GalaxyFlyer wrote:I’d say at low altitudes, it’s quite possible to fly accurately enough by looking out the windows. I had a couple of references to hold level flight, bank 30* and climb and descend. Its the way I was taught.
That said, identifying a stall and being wrong has some severe penalties, so we are always monitoring speed as sensing speed is hard other than known pitch and power relationships. I could hear the engines but had no idea on actual speed without looking.
GF
AmtMike wrote:I am a private pilot and Aircraft Mechanic. I have worked on several different commercial airline aircraft. Including 737-700 and -800. I don't understand why Boeing thought the 737 Max needed an automatic stall prevention system. Pilots flying this aircraft surely know how to recognize and recover from an impending stall. This is taught in the first 10 hours of flight training. Is there a pilot out there with 1000's of hours that flys a 737 or other airline aircraft that can answer this?
Mike
747Whale wrote:Trim provides a visual indication right next to both pilots as the trim wheels move, and trim indication is displayed.
It's not really a fast process. Less than a third of a degree per second, and it doesn't have far to go.
stratclub wrote:Kind of a lame article. Why could the MCAS system have not been a Master caution and an EICAS message instead of the MCAS system mysteriously auto trimming the plane? Since a pilot was already manually flying the aircraft such a warning and message would have got their immediate attention.
It certainly would have solved the mystery of what the Lion Air plane was doing. Or even if the system was auto trimming, an aural warning and EICAS message would have alerted them to what the aircraft was doing.
Woodreau wrote:
As a result of stall accidents in the last couple years, aircraft manufacturers have been gathering data on the handling characteristics of their aircraft in the stalled regime and simulators are now getting certified with an enhanced flight envelope, covering 4 degrees AOA past stall so that stall training can be done. At least in the US airlines are now doing stall demonstrations and training from full stalls in these simulators with the enhanced flight envelope.
Max Q wrote:What I haven’t seen before is a system that uses the horizontal stabilizer to input a nose down force if approaching a stall
In the past stick pushers provided a nose down input to the elevators, why Boeing designed it this way makes me wonder if their flight test results showed that the elevators lacked the necessary authority in that scenario
Problem is you can’t override the stab with elevators, it is much more powerful
fr8mech wrote:i]
Now, tell me that the pilot can't override if the MCAS is trimming, I'm concerned.
stratclub wrote:That's the problem. MCAS. Even if the pilot could over ride the auto feature of MCAS it will start trimming nose down again if the AOA input to it senses a stall. That is why I suggested a Master Caution and EICAS message when MCAS is auto trimming. Pilot awareness to something the aircraft is automatically doing goes a long was in understand when the aircraft is doing something that could exasperate a stall.
fr8mech wrote:stratclub wrote:That's the problem. MCAS. Even if the pilot could over ride the auto feature of MCAS it will start trimming nose down again if the AOA input to it senses a stall. That is why I suggested a Master Caution and EICAS message when MCAS is auto trimming. Pilot awareness to something the aircraft is automatically doing goes a long was in understand when the aircraft is doing something that could exasperate a stall.
Is the clacking trim wheel gone on the -max? While I don't disagree with you, isn't there already an aural and visual indication of stab movement (trim wheel)?
Starlionblue wrote:I don't know if the clack, but they're definitely still there.
stratclub wrote:I think I can see the stick shakers in the pic. Do they use the same AOA input as MCAS?
pikachu wrote:EICAS? In a 737? Why does anybody waste time here looking for answers from children in high school?
Woodreau wrote:A Cessna 172 when stalled, the nose pitches down and the stall warning indicator sounds. This doesn’t happen in an Airbus 320. When the 320 stalls there is no nose pitch down moment indicating a full stall. It just mushes and starts “falling out of the sky” in a nose level wings level attitude. The aural stall warning is not Mach compensated, so at high altitude (FL350 for example) with the aircraft fully stalled, there is no aural stall warning.
The hard part of stall recognition and recovery training is recognizing that the aircraft is stalled. It becomes harder when you have issues with the flight instruments, i.e. erroneous airspeed indicator, trying to figure out which of the three airspeed indicators in the cockpit is telling you the correct airspeed. Once pilots realize they’re stalled though, pilots are recovering. Delays in recognizing the stall can add to the amount of altitude required to recover from the stall.
It is easier to recognize a stall at low altitudes. It’s quite different at FL350, when your airspeed indicator is not showing anything, the other pilot airspeed indicating an over speed, the standby indicating something normal and the overspeed aural going off in the cockpit, nose +2.5 nose up and wings are level engines at full thrust but the FPA is indicating -15 and VSI pegged full down. Yeah you’re fully stalled.
fr8mech wrote:Max Q wrote:What I haven’t seen before is a system that uses the horizontal stabilizer to input a nose down force if approaching a stall
Aerodynamically, that may be true, but on every Boeing I've worked on (B727/747/757/767, note the conspicuous absence of the B737), an elevator (column) input in the opposite direction will disable the stabilizer trim system. I can't imagine the B737 doesn't have the same set-up.
Each one of the AMM's I looked at has this statement:
The switches employ a pilot's natural reaction to correct a runaway condition.
Max Q wrote:What I haven’t seen before is a system that uses the horizontal stabilizer to input a nose down force if approaching a stall.
Stitch wrote:Max Q wrote:What I haven’t seen before is a system that uses the horizontal stabilizer to input a nose down force if approaching a stall.
I was watching the "Mayday" episode on QF72 last night and the A330/A340's envelope protection has (had?) a high-AOA protection mode which commanded the elevators to pitch the nose down at up to a 10 degree angle. There was an undiscovered issue where the air data inertial reference units could send corrupted data to the flight control computer making the FPC think the aircraft had too high of an angle of attack and trigger the high-AOA protection mode. QF71 ran into the same issue two months later, but their crew was aware of the issue and revised procedures issued by Airbus so they were more easily able to recover.
BoeingGuy wrote:fr8mech wrote:Max Q wrote:What I haven’t seen before is a system that uses the horizontal stabilizer to input a nose down force if approaching a stall
The 737 has the same set up for all other trimming other than MCAS, and that is also being changed with the new MCAS software. An opposite column input on the 737 will stop stab trimming. It will stop MCAS trimming also with the forthcoming design.
pikachu wrote:stratclub wrote:Kind of a lame article. Why could the MCAS system have not been a Master caution and an EICAS message instead of the MCAS system mysteriously auto trimming the plane? Since a pilot was already manually flying the aircraft such a warning and message would have got their immediate attention.
Laughably poor understanding and uneducated opinion.
