Lpbri wrote:787s have issues with hot brakes. An issue with steel brakes is they can lock and shatter ( common on a 737 ). The tide has turned towards carbon. I don't think you can steel on a new airliner anymore.
mmo wrote:You haven't looked at a 320 with no brake fans. I have had to delay takeoff after a long taxi because the brake temps were out of limits. Takes forever to get the temps down with no fans especially in OMAA
747Whale wrote:Carbon brakes don't get as hot, ...
Lpbri wrote:Another issue is heat. Carbon brakes get hotter.
Zeke2517 wrote:If you had both types of brakes wouldn’t you lose the weight advantage of carbon brakes by also having... steel brakes?
Like, you would also lose the health benefits if you ate the veggie burger AND the cheeseburger.
747Whale wrote:All brakes wear.
Regardless of braking type, in large aircraft we don't pump or repeatedly apply the brakes; they're applied as needed, released when not.
The number of brake applications, even at low speeds, is the primary factor that affects
brake life. Aircraft that fly to/from congested airports, that favor multiple brake applications
during taxi, usually have a 20 % to 30 % reduced brake life. Approximately 75 % of brake
wear occurs during taxi operations
All recommended braking techniques should mainly aim at reducing the number of brake
applications
https://www.iata.org/whatwedo/ops-infra ... Airbus.pdf
kitplane01 wrote:Zeke2517 wrote:If you had both types of brakes wouldn’t you lose the weight advantage of carbon brakes by also having... steel brakes?
You would lose a small bit of the weigh advantage.
You would have small steel brakes, just enough to stop a taxiing airplane. And you would reduce the size of the carbon brakes a tiny bit, since there are steel brakes to help.
zeke wrote:The outside air temperature has little to do with rate brakes cool down. The characteristics of how to treat your brakes varies, you need to know if they are Messier-Bugatti, Honeywell-ALS or UTAS brakes.
The main influence of high outside temperature is to increase density height which increases the ground speed during takeoff and landing.
kitplane01 wrote:747Whale wrote:Carbon brakes don't get as hot, ...Lpbri wrote:Another issue is heat. Carbon brakes get hotter.
I feel so confused
kitplane01 wrote:I bet you'll believe that IATA's advice to airline pilots.
zeke wrote:mmo wrote:You haven't looked at a 320 with no brake fans. I have had to delay takeoff after a long taxi because the brake temps were out of limits. Takes forever to get the temps down with no fans especially in OMAA
mmo wrote:Zeke, I understand what you are saying but I am talking about a dead aircraft started and taxied out and having to wait. I have experienced this on one more than one occasion. your TAS does not increase significantly during taxi. We were restricted to a 25 Knot taxi speed. OFF THE PFD, that is TAS. A relatively light aircraft having to taxi from the Amiri ramp and having to wait over 30 minutes to have the brakes cool down. The normal one smooth brake application to slow the aircraft down, not riding the brakes were done. Our SOP restricted us from single engine taxi and using the T/R to slow. Why anyone would order the 320 series with no brake fans needs their head examined!
TOGA10 wrote:Off topic, how would you treat the different manufacturers? Do you adjust the amount of applications or something else? Just curious!
zeke wrote:I don’t understand how you can get to 300 deg with an empty/light aircraft. Especially if as you are saying your letting it accelerate to 25 kts and then one application back to 5 kts.
The limit with fans installed is 150 deg.
Tristarsteve wrote:Isn't the A320 limit 150 deg with the fans running, and 300deg with them turned off?
747Whale wrote:kitplane01 wrote:747Whale wrote:Carbon brakes don't get as hot, ...Lpbri wrote:Another issue is heat. Carbon brakes get hotter.
I feel so confused
Carbon brakes get hot, like any brake; they don't stay hot like steel brakes; they cool faster, and they don't absorb the heat energy to release it into the wheels nearly like steel does. Carbon is lighter and its more effective the hotter it gets. Steel brakes are the opposite.
Classic 747's in Afghanistan took hours with fans in many cases, to cool enough to take off, and that's after dropping the gear at 18,000 of higher on the arrival to precool it on the way down, leaving it out after takeoff on the hops into Afghanistan, etc. Brakes get hot. At heavier weight, they get particularly hotter. At heavy weights, even with little brake use, the brakes can get so hot during a short taxi just from tire flex and the heat generated that way that a takeoff may need to be delayed, for brake energy. A long three mile taxi at Schipol is a good example.kitplane01 wrote:I bet you'll believe that IATA's advice to airline pilots.
Aaah...yeah.
I am an airline pilot.
And an aircraft mechanic with a few decades of experience.
It's always good to be schooled by a private pilot qualified to neither, though. Thanks.
pikachu wrote:"I get I'm being insulted, but I don't get why. Also, it's not helpful.
No one believes I'm an expert in anything. I don't either. But I understood that the main cause of wear in carbon brakes is number_of_applications, not total_energy_of_stopping. I believe this because the IATA says so (and lots of other people too). Do you disagree with them? If so, how come? I'm here to be educated."
What high school class are you developing this project for?
Brakes are made to stop airplanes. When brakes wear out you replace them.
Any questions? LOL
kitplane01 wrote:pikachu wrote:"I get I'm being insulted, but I don't get why. Also, it's not helpful.
Any questions? LOL
No high school project.
It would be better if brakes wore out less often. Or am I confused about that? Don't they cost many much $$$$?
kitplane01 wrote:kitplane01 wrote:I bet you'll believe that IATA's advice to airline pilots.
No one believes I'm an expert in anything. I don't either. I'm not trying to school anyone. But I understood that the main cause of wear in carbon brakes (unlike steel brakes) is number_of_applications, not total_energy_of_stopping. I believe this because the IATA says so (and lots of other people too). Do you disagree with them? If so, how come? I'm here to be educated.
Also, I like the personal experience stories. But not the insults.
747Whale wrote:kitplane01 wrote:kitplane01 wrote:I bet you'll believe that IATA's advice to airline pilots.
You're not being insulted. You're being insulting. There's a difference.
Nope. You're reading things I never wrote. No insult was written.
Peace
thepinkmachine wrote:Boeing has come with an interesting solution to reduce brake wear on the 787.
If brakes pedals are pressed below certain speed during taxi (30 or 70 Kt depending if it’s -8 or -9), only two out of four brakes on each bogie activate. On a subsequent pedal application they alternate, ie the other two brakes activate, while previous pair remains released.
This way taxi brake wear is reduced by half. In case of harder pedal activation, or at higher speeds, all four brakes activate on each bogie.
LH707330 wrote:Thanks for posting this. I was about to ask, "has anyone thought of alternating the brakes applied?"
thepinkmachine wrote:LH707330 wrote:Thanks for posting this. I was about to ask, "has anyone thought of alternating the brakes applied?"
Yup, it’s a pretty neat solution and a relatively simple one. Mind you, 787 brakes are all electric. I wonder if alternating brakes could easily be introduced on a traditional hydraulic brake assembly.
In addition to the link above on how carbon brakes work, there’s a pretty good video on the subject on YouTube:
https://youtu.be/SG4Aw5BujEU
kitplane01 wrote:I understand that normal metal brakes experience wear as a function of stopping power. Stopping from high speed causes more wear than normal taxiing. I also understand that carbon brakes experience wear more as a function of number of applications. Every time you engage carbon brakes, you're putting wear into the brakes.
Suppose a plane had both kinds. Then on low speed braking (taxiing), you could use only the metal brakes, but on high speed braking (landing) you could use both. You would get the advantage of light weight from the carbon brakes, and less wear from the metal brakes.
To make things even better, put metal brakes on the nose wheels and carbon brakes on the mains. Now you also have more total stopping power. Since the nose wheel brakes are taking some of the load, the main wheel brakes could be lighter. (I do understand this increases weight/complexity somewhat)
Has any plane ever mixed brake types?
strfyr51 wrote:kitplane01 wrote:I understand that normal metal brakes experience wear as a function of stopping power. Stopping from high speed causes more wear than normal taxiing. I also understand that carbon brakes experience wear more as a function of number of applications. Every time you engage carbon brakes, you're putting wear into the brakes.
Carbon Brakes weigh 30% less than steel brakes and get twice as many landings!! Why would you want to use a heavier Brake and carry more Zero Fuel Weight?
If that makes sense to you? Then see how many guys agree with you because I for one Do NOT! Many airlines are dumping Steel brakes of they can.
