A380MSN004
Differences Dash 8 & Dash 8 NEXTGEN
Fri Mar 29, 2019 4:15 pm
Hi everyone,
I did some researches regarding the difference between the Dash 8 Q400 and the Dash 8 Q400 NEXTGEN. Here are below according to some pages the updates on the NEXTGEN
Q400NextGen
Version of the Q400 with updated cabins, lighting, windows, overhead bins, landing gear, as well as reduced fuel and maintenance costs.
I'm looking for the information regarding the reduced fuel consumption and the maintenance costs? Does anyone have some datas about those reductions?
Many thanks.
A380MSN004
Re: Differences Dash 8 & Dash 8 NEXTGEN
Mon Apr 08, 2019 4:00 am
After some researches, I found out that its only a cosmetic update :
Led Cabin lights
Overhead bins that Can fit IATA standards cabin bags
New slim seats
They increase the C Cheks intervall
Performance And fuel burn remains the same
Ethan22
Sun Aug 04, 2019 11:31 pm
The differences between the Dash 8 and Dash 8 NEXTGEN are very small....
For example, we have the "Q" series, which implements a Noice and Vibration supression system, and some interior updates as well.
The ANVS (active noise and vibrations supression system) works by putting a low frequency sound through the speakers of the cabin, which cancels out much of the noise on the Dash 8. (the Q400 is by far the quietest turboprop in the sky) and also has a system that cancels out much of the vibrations on the aircraft. A normal Dash 8 takeoff sound in the cabin would be about 104DB, (which is considered very unsafe), while a Dash 8 equipped with the ANVS would be roughly about 85DB. (still very loud considering the jet aircraft), and the vibrations would be very obvious on the Dash 8 with no ANVS (so bad that your drinks could possibly spill), and one with it would barely have any vibrations at all.
As for the decorations on the interior, better lights and AC are added to the cabin, as well as better overhead bin space. The old AC's on the aircraft were extremely bad...….however the updated versions are much better.
Many airlines continue to operate the Dash's with the original systems, not the newer. Airlines such as Air Canada use the original Dash 8's, not the NEXTGEN. Clearly many airlines would choose the NEXTGEN over the original, due to the rising fuel cost, however for some airlines, it is simply too much money to operate the NEXTGEN aircraft, (such as the Q100, Q200, Q300, Q400) so they just operate with the orignal aircraft with the original systems, engines AC's etc...
Hope that helps.
A380MSN004
Mon Aug 05, 2019 7:15 am
Very interesting. Thanks.
Would be curious To have a comparison regarding the cabin noise with a Jet.
Canuck600
Mon Aug 05, 2019 8:19 am
Air Canada's regional partner operates Q400's https://www.aircanada.com/ca/en/aco/hom ... fleet.html
Armadillo1
Mon Aug 05, 2019 12:54 pm
https://www.seatguru.com/airlines/Phili ... mation.php
for difference between Q400 and Q400NG
Users browsing this forum: flipdewaf and 29 guests
