anthonycII
ILS Categories US Major Airports
Tue Feb 12, 2019 11:50 am
I'm curious as to why some major US airports, such as MIA, only have ILS Cat I runways? Is it not worth the cost based on the low percentage of weather occurrences that would warrant an ILS IIIb approach?
sixtyseven
Re: ILS Categories US Major Airports
Tue Feb 12, 2019 1:33 pm
Obviously not. Lots of overhead, infrastructure, and upkeep.
Why bother when the weather is benign all the time. I live in Canada and the sheer number of airports in the US with CAT II/III ILS is enough to make us drool. There was a point not too long ago you could count the number of CAT III approaches in the COUNTRY on one hand. And you could be missing a couple fingers.
Now you can look at say Halifax, Canada and wonder why in the hell a place with such horrendous weather would not have at least a CAT 1 ILS strung to every runway there. Which they don’t.
If a major US airport is lacking CAT II/III, then I would seriously think there just is t any need for it. That any weather situation would be very rare and short lived.
Stand-by for new ATIS message......
AirKevin
Tue Feb 12, 2019 1:39 pm
I'm going to go ahead and guess probably not. I would think the certification requirements are more stringent for CAT IIIB than it would be for CAT I.
Captain Kevin
flyingturtle
Tue Feb 12, 2019 1:48 pm
CAT III ILS was pushed in Great Britain and in mainland Europe, because of the frequent fog.
When British Airways replaced their Tridents with Boeing 757, they went for a plane with a worse ILS capability. For a long time, CAT III ILS wasn't a usual feature of US-built airliners.
David
Reading accident reports is what calms me down
Tan Flyr
Tue Feb 12, 2019 1:53 pm
This web-site has a good list
https://sites.google.com/site/ilsapproaches/Home/cat3
Even some particularly seasonally foul weather airports have a CAT III approach. FAT is one due to our winter Tule fog.
Tan Flyr
Tue Feb 12, 2019 1:54 pm
DiamondFlyer
Tue Feb 12, 2019 2:45 pm
A large number of aircraft in the US aren’t CAT III capable. Heck, some of the regionals aren’t even CAT II certified
From my cold, dead hands
bhill
Tue Feb 12, 2019 8:10 pm
With the recent snow in Seattle this has me wondering...is there a standard for distance from CAT III to non CAT III? Or do you just enjoy a ground stop till the weather is better?
Carpe Pices
MO11
Tue Feb 12, 2019 9:16 pm
Not sure what the question is...technically you're not allowed to depart if your destination is below minimums.
LH707330
Tue Feb 12, 2019 9:51 pm
Seattle is messed up because there's not enough infrastructure to handle snow because it doesn't snow here often. The poor visibility was one factor, but the shortage of deiciers, snowplows, and other such equipment played a bigger role.
arcticcruiser
Tue Feb 12, 2019 11:28 pm
About half my flying is and has been to the US and Canada and has been for decades. The rest is mostly Europe. Been flying Cat.II and III since late eighties, early nineties. I have never done a Cat.II/III in the US/CAN but whole weeks of nothing but those in continental Europe.
Different climates.
FlyHossD
Wed Feb 13, 2019 4:06 am
Different climates.
You've had better luck in the US than I ever had. I recall one period where I flew 5 CATIIIs in the US in the span of 6 weeks (CLE and IAH). I've also flown actual CATIIIs at DEN, EWR, LAX and SEA (there may be another one or two).
N47
Fri Feb 15, 2019 12:04 pm
Fun fact about CAT II/III ILS's: due to the lower minimums and the safety involved CAT II/III systems have more stringent flight inspection tolerances meaning the CDI has to be centered about the centerline (or glidepath for GS) tighter than CAT I systems. When the A380 came onto the scene, because of the huge vertical stabilizer the LOC radiation would interact with the tail and cause oscillations of the LOC CDI (i've heard it referred to as the CDI windshield wipers) of aircraft landing behind it, usually this was most prevalent when the A380 is vacating the runway or when they are holding short of the runway as the angles of the radiation are just right to produce this interference effects. Due to the A380 traffic in Frankfurt they actually developed specific hold short lines when operating under CAT II/III (search up FRA in google earth), which is interesting because other airports that have high A380 traffic dont have these hold short lines (or not that i know of anyway).
jetblueguy22
Fri Feb 15, 2019 2:19 pm
ILS holdlines aren’t new, nor specific to the A380.
Look at sweatpants guy. This is a 90 million dollar aircraft, not a Tallahassee strip club
FlyHossD
Fri Feb 15, 2019 5:01 pm
On a CATIII to IAH and behind a Fedex MD-11 (IIRC) that was exiting the runway, we received such distortion of the localizer that we had to fly a missed approach. In other words, aircraft other than an A380 can cause such interference.
CosmicCruiser
Fri Feb 15, 2019 6:31 pm
I'm surprised they had you that close to the MD.
FlyHossD
Fri Feb 15, 2019 7:44 pm
That's a good point, but we were initially greater than 5 miles behind the FDX MD-11. However, I suspect they slowed on the runway and rolled to the end or nearly so and that's why or how it fell apart.
N47
Fri Feb 15, 2019 8:27 pm
Being further down the runway would mean they were closer to the LOC and more potential to interfere. Plus the engine of MD-11 is long and perfectly aligned with the horizontal polarization of the LOC. The amount of antenna elements also determines the quality of the LOC signal. 8 and 14 element LOCs are the most common in the US (all LOCs at IAH are so) with some airports having/getting 20 elements LOC. The fewer the elements the wider the beam more prone to interference, opposite is true for more elements. From what I've seen 8-element arrays are only used for CAT I. Challenging sites (lot of hangars terminal buildings etc) tend to have 20, in Europe they have even more than 20 (i counted 32 elements at LHR RWYs). There was a recent case in Chicago where it is suspected that LOC deviations might have played a role: (https://aviation-safety.net/wikibase/wiki.php?id=212473, and https://www.youtube.com/watch?v=yYiSrTUyXbo&feature=youtu.be).
CosmicCruiser
Fri Feb 15, 2019 10:32 pm
If it was CATIII I'm sure they were not going to expedite any turn offs. So they did take it easy on the exit.
N1120A
Thu Apr 25, 2019 7:25 am
David
Where do you get this impression? MD80s can autoland to CATIIIA minimums (and CATIIIB if they have a HUD). Of course the 757 and 767 can. In fact, they had a highly advanced autoland system installed from the start - which was developed specifically for those aircraft.
TOGA10
Thu Apr 25, 2019 8:21 am
Something similar happens in LGW, if you happen to be vectored behind the EK A380 you have to fly the RNAV approach instead of the ILS.
Go Max! #33
BoeingGuy
Thu Apr 25, 2019 8:07 pm
Every current Boeing airplane is Cat 3B autoland capable as a baseline feature, including the 757. The exception is the 737 in which Cat 3B capability is available, but optional.
BravoOne
Thu Apr 25, 2019 8:27 pm
The airpanes are capable but the crews are not, mostly due to the operators unwillingness to spend the $$ for initial Low Viz training and subsequent recurrent. If the airports they frequent don't generate those Lo Viz days enough on an annual basis, they take a pass. It wasn't that long ago that SWA didn't do CAT lll landings.
Yikes!
Sun Apr 28, 2019 3:53 am
FIVE STAR ANSWER! A few years ago, Saint John (CYSJ) was planning a multi-million dollar upgrade to its terminal building. I wrote a letter to the local newspaper which resulted in the upgrade being cancelled due to lack of runway infrastructure. If any single airport in Canada needs a Cat II/III runway, it's CYSJ. That letter was written over 10 years ago. Still no Cat II let alone III ILS.
Welcome to Canada...
Users browsing this forum: Avianca, mxguy and 21 guests
