battlegroup62 wrote:Well he's not wrong, but obviously you were hoping for more than that. The enhanced winglet is one step closer to the blended wingtip like say on the 787 and on the E2's. With all the aerodynamic studies that have been done to study wingtip vortices, drag ... we went from no winglets, to multiple designs, and now we are going to blended wingtips. The advances in material science and testing methods have allowed us to continue to lower the drag and vortices which increases efficiency. For instance just changing from the standard to enhanced winglet on an e175 nets about 5% less fuel burn. This is due to how the drag and vortices are dealt with and the increased lift of the winglet. As for weight they are maybe 5-10 pounds heavier than the standard, but planes that have them have other changes as well that save weight.
VC10er wrote:battlegroup62 wrote:Well he's not wrong, but obviously you were hoping for more than that. The enhanced winglet is one step closer to the blended wingtip like say on the 787 and on the E2's. With all the aerodynamic studies that have been done to study wingtip vortices, drag ... we went from no winglets, to multiple designs, and now we are going to blended wingtips. The advances in material science and testing methods have allowed us to continue to lower the drag and vortices which increases efficiency. For instance just changing from the standard to enhanced winglet on an e175 nets about 5% less fuel burn. This is due to how the drag and vortices are dealt with and the increased lift of the winglet. As for weight they are maybe 5-10 pounds heavier than the standard, but planes that have them have other changes as well that save weight.
No, the pilot was not wrong by saying a different design is a different design! I just thought it was a bit of a brush off or because he actually hiding the fact that he didn’t know. Actually, I left out a part. After I my first response about what seemed like a dismissive remark and said “obviously” I said “well, aside from just being a different design, does the new winglet perhaps add more lift as it does, in a way, make the wing longer, a bit like a raked wingtip similar to a 777-300 or 764?” and his answer was slightly snide again and said “sounds about right, go with that one!”
Thank you for your response! Making more of a comparison to the softer blend of the 787, (maybe even the A350?) seems logical.
While nothing about the design of an aircraft is done for aesthetic reasons and only aero-dynamics, I personally find winglets as an improvement aesthetically, even a 767 or 767, and especially so on the 787, 748 and A350.
The last question I have about winglet design: really, does the extended sharp point added to a “simitar” (sort of the BatPlane look) look make that much of a difference? If so, how vs the previous simple ones? (I seem to see them only on 737’s as well). Again, Thanks
mcdu wrote:VC10er wrote:battlegroup62 wrote:Well he's not wrong, but obviously you were hoping for more than that. The enhanced winglet is one step closer to the blended wingtip like say on the 787 and on the E2's. With all the aerodynamic studies that have been done to study wingtip vortices, drag ... we went from no winglets, to multiple designs, and now we are going to blended wingtips. The advances in material science and testing methods have allowed us to continue to lower the drag and vortices which increases efficiency. For instance just changing from the standard to enhanced winglet on an e175 nets about 5% less fuel burn. This is due to how the drag and vortices are dealt with and the increased lift of the winglet. As for weight they are maybe 5-10 pounds heavier than the standard, but planes that have them have other changes as well that save weight.
Apologies for the dismissive nature of that pilot. But unfortunately there is a lot of that in the RJ cockpits. He was probably to busy planning his "meow" voice over the guard frequency. The level of professionalism is sinking rapidly in cockpits with the new generation of pilots that do not accept the responsibility that goes with this job is a dedication to the profession.
e38 wrote:Quoting stratclub (Reply #9), " It was your introduction."
I think it all depends on the personality of the individual.
Actually, if someone were to come up to me and say, " I’m a real aviation enthusiast and have a small question...", my eyes would light up a little bit because it's rare to have a passenger actually interested enough in aviation to come up and ask a question, then I would invite them into the flight deck and ask them if they would like to have a seat in one of the pilot seats to have a look around. Personally, I think it's great when somebody is interested enough in what we do (pilots) to come up to the flight deck and introduce themselves. It just doesn't happen very often.
Everyone is different; however.
e38
Flyer732 wrote:I've been on the 170/175 for three years and counting, sitting on about 2000 hours on type. The 170 is lighter and slightly smaller, the winglets help with fuel burn. The 175 with the enhanced winglets adds roughly 10 feet to the wingspan, and increases lift, and decreases fuel burn. As was stated above the 175 has about 3000 more weight to it as well. As far as why, the enhanced winglet is just a newer design that wasn't examined for whatever reason on the 170 variant.
The largest difference for the crews is during ground maneuvering and landing. I find the 170 significantly easier to land than the 175, due to the smaller wing area. The 170 will also climb faster to higher altitudes, but that is mainly due to the lower weight.
LH707330 wrote:Flyer732 wrote:I've been on the 170/175 for three years and counting, sitting on about 2000 hours on type. The 170 is lighter and slightly smaller, the winglets help with fuel burn. The 175 with the enhanced winglets adds roughly 10 feet to the wingspan, and increases lift, and decreases fuel burn. As was stated above the 175 has about 3000 more weight to it as well. As far as why, the enhanced winglet is just a newer design that wasn't examined for whatever reason on the 170 variant.
My guess is that the cert costs for the 170 versus the units they could sell didn't make the business case work. Regarding why they did the first version upright and then the diagonal one, my guess is that v1 was more optimized for gate spacing, and when airlines sent them on longer routes, they wanted the efficiency benefits.
VC10er wrote:Actually I don’t understand why the general population is not more intellectually curious about flying? I don’t think they need to be enthusiasts, but somewhere after the launch of the 747, and after the 767 etc...I presume the miracle of flight is just taken for granted. Today it’s only about price and complaints, and I totally understand how that happened.
But to see a 787 or 747 or A380 take off so effortlessly is a miracle to me every time. And it’s not that it does it once. The fact that any 747 or 767 or A340 I see has been taking off and flying hundreds of people miles over the Earth, lands many thousands of miles away, then comes back (over and over) is the true miracle beyond the wind foil.
When I see a United 772 at Newark, parked at a gate and think “that enormous metal machine has been to a hundred cites, around the world hundreds of times” it just awes me.
But, I do realize that as a child in the 1960’s with my parents and grandparents- I was only really 1 generation away from people who only had ocean liners to visit relatives in the “Old Country”- I was far closer to the advent of regularly scheduled flights to London or Hong Kong.
About 10 years ago or more perhaps, I remember watching Tom Brokaw reporting on the accidental finding of a time capsule buried by nuns at a convent in the 1850’s. Among the letters etc, one nun asked:
“Are there flying machines?” And my whole body got goosebumps!
So, I personally think it’s incumbent on the airlines to explain and celebrate flying and in lay terms in the on board magazine. How lift is created, why wing length or engine power is needed at hot and high airports.
United’s “Big Metal Bird” is a good start, but the dwindling Ch 9 sucks! Perhaps a video option about the plane you’re on “Learn about this 787-9” etc etc would be AWESOME.
VC10er wrote:No, the pilot was not wrong by saying a different design is a different design! I just thought it was a bit of a brush off or because he actually hiding the fact that he didn’t know. Actually, I left out a part. After I my first response about what seemed like a dismissive remark and said “obviously” I said “well, aside from just being a different design, does the new winglet perhaps add more lift as it does, in a way, make the wing longer, a bit like a raked wingtip similar to a 777-300 or 764?” and his answer was slightly snide again and said “sounds about right, go with that one!”
B6JFKH81 wrote:VC10er wrote:Actually I don’t understand why the general population is not more intellectually curious about flying? I don’t think they need to be enthusiasts, but somewhere after the launch of the 747, and after the 767 etc...I presume the miracle of flight is just taken for granted. Today it’s only about price and complaints, and I totally understand how that happened.
As someone in the industry, especially the technical side, I can tell you how easy it is to fall into the entire "pushing tin" and "just focus on my job" thing. But I, like you, appreciate many more aspects of the collective industry. When I have a plane come into a heavy check, I always go out to greet it and cannot help but to think that in all those hours and cycles, all the cities it has flown to, all the customers it has carried to those destinations.
And when one leaves me? I know how hard I worked, the 18 hour days to meet it's ETR, 2am wake-ups with problems, you bet I'm out there to wave to the pilots as they taxi out for departure, and I am out there on the ramp until the wheels are in the wells. I can only imagine the adventures the aircraft will have once it gets home and back into the operation. I appreciate all I do to make a safe and well-maintained aircraft for my crew and customers, and I take pride in it. I, like you, think it is a miracle every time one of these machines (from a C172 to an A388) takes to the sky.
Don't stop asking questions, and if you experience any answer like you did, just know that some folks in our industry sometimes lose sight of the passion that got us into this industry to begin with, but is still alive in people like you and I.
