PerVG wrote:Not very likely, IMHO.
What would be the point of it, anyway? They already have the record, with the "bragging rights" that come with it. And that record came from normal testing, not from any intentional "record run".
As for the GE9X, it targets a lo"wer thrust point than the GE90, at least for now. I don't see it breaking any thrust records in testing.
It should break efficiency records, tho, which are far more important.
stratclub wrote:The 747-8 could easily take off at over a million pounds but to the best of my knowledge Boeing never has because MTOW is certified at 875,000 pounds.
Stitch wrote:stratclub wrote:The 747-8 could easily take off at over a million pounds but to the best of my knowledge Boeing never has because MTOW is certified at 875,000 pounds.
Current MTOW for the 747-8 Intercontinental is 975,000 pounds (442,000kg) and for the 747-8 freighter it is 987,000 pounds (448,000kg).
stratclub wrote:The 747-8 could easily take off at over a million pounds but to the best of my knowledge Boeing never has because MTOW is certified at 875,000 pounds. They certainly could easily do it except bragging rights have no place in something as conservative as aviation.
stratclub wrote:Stitch wrote:stratclub wrote:The 747-8 could easily take off at over a million pounds but to the best of my knowledge Boeing never has because MTOW is certified at 875,000 pounds.
Well, I am retired so all I have to go by is crappy old Wikipedia. Do you agree with the intent of my post?
Farsight wrote:Thanks for the replies..
Then how was the 127,000lbs figure achieved during GE90 testing?
The design brief was fixed at 115,000...so why did they exceed it so dramatically? What was the purpose?
Pudelhund wrote:I am not very familiar with engines, so why would you need a GE9X if it carries the 777-9 with less thrust than the GE90 for the 77W? Is it just efficiency and longevity? TOGA power requirements?
LH707330 wrote:I'm pretty sure that both are 987k, whether the operators bought those weights is another question: https://www.flightglobal.com/news/artic ... ts-367030/
Farsight wrote:My question is...how likely is it that GE will attempt to beat the GE90 thrust record any time soon? Could a test GE9X be 'turned up to 11' and put out a few 1000lbs extra...just for bragging rights of course!
Farsight wrote:Then how was the 127,000lbs figure achieved during GE90 testing?
Once the flight envelope etc is defined you just plain old do not intentionally exceed it. Like I said, aviation in reality is a very conservative endeavor. In the jet age, Boeing and if my info is correct Airbus have never lost an aircraft during validation testing. When you consider the extent of testing and the performance modern airliners are capable of, that stat is pretty amazing.
Faro wrote:I severely doubt whether GE will provide a thrust bump option up to that level of thrust, among others because of Mvca / Mvcg considerations
mickrussom wrote:Its very likely. Ted Ingling (GE Aviation’s GE9X program manager ) said the GE9x has unofficially beaten the GE-115B record thrust in cold weather triple red line conditions and stated a new record for the books will be forthcoming.
PerVG wrote:mickrussom wrote:Its very likely. Ted Ingling (GE Aviation’s GE9X program manager ) said the GE9x has unofficially beaten the GE-115B record thrust in cold weather triple red line conditions and stated a new record for the books will be forthcoming.
That means at least 121% of rated thrust.. very impressive. But also seems a bit of wasteful overengineering.
Farsight wrote:Seen a record of 134k on TwitterWell...i can’t wait to see the new record figures, im going with 131,000lbs
mickrussom wrote:Farsight wrote:The GE9X could produce more power than the 115B (its a larger fan diameter GE-115B is 128 inches, the GE9X is 132 in).
Eyad89 wrote:Question is, why?
77X needs less thrust. Was this increase in thrust planned? Or was it more than expected?
426Shadow wrote:
With 3 years on this site and nearly 600 posts i refuse to believe that you haven't heard of triple redline tests.
Every engine flying today can make much more power than the certified numbers. That doesn't mean its good for the engine, so all engines are de-rated.
Stitch wrote:
It is just a by-product of the certification program where it is required to run the engine at maximum fan speed, core speed and exhaust gas temperature so when you do so with this engine, that is the thrust that is generated. It will never come close to those conditions in airline operation so that is why the rated thrust is lower.
Eyad89 wrote:
Two questions here:
1- Did the stator vane fail because it wasn't designed properly?
2- Or was the design all good but inlet temperature was higher than expected?
With the engine producing more thrust than even GE90, I am guessing it's more of the second point.
Note: it's interesting that the 1st stage stator vanes had no problems even though the inlet temperature would be higher.
stratclub wrote:They certainly could easily do it except bragging rights have no place in something as conservative as aviation.
mickrussom wrote:Farsight wrote:Then how was the 127,000lbs figure achieved during GE90 testing?
Triple red line testing of the engine in a test bed with a potentially sacrificial SETT (second engine to test - after certification this will be the reference design).
GE Aviation ran the GE90-115B ran for approximately 60 hours at triple-red-line conditions (maximum fan speed, core speed and exhaust gas temperature) to evaluate the engine at its operational limits and demonstrate its capability beyond the most extreme operating conditions.
stephanwintner wrote:Cold weather, alone, allows for quite a bit more thrust than, for example, a hot day takeoff. I'm not sure what precise values are used for a rating, but keep in mind that the rated thrust is not what the average engine makes. Every single engine in the fleet, worn or not, should be capable of exceeding that value.
kitplane01 wrote:If the engine can clearly produce more than rated thrust .... why is that not allowed during emergencies?
Example: If some particular flight is weight limited because of engine-out concerns, and the engine had an extra bit of thrust just for emergencies, then one could increase weight. (Assuming enough rudder, strong enough pylon, etc.)
I would assume there are some emergencies where an extra 10% of thrust for 5 minutes would make things better/easier. And it's availability would help with some operational restriction.
waly777 wrote:kitplane01 wrote:If the engine can clearly produce more than rated thrust .... why is that not allowed during emergencies?
The 77W has this option with the thrust bump. However this means faster engine wear & tear.
