GalaxyFlyer wrote:MCAS addresses a aerodynamic problem in the small part of the envelope near stall AOA in clean configuration. It’s not a major problem, only a problem in that small regime. The operational problem that testing didn’t reveal was the case of sole source sensor failing or providing incorrect sensor data to the MCAS. Or, in operation crews are poorly trained in handling these failures.
MCAS is probably a fairly simple elegant solution, it just needed more robust sensor input. In service without the sensor failure(s) it would likely never be encountered by crews. The alternative was likely a stick pusher.
GF
pugman211 wrote:I'm sure once the software update is completed, all will be good with the Max again
tealnz wrote:There’s also now reason to believe there were shortcuts in certification.
stephanwintner wrote:I cannot imagine Boeing deliberately withheld data.
747Whale wrote:tealnz wrote:There’s also now reason to believe there were shortcuts in certification.
That's not "reason to believe." That's an article in popular media. The cited article is misquotes, use out of context, and very misleading, as the original material does not state what the article imports.
Some tend to give credence to anything found in writing, on popular media, in the news, or on TV. Just because someone put it print does not make it so. The use of statements in that article actually say the opposite of what they were written to say by their original source.
GEUltraFan9XGTF wrote:The Boeing <> FAA certification issue aside, the whole MCAS system screams of being sloppy, rushed, half-baked work. Everything mentioned here and elsewhere is design 101.
-MCAS activation should depend on agreement of 2-3 sensors. If there is disagreement, a warning light should appear in the cockpit.
-AOA sensors themselves should be "smart" enough to realize they are reset to "0" on the ground. If not, a warning light should appear in the cockpit.
-MCAS activation should be indicated clearly in the cockpit.
-The fact that there is discrepancy in the degree MCAS activation (.6 vs. 2.0 degrees) screams more sloppy, rushed project management than corporate malfeasance to me. Neither side knew what was going on and both sides (Boeing and FAA) let it all slip. Whether intentionally or not is the question. If so, I think it's criminally negligent.
-Ditto in terms of the system resetting versus constantly working away, exacerbating the problem. Sloppy work. Bad project management and oversight.
A lot of Boeing heads should roll:
-MCAS project manager
-737 MAX project manager
-Boeing CEO
stratclub wrote:GEUltraFan9XGTF wrote:The Boeing <> FAA certification issue aside, the whole MCAS system screams of being sloppy, rushed, half-baked work. Everything mentioned here and elsewhere is design 101.
-Boeing CEO
Could you give it a rest? What we actually know.*Boeing screwed the pooch on this one.
*Boeing is taking full responsibility for this one.
*Boeing will engineer a fix.
*The fix will be reviewed and approved for validation testing by the FAA.
*The fix will be validated by Boeing through testing.
*Once Boeing has final FAA approval all delivered max aircraft will be modified at Boeing expense.
*The fix will be incorporated into production.
I don't think that Boeing or the FAA have a requirement for social media approval............
kalvado wrote:stratclub wrote:GEUltraFan9XGTF wrote:The Boeing <> FAA certification issue aside, the whole MCAS system screams of being sloppy, rushed, half-baked work. Everything mentioned here and elsewhere is design 101.
-Boeing CEO
Outlined above is the very best case scenario.
Social media approval may not be required, but approval by other regulators may be a bit more interesting story. Not to mention that FAA may reject either implementation of the patch as presented or entire idea of software patch.
Worst case scenarios may include a lot of fun things. How about avionics replacement on built frames (a-la Toyota unintended accelerations)? Buyback of frames already sold a-la VW dieselgate?
I don't quite believe in those, but best case scenario is not fully believable as well. Hopefully something in between.
stratclub wrote:What I laid out, it is not a "best case scenario", it is exactly how the system works. Every step of the process has FAA oversight and approval. If the FAA does not approve the fix, then Boeing has to address the FAA's issues before proceeding on to modification and validation testing.
Besides the FAA the NTSB what other government agencies have to sign off on the resolution of this issue? The Dept of the interior or the IRS maybe? Sure Boeing will be eaten alive on liability, but that has nothing to do with the actual resolution of the issue.
stratclub wrote:Well duh. Those countries have their own regulatory agencies. For the most part with some small exceptions most foreign regulatory agencies pretty much mirror what the FAA does. Boeing's fix will have to pass approval with those countries as well.
Everyday Boeing delivers aircraft that meet airworthiness requirements with the regulatory agency where they will be operated. The fix being written to meet FAA requirements will also be written to meet the requirements of the country they are operated in. If the fix meets FAA requirements, most likely other regulatory agencies will review the engineering data and approve it based on the FAA's findings during validation testing etc.
What leniency's are you referring to? Are you implying the FAA might allow a fix that is not airworthy?
I have no clue why you believe that this is some kind of soap opera. In any case the media is famous for trying to sensationalize things, miss quote people and in many cases just plane old get things wrong all with the purpose of increasing circulation.
GalaxyFlyer wrote:Bring back D.P Davies of the U.K. CAA certification branch. He insisted on better yaw stability for the B707 when the FAA didn’t require it and refused the B727-200 which has very similar behavior nearing the stall as the MAX. Listen to his podcasts.
GF
kalvado wrote:stratclub wrote:Well duh. Those countries have their own regulatory agencies. For the most part with some small exceptions most foreign regulatory agencies pretty much mirror what the FAA does. Boeing's fix will have to pass approval with those countries as well.
Following FAA didn't prevent rest of the world from grounding max while it was still flying in US. I suspect at least 2/3 of current fleet will be grounded until EASA gives their OK. Welcome the new trendsetter.
stratclub wrote:GalaxyFlyer wrote:Bring back D.P Davies of the U.K. CAA certification branch. He insisted on better yaw stability for the B707 when the FAA didn’t require it and refused the B727-200 which has very similar behavior nearing the stall as the MAX. Listen to his podcasts.
GF
Yes, the CAA airworthiness requirements are more stringent in some areas than the FAA's requirements. So, what is the point? Boeing has been building aircraft to CAA requirements for decades. Between different regulatory entities there always will be requirements that differ and that is why the fix will be designed to meet CAA's specific requirements as well if Britain has carriers that fly the MAX.
kalvado wrote:stratclub wrote:GalaxyFlyer wrote:Bring back D.P Davies of the U.K. CAA certification branch. He insisted on better yaw stability for the B707 when the FAA didn’t require it and refused the B727-200 which has very similar behavior nearing the stall as the MAX. Listen to his podcasts.
GF
in theory passing EASA certification should be a breeze. In practice, there may be a bit more to handle. For example:
As far as I understand, Boeing rated MCAS problems as serious accidents which would not lead to loss of life for certification purposes. Now with actual events leading to major crashes, a higher rating and lower event probability will be required. Boeing may be required to demonstrate significantly higher reliability of involved software and hardware, to go from 1e-7 probability they clamed and 1e-5 they actually got to 1e-9 required for catastrofic events. Which may lead to electronics requirements being upgraded from "manual mode is always there" to basically FBW standards. That would mean new set of flight computers (probably transplant from 787) and a full new software base. That is lots of work and tons of money for just a single word in certification papers.
I am not saying this will happen as outlined, this is what I see on a worst case scenario side - but these is the type of issues that may come once certification agency is inclined to have their own opinion and not just trust OEM .
stratclub wrote:Kalvado. In the end, Boeing will have to jump through all the required hoops to meet all of the regulatory requirements of all of the counties the MAX are registered in. Your understanding does seem to be spot on. Time line? hard to say at this point.
GF
wikipedia wrote:Re Boeing 707; The British Air Registration Board refused to give the aircraft a certificate of airworthiness, citing insufficient lateral control, excessive rudder forces, and the ability to over-rotate on takeoff, stalling the wing on the ground (a fault of the de Havilland Comet 1). Boeing responded by adding 40 inches to the vertical stabilizer, applying full instead of partial rudder boost, and fitting an underfin to prevent over-rotation. These modifications except to the fin under the tail became standard on all 707 variants and were retrofitted to all earlier 707s.
kalvado wrote:stratclub wrote:Kalvado. In the end, Boeing will have to jump through all the required hoops to meet all of the regulatory requirements of all of the counties the MAX are registered in. Your understanding does seem to be spot on. Time line? hard to say at this point.
Time and cost are the main question. Absolutely worst case scenario - MAX is not cost effective to bring to compliance, going back to NG and paying a fortune for everything. Followed by chapter 7-11.
I definitely not want to see that, but IMHO this is not an impossible - just very unlikely - outcome. But this is not unprecedented either - see Theranos story.
Sometimes it is better to be a pessimist and enjoy the bright future when it comes...
stratclub wrote:kalvado wrote:stratclub wrote:Kalvado. In the end, Boeing will have to jump through all the required hoops to meet all of the regulatory requirements of all of the counties the MAX are registered in. Your understanding does seem to be spot on. Time line? hard to say at this point.
If you mean the Elizabeth Holmes/Theranos story, I don't even remotely see the parallel. You have to remember that this isn't Boeing's first rodeo and complete resolution might be quicker than many people think. I try to be neither pessimistic or optimistic. I just wait for actual facts. I think a lot of people are looking for a smoking gun that does not exist..........
GF
stratclub wrote:I don't think the C/L or C/G would change unless Boeing relocated the engine or changed their weight in some way. The problem isn't either of those, it is the tendency of the aircraft to pitch up when power is applied and pitch down when power is reduced.
Something they may have considered in the MAX original design is changing the angle if incidence of the engines. If they did consider it, it may not have proven to be something viable so we have MCAS instead.
7BOEING7 wrote:stratclub wrote:I don't think the C/L or C/G would change unless Boeing relocated the engine or changed their weight in some way. The problem isn't either of those, it is the tendency of the aircraft to pitch up when power is applied and pitch down when power is reduced.
We don't have MCAS because the airplane pitches up or down, we have MCAS because at one very small area of the flight envelope if the pilot is not pushing the nose over to recover from a stall MCAS helps him out. And by the way the pitch up/down differences between the NG and the MAX probably are no where near the differences between the Jurassic and the Classic.
trpmb6 wrote:I'm not sure where the discussions of lift being produced by the engine are coming from. It has far more to do with the fact that the engine was relocated forward and up in relation to where it previously was, resulting in a different thrust vector orientation than the NG. This creates different pitching moments with which the tail must generate an up or down force to counter act. It only becomes a problem at certain parts of the flight envelope (becoming increasingly noticeable as you approach stall speeds). The first instinct when you approach stall is to immediately increase thrust, but this has an unintended consequence because the pitching moment at that point may cause your AOA to increase faster than the horizontal stabilizer is able to account for. Thus MCAS was implemented to trim the Horizontal stab such that it nosed the plane down as you were approaching that portion of the flight envelope.
stratclub wrote:trpmb6 wrote:I'm not sure where the discussions of lift being produced by the engine are coming from. It has far more to do with the fact that the engine was relocated forward and up in relation to where it previously was, resulting in a different thrust vector orientation than the NG. This creates different pitching moments with which the tail must generate an up or down force to counter act. It only becomes a problem at certain parts of the flight envelope (becoming increasingly noticeable as you approach stall speeds). The first instinct when you approach stall is to immediately increase thrust, but this has an unintended consequence because the pitching moment at that point may cause your AOA to increase faster than the horizontal stabilizer is able to account for. Thus MCAS was implemented to trim the Horizontal stab such that it nosed the plane down as you were approaching that portion of the flight envelope.
I'm not sure I saw anyone post that. Because of the lever moment the engine exerts on the wing, thrust level would certainly change pitch attitude. Lift is determined by the wings AOA. Thrust vector is mostly optimized for cruise and could be optimized for specific flight phases but still changes in thrust would still cause pitch changes in the Max design.
The best fix would be for the engines thrust component to be centered on the same longitudinal axis as the wings chord. I hope that makes sense. That would be impossible unless Boeing went back to Turbo jets.
Like this one:
YYZYYT wrote:I've been wondering how the change in engine placement / size would result in an increased tendency yo pitch up (it's counter-intuitive, as the larger engine, farther forward would suggest CG shifted forward). The comment re thrust vector orientation makes sense.
I also recall seeing reference to air flow over the wing being disturbed by the changed engine size / placement (kinda like on the the original DC 10?) in one of the many, long threads over in Civ Av. Is there any possibility that this could play a role, ie high AOA = disrupt air flow = loss of lift ?
YYZYYT wrote:I've been wondering .......................
Like this one:
Starlionblue wrote:YYZYYT wrote:I've been wondering how the change in engine placement / size would result in an increased tendency yo pitch up (it's counter-intuitive, as the larger engine, farther forward would suggest CG shifted forward). The comment re thrust vector orientation makes sense.
The CG probably hasn't been moved much at all compared to the NG because moving it forward would reduce efficiency. Move the engines forward, but something else went backwards, or the fuselage was stretched more behind the wing or something.
The issue here is that big nacelles contribute significant lift, especially at higher AoA. You have a situation where at high AoA, the center of lift moves forward, inducing a pitch up moment.
