airlineworker
Jet Bridges to service two different aircraft?
Sun Apr 07, 2019 12:23 am
Are there jet bridges that that break off into a Y formation for servicing two planes at once? I could see this working for small terminals with space constraints.
Reason: Non descriptive title
johns624
Re: Jet Bridges
Sun Apr 07, 2019 12:58 am
It really wouldn't save space since the deciding factor in how close planes can park is wingspan. Also, one plane would board from the left door and the other from the right.
superjeff
Re: Jet Bridges
Sun Apr 07, 2019 2:44 am
American has a number of gates at DFW where one entrance breaks off into two jetways; some of them, back in the day, were used where widebodies boarded from L1 and L2 (747's and DC10's).
JayinKitsap
Re: Jet Bridges
Sun Apr 07, 2019 3:36 am
The concourse designer lays out to have a standard Jet Bridge down the length, but often at corners it gets difficult. Widebody gates are easy to fit there but if just NB's the use of a fixed bridge section down to a Y is a good solution. As Superjeff noted the layout to do the L1 & L2 is still used. Because of the corner the planes are turned about 120 degrees to each other to take the least space.
Cubsrule
Re: Jet Bridges
Sun Apr 07, 2019 3:39 am
There are also some on F and G at ORD. The F ones may have been widebody gates, but G (in its current incarnation) was purpose built for RJs.
CLEguy
Re: Jet Bridges
Sun Apr 07, 2019 3:34 pm
Gate C21-22 at CLE might be what you're talking about? Take a look at this aerial shot of the "banjo" end of the C concourse.
https://www.google.com/maps/@41.4072588 ... a=!3m1!1e3
OB1504
Re: Jet Bridges
Sun Apr 07, 2019 5:36 pm
Gates F11/F15 and F10/F12 at MIA do this, and gates F14/F16/F18/F20 and F17/F19/F21/F23 take it to the next level by effectively breaking off into two Ys.
Wynnster8
Re: Jet Bridges
Sun Apr 07, 2019 5:47 pm
Yes, Tel Aviv airport does.
Favorite plane is 757-200 Favorite airport is Singapore Favorite route is SYD-JNB
airlineworker
Re: Jet Bridges
Sun Apr 07, 2019 8:55 pm
Thanks for the photo, I knew I had seen one in the past but can't remember where. A good way to add 2 gate positions at small terminals.
spacecadet
Re: Jet Bridges
Sun Apr 07, 2019 11:08 pm
I feel like this is actually pretty common.
Here's one at JFK: https://goo.gl/maps/V4F2nbCCnMC2
Several at Newark: https://goo.gl/maps/XvSqMeWfqAC2
In Japan and maybe other places, they have "permanent" jet bridges that then split off to service two airplanes - so you leave from one of two gates into a common jetway, then split off to your plane. Like this:
https://goo.gl/maps/tfCzPiiSBVM2
You can see that that gate is labeled 67L, 67, and 67R. You can fit two narrowbodies or one widebody in there.
Dominion301
Re: Jet Bridges
Mon Apr 08, 2019 12:46 am
In Canada, YHZ has a pair of these and the old YOW terminal had one...I think that the two loading bridges in YQM’s old terminal were like that too. I think YEG used to have one too.
Ziyulu
Re: Jet Bridges
Mon Apr 08, 2019 1:07 am
I think LAX had a few with AA in terminal 4.
September11
Re: Jet Bridges
Mon Apr 08, 2019 1:10 am
CMH has 3 gates connecting to a jet bridge. America West's idea.
Airliners.net of the Future
upperdeckfan
Re: Jet Bridges
Mon Apr 08, 2019 2:08 pm
FRA concourse A/Z gates although mostly used by LH's WB's can also serve 2 NB's at the same time
748,744,742,741,772,773,762,763,
764, 789, 732,733,735,737,738,739,
752, 722, 717,74M,DC10,DC9,M82,
M83, M87, M88,310,319,320,321,332,
333, 343, 346,359,388,L1011,CR2,
CR7, CR9,CRK, E175,E190,ATR42,
DSH8, CS1,CS3
RawSushi
Re: Jet Bridges to service two different aircraft?
Tue Apr 09, 2019 8:38 am
I believe this is done in Singapore as well. I've been in gate lounges where there are passengers from two separate flights departing within 20 minutes of each other and the plane outside the window was not the one I was taking. It's probably one of the A380 gates.
Tue Apr 09, 2019 10:17 am
Yes done at many airports, a gate can have three markings, like 26,26A,26B. The whole number is for single use gate, the A and B allow the gate to be used by two narrow bodies, each with a bridge.
seansasLCY
Dual Use Gates at Airports
Mon Apr 15, 2019 1:39 pm
Forgive me if this is the wrong place. I'm looking for some pictures of dual use gates at airports like they have at Heathrow T2. I'm referring to the kind of gate which can hold either a single widebody or two narrowbodies. Also is there a proper name for such a set up?
CPS001
Re: Dual Use Gates at Airports
Mon Apr 15, 2019 10:24 pm
MARS - Multiple Aircraft/Apron Ramp System.
chunhimlai
Mon Apr 15, 2019 10:43 pm
Which USA airport does install MARS?
I only know SFO/DFW/JFK/DEN
Flightguy123
Mon Apr 15, 2019 10:58 pm
Seattle has gate S3/S3A and S2. If a widebody plane is parked in at S3A, then the bridge at S2 cannot be used as the wing of the wide body is usually just about 10-15 feet infront of it. After the Delta international push around 12-13:30 local, both gates are run domestic (normally) or rather narrow body planes.
airplanedaj
Mon Apr 15, 2019 11:02 pm
I think there are two types of gates that we are talking about here: there's what looks like a dual jet bridge wide body gate, but can also be used for two narrow bodies (see LHR, JFK, etc), and then there are the gates where they throw a wide body line over two narrow body gates (48X at LAX, H16X at ORD, etc).
DLHAM
Mon Apr 15, 2019 11:50 pm
Hamburg has two of them.
https://maps.app.goo.gl/1tLJh
They can hold either one plane with maximum size of an A380 or two planes of the size of a 737 or 32X maximum.
On Google Maps you see a 777 parked at the one Gate and two A320s parked on the other one for a perfect comparison.
Most of the other Gates are sized to have a 757 and an A310 next to each other alternately. There are additional lines/positions for widebodies. When one Gate is used by a widebody the adjacent "standard" position to one side is blocked.
My Instagram Account: Instagram
LittleFokker
Tue Apr 16, 2019 2:20 am
LAS used to have a few gates at the A/B terminals that could have 1 widebody or two regional jets (HP would split them for the night hub). SFO gate 84 is currently being used by 4 CRJ2s when but is 777/747 capable.
"All human activities are doomed to failure." - Jean Paul Sartre
fessor
Tue Apr 16, 2019 3:52 am
What About AYT they have it and use it alot
OB1504
Tue Apr 16, 2019 6:01 am
MIA makes heavy use of gates like this at nearly every concourse:
• D1A or D1 & D2
• D4A or D4 & D6
• D5A or D5 & D7
• D8A or D6 & D8
• D9A or D7 & D9
• D10A or D10 & D12
• D28A or D28 & D29
• D30A or D29 & D30
• E6A or E6 & E8
• E24A or E24 & E25
• F10A or F10 & F12
• F14A or F12 & F14
• F15A/B or F11 & F15
• F16A or F16 & F18
• F18A or F18 & F20
• F19A or F19 & F21
• H4A or H4 & H6
• H8A or H8 & H10
• H10A or H10 & H12
• H15A or H15 & H17
• J5A or J3 & J5
• J7A or J7 & J9
• J11A or J9 & J11
• J17A or J15 & J17
Dotted lead in lines galore across the ramp.
VSMUT
Tue Apr 16, 2019 8:15 am
Dar Es Salaam, Tanzania, has 2 double jet bridges.
TheEuphorian
Wed Apr 24, 2019 8:27 am
If I remember correctly, CGK T2 has quite a few of them.
Users browsing this forum: Armadillo1, VolvoBus and 22 guests
