DominikPirek
A330/350 type rating
Mon Mar 04, 2019 9:28 pm
Good evening,
if this topic had been discussed here before I do apologize, but I was wondering whether companies using a330 (ceo, neo) and a350 - Lufthansa, Emirates...- will be using common type rating for both of them and therefore rotate crews on both types just like on a330/340 types.
Thank you for answer, Dominik
Reason: Typo fixed
johns624
Re: A3330/350 type rating
Mon Mar 04, 2019 9:41 pm
Delta has them separate. I don't know if it's because of separate type ratings or just for pay scales but they are separate groups of pilots.
Mon Mar 04, 2019 11:19 pm
DominikPirek wrote:
Good evening,
At CX we do, I can and have flown the A330-300, A350-900, and A350-1000 on the same day.
The A330/A350 is only a common type rating under EASA, under FAA rules the A330/A350, 777/787 are not common types.
AirKevin
Tue Mar 05, 2019 1:08 am
Now you have me curious, how short are these flights that you can actually do that. I would have thought the A350s would be used on longer flights unless they're still being used for crew familiarization.
Captain Kevin
Tue Mar 05, 2019 1:29 am
CX, CI and others use the A350 on plenty of shorter sectors, e.g. HKG-TPE or HKG-MNL. A pilot could do HKG-TPE-HKG-MNL in one day flying 351, 359 and 330.
The timing of long haul ops means there are large gaps between the long haul peaks, leaving space for regional sectors. In HKG you get this big flock of long haul aircraft landing from Europe in the early morning, and another large flock departing for Europe around midnight. Unless you use the planes for regional work, many would sit idle for 15+ hours. In the same vein, SQ uses the A380 on SIN-HKG-SIN between long haul duties.
HKG-TPE is only about 90 minutes but it is wall to wall widebodies during the day.
Tue Mar 05, 2019 10:33 am
All of our passenger aircraft are used regionally between long haul flying, the A350s would average around 15 hrs in the air every day.
If I recall that day correctly it was BKK-HKG 35K (about 2:20), HKG-TPE 359 (around 1:15), another crew took that aircraft then to Japan and I got on an 333 to do TPE-HKG (around 1:40).
Less than 6 hrs of flying, at work probably around 11 hrs, can be a 2-3 hr wait between sectors.
workhorse
Sat Mar 09, 2019 11:39 am
What about the A320 family? Would it be possible for you to fly an A321, an A330 and an A350 on the same day (if your airline had all of them)? And the A380?
TOGA10
Sat Mar 09, 2019 1:49 pm
I think in EASA-land, you can only hold 2 typeratings at the same time. So, in theory, you could fly the A318-321 (a320 family is 1 typerating), A330 and A350 (common typerating) all in one day. If it's wise, not so sure. I think it would be a bit too easy to mix up certain procedures etc.
Love flying, hate the alarm at 3 in the morning, love watching the sun rise at 5:30. It's all about compromises.
workhorse
Sat Mar 09, 2019 3:21 pm
I think (but not so sure, hence the question) that Swiss pilots used to fly both the A320 and the A330/A340 family (thus effectively covering the whole fleet of their airline).
thepinkmachine
Re: A330/350 type rating
Sat Mar 09, 2019 4:23 pm
You can hold as many as you please, as long as you do the OPC on each type. Now, AFAIK, EASA OPS rules only allow you to operate 2 types at the same time.
"Tell my wife I am trawling Atlantis - and I still have my hands on the wheel…"
Sat Mar 09, 2019 6:20 pm
It is possible, and pilots who work for airbus do fly multiple types. Every type rating needs to remain current, which means regular simulator checks on each type which becomes uneconomical both in terms of time and money for an airline. It would work for a smaller outfit that’s does ad hoc charters, as the pilots normally are not running into maximum hours or days at work and people pay a premium for the aircraft to be available.
glen
Tue Mar 12, 2019 1:15 am
It was either A320 and A330 for some pilots or A330 and A340 for the others, but never all three types.
"The horizon of many people is a circle with zero radius which they call their point of view." - Albert Einstein
workhorse
Tue Mar 12, 2019 5:23 am
Aren't the A330 and the A340 the same type rating?
workhorse
Tue Mar 12, 2019 5:33 am
I guess it depends on what kind of routes they fly, too. If it is an airline that regularly flies 330s on short haul (and thus has flights where a 330 is likely to be substituted to a 321 on short notice due to demand or vice versa) then it makes more sense.
flyinTLow
Tue Mar 12, 2019 6:09 am
You can hold as many as you want, but EASA limits it to 2 and also requires you to perform a minimum number of landings on each type to actually transport passengers with that rating.
They are not. They share big commonalities, but their systems differ a lot due to the number of engines. And ETOPS is also a seperate issue that has to be addressed
- When dreams take flight, follow them -
Tue Mar 12, 2019 7:07 am
A330 and A340 can be held on the same type rating in many jurisdictions. Their systems differ but compared to A330 vs A350, they're practically identical. The A330 and A340 were developed as a single program.
I don't understand the point about ETOPS. Why would it be an issue between A330 and A340?
Tue Mar 12, 2019 8:11 am
This is actually incorrect when it comes to the FBW Airbus types. The rule says you can only fly two types unless credits related to the training, checking, and recent experience requirements are defined. The FBW family has what is known as operational suitability data established by EASA to permit common type ratings, cross crew qualification, and mixed fleet flying.
The operational suitability data defines the recent experience requirements.
flyinTLow
Tue Mar 12, 2019 2:19 pm
Well let me say it like this: I have a EASA license and it says A330/350 and then A340-200/-300/-500/-600.
A340 does not require ETOPS. If anything it requires EROPS.
Users browsing this forum: Florianopolis and 12 guests
