks without seeing an engineer. Northern European CAAs like Iceland and Germany are also among the most strict and thorough in the industry. It's not like the Irish who are understaffed and underfunded.
Georgetown wrote:Some truly great perspectives provided on here from professionals. I can’t say word one from that perspective, but I can give you the the perspective of a business traveler that flies a ton. Before I flew a lot, I was a very nervous flier that would have anxiety set to a low simmer for days, sometimes even weeks, before a flight. That said I have always been fascinated by airplanes and have been a plane spotter since I was a young teenager.
Now for my job I fly every few days, which translates to a couple hundred thousand miles per year. Getting on an airplane has become as routine for me as getting in my car and driving to the office. I don’t even think about it and certainly don’t worry about it. I often couldn’t tell you if a flight was turbulent or not frankly because it’s so commonplace that you become desensitized to a degree. Obviously a big part of going from a worrier to where I am now was simply a function of repetition but I will say that I can pintpoint the moment when my whole mindset shifted. It was after my first two week stretch of insane travel. Every single day for two weeks I was on a plane to a different city come evening. It became part of my daily routine. But the lightbulb went on for me when I realized that even though those 14 flights seemed like an insane amount of flights to me, at any busy airport there might be 14 planes pushing back from the gate to start a journey every few minutes. Multiply that over the course of a day and then multiply that across hundreds of major airports and those numbers get very big, very fast. Then take those huge numbers and do it again the next day, and the day after and so on. With all those thousands upon thousands of flights worldwide you nary hear about a major incident. I felt like I was being extremely arrogant to think something major would happen to a flight I’m on. That’s when everything shifted for me - and my takeaway for you is that sure, a good chunk of back to back flying helped, but it was a mental shift in my thinking that made the difference.
So, those planes you’re going to be flying on in a couple months? Odds are they are in the air at this very moment, and if not this very moment they will be within minutes or hours. And each one of those planes will complete up to a hundred and maybe more flights before it’s their turn to pick you up. I’d be more concerned about the 50-100 slobs sitting in your seat before you and what germs they leave behind!
Try to have fun and remember that somewhere on your flight is a jaded business traveller like me who used to worry about the flight but is now more concerned about getting the whole can of soda from the flight attendant.
Also worth noting: in my 100+ flights per year, every few years I’ll notice something I haven’t heard before - a noise, a vibration, etc - and I always come to this forum and ask about it. Without fail I get an answer about what it was within an hour, sometimes minutes. And without fail, even though it’s something I rarely encounter, it’s something that happens on 100s of flights per day, every day.
Pretty cool stuff.
747Whale wrote:I've been flying for nearly four decades, much of it professionally. I've certainly experienced severe and extreme turbulence, but invariably it's been doing something other than passenger flying. Most of it has been flying close to mountains during firefighting operations, something that you won't experience as a paying passenger. In airline operations, while turbulence is part of flying, it's nearly always light to occasionally moderate. Airlines work hard to avoid turbulence. We make turbulence reports to air traffic control, change altitudes to avoid it or minimize it, and receive regular ride reports. Flights are planned to avoid it, minimize it, or minimize the time exposed to it. It's rare that you can't have a glass of water or soda on your tray table; you might see a ripple in the water, but very, very seldom any more than that.
akb88 wrote:747Whale wrote:I've been flying for nearly four decades, much of it professionally. I've certainly experienced severe and extreme turbulence, but invariably it's been doing something other than passenger flying. Most of it has been flying close to mountains during firefighting operations, something that you won't experience as a paying passenger. In airline operations, while turbulence is part of flying, it's nearly always light to occasionally moderate. Airlines work hard to avoid turbulence. We make turbulence reports to air traffic control, change altitudes to avoid it or minimize it, and receive regular ride reports. Flights are planned to avoid it, minimize it, or minimize the time exposed to it. It's rare that you can't have a glass of water or soda on your tray table; you might see a ripple in the water, but very, very seldom any more than that.
Good to know. I'm trying to tune my brain to expect bumps but not maybe the ones that throw me out of the seat make people scream. I've never had it happen during all my flights which have been quite a lot over the years even after I got this silly fear. On this trip the only major mountainous area would be the Alps
pikachu wrote:akb88 wrote:747Whale wrote:I've been flying for nearly four decades, much of it professionally. I've certainly experienced severe and extreme turbulence, but invariably it's been doing something other than passenger flying. Most of it has been flying close to mountains during firefighting operations, something that you won't experience as a paying passenger. In airline operations, while turbulence is part of flying, it's nearly always light to occasionally moderate. Airlines work hard to avoid turbulence. We make turbulence reports to air traffic control, change altitudes to avoid it or minimize it, and receive regular ride reports. Flights are planned to avoid it, minimize it, or minimize the time exposed to it. It's rare that you can't have a glass of water or soda on your tray table; you might see a ripple in the water, but very, very seldom any more than that.
Man up?
Put your big girl panties on?
See a therapist?
See a mental health professional?
akb88 wrote:Hopefully Norwegian also have a decent work ethic, their planes do jump around Europe quite a bit but since I'm flying from their base at Gardermoen I expect the plane to have been inspected by someone there.
mxaxai wrote:akb88 wrote:Hopefully Norwegian also have a decent work ethic, their planes do jump around Europe quite a bit but since I'm flying from their base at Gardermoen I expect the plane to have been inspected by someone there.
It might comfort you to know that much of Norwegian's maintenance is done by Lufthansa Technik, who have a good record. https://www.mro-network.com/maintenance ... ir-shuttle
One other thing to remember:
What do LCC's love? Making money.
How much money does a broken plane earn? None. But it still incurs some fixed costs, regardless if it flies or not. Since you never know what the next failure might look like, potentially making the plane unairworthy and leading to flight cancellations or delays, they have to ensure that issues are found before they can have an operational impact. And that means regular inspections and replacement of parts before they reach the end of their lifespan.
Norwegian learned this the hard way with their early 787 when maintenance issues and a tight schedule forced them to cancel numerous flights. They had to charter expensive substitutes and got lots of bad press. After that, they made a few changes: Have maintenance facilties at the aircraft base, increase part stocks, shorten delivery times of parts, etc. The cost of doing it cheaply was just too high.
akb88 wrote:
Interesting point and indeed helpful. I just need to get over this fear of turbulence or bad weather taking down the plane or being in that less than 1% of people that perish in a crash. But it's all mostly anticipatory anxiety for me.
Working on it.
strfyr51 wrote:akb88 wrote:So are all my worries unfounded then? Do I need to worry about poor maintenance in let's say Norwegian airplane. Surely it must be the case that if there is even a slight hint of doubt regarding the planes airworthiness that it's pulled from service. No matter what airline or country it comes from.
Pretty much all of them. I'm a professional Airline mechanic. I came up through United ranks as a Mechanic, Inspector, Foreman and a Maintenance controller. NO knowing Mechanic would put His/Her Name on an airplane that wasn't up to snuff. We as controllers accomplished Fleet Reviews every night looking for Chronic /Repeat problems and Faults where we were required to issue directives to have the problem fixed or just Ground the airplane to Have it fixed.
The Company mandated that and even is we found problems we did it not because the company wanted it but because we did NOT want the FAA to find it as they could look into our Maintenance records Just like WE looked at them. (they had the same computer at their ADCO as I had on my work station) I once got a call from an FAA Inspector after having grounded an airplane wondering why I was being so Hard on a problem, I spent 15 minutes explaining my reasoning and what I felt was related TO the problem on my A319. The next day? She came into the office to get me to show her why I made the determination before she opened an investigation on my butt.
I found out later she talked to guys at Northwest and USAir about my determination. Then? When I proved my theory via schematics, and Fault Analysis? She went back and told those same guys what I found and they then Verified my findings. I was Hopping MAD after I found it out too! But? What Exactly was I or could I have done about it? NADA! Zip, Zilch! I was later glad she did it as I never had her down on me again because she was a Pain in the Butt!
stratclub wrote:Seriously. Fear of flying is just one of those irrational mental components of some people. Just the way it is. Usually, nothing you can say on a rational level will help them overcome it. I sincerely hope that the OP can figure out how to deal with his irrational phobia in a way that works for him/her.
dangle wrote:....
Thanks. My experience is that the men and women who maintain and fly the aircraft we passengers depend on are more honorable than the 'fancier' individuals that manage and regulate the airlines.
An anecdote: While waiting at the gate for our AA 777 to be repaired in ORD for a flight to ?LHR or China, I can't remember, an obviously upper middle class passenger loudly interrogated the mechanic who was working to bring the aircraft to flight readiness with a rather unfriendly "When are we going to take off?" To which the greater gentleman replied calmly: "As soon as I'd let my family fly on this plane."
jakubz wrote:dangle wrote:....
A).... Talk about broad strokes....
B).... What does "obviously upper middle class" even mean? To me it seems like it was a non-aviation person not understanding the significance of proper airline maintenance.
C).... What does a "passenger loudly interrogated the mechanic" have to do with "the 'fancier' individuals that manage and regulate the airlines"?
dangle wrote:jakubz wrote:dangle wrote:....
You're right, that was unfair of me to say and off topic. I overreacted in sympathy with strfyr51's experience.
I should have just let my anecdote speak for itself in an attempt to help the OP have something comforting to distract themselves when their thoughts are dwelling on fear of flying.
dangle wrote:. I'm guessing the other guy shut up very quickly after that."As soon as I'd let my family fly on this plane."
akb88 wrote:stratclub wrote:Seriously. Fear of flying is just one of those irrational mental components of some people. Just the way it is. Usually, nothing you can say on a rational level will help them overcome it. I sincerely hope that the OP can figure out how to deal with his irrational phobia in a way that works for him/her.
Precisely what I'm trying to do. I'm working on altering my brain to focus on other things during flights. I never used to be like this, I'm 30 and I've been flying since I was 1 and I honestly don't remember any sort of? Have been all over the world with heir turbulence until just recently. Probably cause I never really noticed it that much or was bothered and I always was and still AM an airplane and aviation enthusiast! Weird thing is that a lot of the people I've talked to with the same fear are the same!
This didn't start with me until my mid 20s when it started after my dad got Alzheimer's which put a lot of responsibility on me, this is similar to when people with newborns get this fear. After he passed a lot of my anxieties went away but this one still lingers.
Fair enough. I do like the response ofdangle wrote:. I'm guessing the other guy shut up very quickly after that."As soon as I'd let my family fly on this plane."
