And just so I can get my head around the matter a bit more: There was no mentioning of the system in the initial FCOMs to the flight crews? What can you find in the manuals now?
greg85 wrote:I am also a mere Airbus pilot. But I’m led to believe that a key difference is that Boeing’s MCAS system is linked only to the capt AOA. So, a single faulty/frozen AOA vane could cause a nose down input from MCAS. Whereas, on an Airbus the same would have to be a double fault. As many will be aware it did happen to Lufthansa in the A320, they recovered by switching 2 ADRs off. Which is now the recognised procedure.
I expect at some point the argument will need to be raised that a single failure should not lead to such a drastic and confusing situation as what happened to Lion air.
I wonder what will happen next. Lots of money spent on the MAX by large and powerful corporations.
Pluto707 wrote:Maybe my question belongs here: as a simple ppl i understood that MCAS is not operative if: autopilot on/ flaps out/ speed high, but is there any relation with GPWS or is my thinking irelevant ?
flyinTLow wrote:Hey everyone!
As everyone is all over the MCAS System on the 737 MAX now, can anyone give me a detailed technical description to the system, preferably by Boeing?
flyinTLow wrote:There was no mentioning of the system in the initial FCOMs to the flight crews? What can you find in the manuals now?.
zeke wrote:Next to nothing in the pilots manuals, and only a little in the maintenance training.
zeke wrote:flyinTLow wrote:Hey everyone!
Some technical details here, slightly incorrect in that MCAS trims at 2.7 deg per sec where the page says 2.5..
http://www.b737.org.uk/mcas.htm
MCAS can be thought of like a high speed stick pusher, it is designed to work like in a high speed spiral dive outside the normal flight attitudes. Only is activated with flaps up. When activated MCAS trims nose down for 10 seconds, then it trims nose up. If the timer is interrupted by pressing the manual trim switches, the timer resets and starts from zero again. The electric trim moves at 2.5 deg per sec, which means to counter the MCAS trim a pilot would need to trim about 10% longer.
The 737 does have two AOA sensors, each with two resolvers (effectively say the left side generates Left 1, and Left 2, the right side Right 1 and Right 2, these are not Boeing terms, they are just to illustrate what is being generated). So each AOA sensor can feed both sides. MCAS AOA source changes each sector.
MCAS is an autopilot function which works if the autopilot is on or off. When manually flying the MCAS function in the FCC will pitch the stab nose down by commanding the electric stab motors directly. There is no way to isolate MCAS, the “fix” is to turn off the power to the stab motors, with the motors off the MCAS function is still commanding nose down however the motors are not powered.
There is no EICAS or FMA to say the MCAS functionality is active. MCAS can be a single point of failure as the FCCs do not check to see if the active AOA resolver is generating a reasonable AOA. This could be fixed by comparing each AOA resolver AOA against each other and the aircraft performance and voting out bad AOA from the MCAS system input side.flyinTLow wrote:There was no mentioning of the system in the initial FCOMs to the flight crews? What can you find in the manuals now?.
BravoOne wrote:Faults that affect MCAS also affect Speed Trim and are annunciated with the Speed Trim Fail indication on the
flight controls panel.
zeke wrote:flyinTLow wrote:MCAS AOA source changes each sector.
BravoOne wrote:Almost right, but not quite...
Pluto707 wrote:Another one... No fault in MCAS, but for some reason, acft encountered power/climbing problems, was maneuvering at +- 1500 ft agl, some high turn to avoid terrain, AoA, speed...and....MCAS lowered nose, direction ground
zeke wrote:slightly incorrect in that MCAS trims at 2.7 deg per sec where the page says 2.5..
Rexus wrote:zeke wrote:flyinTLow wrote:MCAS AOA source changes each sector.
As far as I understood AoA source depends on the active FCC. There are two independent FCCs installed on the B737 series, one of which is active, the other one is on standby. The active FCC alternates with each flight sector.
Assuming that FCC A reports false AoA values, is there a way to manually deactivate FCC A so that FCC B becomes active? How would pilots do that? Is there a switch to choose between FCC A and FCC B manually?
