dom66
DC8 55F main cargo door
Mon Apr 08, 2019 6:32 pm
Hello,
I am looking for a person who could inform me about an old aircraft the famous DC8 serie 50, and where I could find information about electrical, pneumatic and hydraulic circuit.
For the moment, here is my question.
My question is about the function of the main cargo door on DC8 55F.
Is it possible to open the cargo door without electric Ground power unit, just by the inboard battery ?? 28 vdc??
Thank you in advance for the answer.
A million apologies, guys, for my bad English
Max Q
Re: DC8 55F main cargo door
Tue Apr 09, 2019 2:02 am
Don’t know, I do know it has flown with the cargo door wide open !
GGg
dom66
Tue Apr 09, 2019 10:18 am
???? " flown with the cargo door wide open" ???? :laughing: :banghead:
Max Q
Tue Apr 09, 2019 12:32 pm
Can’t link it, google ‘ DC8 cargo door open in flight ‘
No kidding
GGg
Natflyer
Sun Apr 14, 2019 9:30 pm
dom66 wrote:
Hello,
It’s been nearly 30 years since my DC-8 days, but I am pretty sure you need AC (ground power) to operate the door pump. There was a manual way to “pump” the door up IIRC.
fr8mech
Sun Apr 14, 2019 11:25 pm
The door can be pumped open, but there is an isolation valve in the system. I can’t remember if the valve is on the battery bus, nor can I reimburse if it had a manual override. That valve must open for the door to operate, electrically or manually.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
Apprentice
Mon Apr 15, 2019 5:54 pm
Hello: I had never dealt with a DC-8. I don’t know about similarities with DC10/ MD11
For these, to open any of the two main cargo door, You don’t need power, just a lot of Man Power., light will help to tell You when every On is on position to change to the next step, nothing more.
Turn a manual driver in two locations:
1. Locks , when Locks are completed open, (handle)
2. Latches, (turn the manual drive, till Latches are fully open)
3. Hooks. When hooks are open, door move away a little from is closed position and them, it’s time to open the door by turning manual drive a a lot, until door is completed open.
OSI: 1, use of an electrical or battery screwdriver is not allowed, it may damage mechanism due to overtorque.
2. A Placard with instructions, should be placed in every cargo door as indicated by IPC.
3. Bulk Cargo door and Pax doors 11 & 21, may be opened similar way.
“An4; IL18; IL6; Tu5; D10; MD11; MD83; B32; B34: B37; B744; B748; B752; B763; B772; B773; B77W; A320; A332; A333; A342; A343.
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
“CUBANA” 90 years Flying”
Apprentice
Mon Apr 15, 2019 5:58 pm
And last, on Dc/MD, if You do not open the door all the way up, unloading mechanism will not activate.
Apprentice
Wed Apr 17, 2019 4:45 am
Hello, again base on DC10, valve has an Manual position, activated with handle in door control panel. Pump, fully manually, is in the fuselaje between LH and RH Landing Gear. In fact, able to pressurized system #3, except door valve redirect pressure to door opening.
dom66
Sat Apr 20, 2019 5:55 pm
Hello everyone,
Thank you for your answers, I had the information.
External power AC, only on the cabine BUS N°4 and the 115/400 pump. A handle in a floor trap, which controls a hydraulic valve
strfyr51
Sat Apr 20, 2019 6:02 pm
dom66 wrote:
Hello,
I never worked on a DC8-55F but I have worked on the DC8-54F and the DC8-62F, the doors can be opened Electrically using a GPU Or manually by pumping the door open (A LOT of Work) I've never seen where the door could be opened with the Battery.
slcguy
Mon Apr 22, 2019 6:51 am
No kidding
Can't provide any insight on how to open the door. But a DC-8 flying with cargo door wide open did happen (not intentional of course). Apparently also happened with CV-880 and a B-757 as well. Tough birds including the cargo doors . LOL
Thread on A-net about the 757, viewtopic.php?t=581445
You can Google for the DC-8 and CV-880.
Apprentice
Sun Apr 28, 2019 5:07 am
dom66 wrote:
Hello everyone,
Hi, (only for my experience on Dc10)
Valve is located behind Cargo Control Panel outiside fuselaje.:
In Normal mode, , moving the handle (with a latch in open position) will operates Locks and Latches with normal Hydraulic Pressure
In emergency, latch open, activating the handle, switch on “Electrical Emergency Pump”, and them, with valve open....
Do not pay much attention to my memory, in previous post, I forget to describe this past method.
The pump in a panel on fuselaje Rh side, behind Main LG Door, is MANUAL. One man operates the valve and the other. Pump and pump and....so, three methods:
1. Electro controlled hydraulic operated.
2. Manual controlled (valve position) , Emergency electro hydraulic operated.
3. Manually controlled and manually operated.
