IAmGaroott wrote:I’ve heard from US Airways/American maintenance personnel that the E190s always seem to be broken and I’ve read on here similar accounts from B6. I assume this is the reason (among others) the E190 is on its way out of both fleets.
However, the E175 seems to be one of the most desirable jets among regional carriers, currently.
Is the E175 more reliable than the E190? If so, what differences cause this? Is it just because regional carriers have lower utilization than mainline carriers?
Waterbomber2 wrote:There is no difference, the Ejets all have a bad reputation in the maintenance department.
The only difference is in perception. The regional airlines deal with it like it's business as usual, mainline carriers with fleets of reliable mainline jets get to compare and become frustrated because the little ones need so much more care and take up hangar space.
EMBSPBR wrote:Waterbomber2 wrote:There is no difference, the Ejets all have a bad reputation in the maintenance department.
Do you have the numbers or your afirmation is based just your personnal perception?
Cause I got the numbers and they are very good and realiable !!!
smallmj wrote:Air Canada is in the process of dumping their relatively young E190 fleet. They are keeping their E175's.
PlanesNTrains wrote:Can you share the numbers? That’d help put the topic to rest.
PlanesNTrains wrote:EMBSPBR wrote:Waterbomber2 wrote:There is no difference, the Ejets all have a bad reputation in the maintenance department.
buzzard302 wrote:Don't know the answer to your question, but I have a friend that works or B6. His comments are that the E190's have constant issues. Especially in the electronics. Reboot, reset, re-program, etc. etc.
KentB27 wrote:buzzard302 wrote:Don't know the answer to your question, but I have a friend that works or B6. His comments are that the E190's have constant issues. Especially in the electronics. Reboot, reset, re-program, etc. etc.
I've heard that's an Embraer issue in general. The E135/145 is affectionately nicknamed "the Windows 98 plane" because the pilots supposedly spend more time rebooting it and waiting for things to load up than they do flying it.
Crosswind wrote:I’m speaking now as a pilot with 1000+ hrs on the 134/145 series and 2000+ hrs on the 170/190 series. There are no particular issues with these aircraft.
The 135/145 in 2 years I had no significant issues. Never had a flight cancelled due tech. Occasional electrical reset required.
The 170/190 are quite different to each other. Different engines. Different wing. Different Horizontal stab. Different Landing Gear.
This is a far more electronic aircraft than its predecessors. Still, it’s very reliable. The occasional electronic issue happens, normally a full de-power, re-power on stand will fix it, resulting in an on time departure. There is best-practice that avoids most of the nuisance warnings that I assume experienced operators follow. Again, don’t recall any tech cancellations.
Having flown the E170/190 series for 4+ years I’m puzzled where the unreliability claims come from. In Europe Air France, Alitalia, Austrian, BA, KLM, LOT and Lufthansa have all built significant fleets of these aircraft in the last 10 years.
I seem to recall parallels with AA claiming the A300 was unreliable. Where Lufthansa operated the type without complaint over a much longer period. Somemtimes it comes down to your companies pilots/engineers total experience with a particular type that can have an impact on reliability.
I’d say in general, serious tech on any type, affects all types. The minor tech issues (reset etc) will have their impact determined by the people on the ground and their experience on type.
If a type represents a small proportion of your overall fleet, although you will have engineers trained on type, if they spend most of their time working other types, when they have issues they may not have the detailed experience dedicated engineers may have. The engineers I work with don’t deal with any other aircraft types. As such, any issues are dealt with pretty quickly. The occaisonal tech delay is most often related to passenger convenience items (armrests/recline/toilets etc) rather than anything fundamental with the aircraft.
CROSSWIND
CROSSWIND
EMBSPBR wrote:Numbers (I like numbers):
For E1 E170 / E175: 99.8%
For E1 E190 / E195: 99.4%
For E2 E190: 99.9%
From time to time a comment like "I've heard of ..." appears without actually providing any basis or source. The numbers they want are there to show and they are very different from what they say.
lowfareair wrote:EMBSPBR wrote:Numbers (I like numbers):
For E2 E190: 99.9%
Your numbers show that the E190 is 3 times more unreliable than the E175 - 0.6% vs 0.2%.
UPNYGuy wrote:buzzard302 wrote:Don't know the answer to your question, but I have a friend that works or B6. His comments are that the E190's have constant issues. Especially in the electronics. Reboot, reset, re-program, etc. etc.
I know a couple B6 FAs that are on the 190. They refer to it as the E-180 due to the numerous software glitches. This nickname has also spread to other carriers. I have heard it used at AA and AC as well.
For E2 E190: 99.9%
EMBSPBR wrote:UPNYGuy wrote:buzzard302 wrote:Don't know the answer to your question, but I have a friend that works or B6. His comments are that the E190's have constant issues. Especially in the electronics. Reboot, reset, re-program, etc. etc.
Numbers ???
People here like numbers, as me ...
Numbers ???
WayexTDI wrote:From a Tech Support point of view (as an OEM Tier-1 or Tier-2 supplier), the E170/190 series have been much more demanding than 737/A320: with an E170/190 fleet much smaller, the volume of request was almost similar, which says a lot.
As you said, maybe it was the airlines Maintenance Department that was lacking; Embraer wasn't helpful for neither the Operator nor the OEM's, always trying to be the "mailbox" adding nothing but time and frustration on both sides.
As far as AA and the A300-600: AA claimed reliability issues as they did not fully use the auto-test function of some of the systems (which Airbus clearly indicated in their troubleshooting manuals), on top of modifying some of the systems, yet blaming the OEM for reliability issues (even after said OEM warned against those mods). It might not be for all the systems, but I know it didn't help.
Numbers ???
Hell, all you have to do is search for e180 in HERE to verify that...
EMBSPBR wrote:WayexTDI wrote:From a Tech Support point of view (as an OEM Tier-1 or Tier-2 supplier), the E170/190 series have been much more demanding than 737/A320: with an E170/190 fleet much smaller, the volume of request was almost similar, which says a lot.
What you say to a certain extent attests to what the member "Crosswind" (reply #17) claims and this tends to be more subtle (or not) from an airline to another.
EMBSPBR wrote:If a type represents a small proportion of your overall fleet, although you will have engineers trained on type, if they spend most of their time working other types, when they have issues they may not have the detailed experience dedicated engineers may have.
EMBSPBR wrote:Numbers ???
lowfareair wrote:Your numbers show that the E190 is 3 times more unreliable than the E175 - 0.6% vs 0.2%
lightsaber wrote:Numbers are good. Expected is 99.7%. But maintenance costs are high. JetBlue has complained forever:
http://m.aviationweek.com/commercial-av ... -190-costs
Azul is replacing theirs by 2021 (fast turnover):
https://www.airliners.net/forum/viewtopic.php?t=1403409
AC within 18 months (accelerated retirement):
https://airlinegeeks.com/2018/02/22/air ... 190-fleet/
JetBlue is starting replacement in 2020, pretty fast too, 4 years (gone by YE 2024):
https://www.seattletimes.com/business/j ... -a220-jet/
With AA, AC, B6, and Azul replacing the E-190/195, 158 examples are hitting the market fast of 697 active. There were 764 delivered, why so many (67) of a young fleet inactive?
https://www.airfleets.net/exploit/production-e190.htm
I am impressed by the E2-190. The performance has been spectacular. Sad so few orders.
The need for economy of scale has increased. I hope many more are sold.
Lightsaber
Late edit. Unfortunately the E-190 is going to suffer the same fate as the A319. With the A319, when easyJet and Cebu Pacific (#1 and iirc #2 operator) announced phase out, resale prices dropped. We now have the #1 and #2 of the E-190/195 phasing out the type (plus AC and AA). That has spooked the second hand market.
CROSSWIND
WayexTDI wrote:And experience has shown you can make those numbers say whatever you want. As lowfareair pointed out, per your own numbers:lowfareair wrote:Your numbers show that the E190 is 3 times more unreliable than the E175 - 0.6% vs 0.2%
EMBSPBR wrote:WayexTDI wrote:And experience has shown you can make those numbers say whatever you want. As lowfareair pointed out, per your own numbers:lowfareair wrote:Your numbers show that the E190 is 3 times more unreliable than the E175 - 0.6% vs 0.2%
The same proportion would be if the figures were only 0.4% to 0.8% ...
But they are not ... check it out!
EMBSPBR wrote:lightsaber wrote:Numbers are good. Expected is 99.7%. But maintenance costs are high. JetBlue has complained forever:
Lightsaber
I understand your point of view.
But if we look at the date these models were produced - from 2006 to 2009 - many of them will have reached around 15 to 17 years for example. And, in many cases, these airplanes are used in a turnover up to 8 hours per day.
Cost of maintenance: yes, that says it all, in particular the GE engines used in the fleet of the E190 / 195 E1 ...
EMBSPBR wrote:
From these produced, they are proudly stamped, to name a few, in the colors of Air France, Alitalia, Air Canada, American Airlines, Aeroméxico, Blue, Austrian, British Airways, Delta, Finnair, JAL, JetBlue (yes!!!), KLM, LOT, Lufthansa, TAP Air Portugal, United, again, among others ...
And that makes me very proud of the work and effort made so far and it does not matter with the usual "I've heard ..." sometimes it seems to annoy me !!!
