intrepidflyer
Staying on the centre line
Thu Apr 18, 2019 10:03 am
When driving my car on the motorway at roughly 70mph I can feel how small steering movements or corrections have big impacts.
How do planes manage to take off and land so "straight"? You certainly don't feel like plane veering left and right trying to stay on the runway.
Do the wheels lock on a particular heading?
If the pilot were to sneeze and judder the controls during landing or takeoff roll could the plane veer off at high speed?
Just curious!
fr8mech
Re: Staying on the centre line
Thu Apr 18, 2019 10:20 am
The steering system keeps the nose wheels centered, but they are not locked. The flight crew uses the rudder pedal steering system to make small adjustments. As the aircraft speeds up, the rudder begins to gain authority.
Could it? Sure. Will it? Probably not.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
flipdewaf
Thu Apr 18, 2019 10:32 am
When I was learning to fly in the trauma hawk it was always deliberate to keep a bit away from the center line as the shaking caused by lights etc could cause pieces of trim to be released from the cockpit. the steering with your feet could take a bit of getting used to and my instructor could always tell if I had rushed from home to arrive for my lesson as my "clutch foot" was always a bit heavier than the other.
Talking about going straight down the centre line of the runway always reminds me of a particular apocryphal tale:
It is a very windy day with huge and gusting crosswinds and there is a 747 (isn't it always in these tales) coming in to land. The pilots manage a almost perfect landing worthy of praise even in good conditions. The controller comes over the radio and says "good job on landing in these conditions but you did land just to the left of the center line", "I know" says the captain "and the first officer landed just to the right".
Fred
Max Q
Thu Apr 18, 2019 11:40 am
Fred
I have over 1000 hours instructing in the PA 38 !
Haven’t heard that moniker in a while
Best wishes
GGg
akoma
Thu Apr 18, 2019 4:50 pm
Fred
Best wishes
Loved the PA 38, in spite of what others feel. Started my flying in the PA 38, many years ago.
Just like learning other stuff, it was really difficult trying to keep to the centre line during the first couple of hours on a plane; after a few hours, it sort of becomes automatic and we don't even think about it anymore :)
intrepidflyer
Thu Apr 18, 2019 8:37 pm
Interesting. Thanks for the replies
Max Q
Fri Apr 19, 2019 4:20 am
Fred
Best wishes
It’s a good aircraft, much preferable to the tiny, cramped Cessna 152 series
Not stable at all but that made it a good trainer, if you can fly it you can fly anything
GGg
spacecadet
Fri Apr 19, 2019 6:41 am
It's all manual using rudder. And you certainly *can* feel it sometimes, even in an airliner. It depends on the winds and the pilot. I have felt like the plane was going to turn over on some takeoffs and landings.
I fly small planes myself and it's a lot harder to keep one of those on centerline (because less mass), but it's the same basic concept, and I've taken off in airliner Level D simulators as well. You know the winds ahead of time and you know the general tendency of the airplane so you put in what you think is the right amount of rudder to start with. As you begin to gain speed, it becomes clear very early whether you need to make corrections, and you do so. If you're skilled, you make just the right corrections and keep the centerline without anyone feeling anything. If you're less skilled, you're having a bad day or the winds are up at the limit, you can end up "chasing" the centerline and oscillating back and forth. This is usually pretty easy to feel. Also, right near rotation speed the plane can start to lose adhesion on the tires and can begin drifting a bit in ground effect, and you can definitely feel the rudder kick in then.
The runways at major airports usually have pretty wide centerlines so it's not that hard to keep on it in most cases. But yeah, it's definitely possible to get off the centerline, or to oscillate from one side to the other.
fr8mech
Fri Apr 19, 2019 7:53 am
No, it is not all manual using rudder. Airliners have nose wheel steering that can be controlled by 1)A tiller (full authority) 2)Rudder pedal steering (limited authority).
Fri Apr 19, 2019 9:27 am
The instructor screaming "CENTERLINE!!!" in your ear is a strong motivation to improve. :D
7BOEING7
Fri Apr 19, 2019 2:47 pm
Boeing airplanes: Just to be clear generally the tiller is used for initial lineup and rudder pedal steering for the takeoff roll up until the rudder becomes effective at 40-60 kts. The tiller is not recommended above 30 kts and above 20 kts it is easy to end up over controlling when using the tiller.
CosmicCruiser
Fri Apr 19, 2019 7:06 pm
we never used the tiller once lined up.
greg85
Fri Apr 19, 2019 7:43 pm
But if you ever do feel a judder, it definitely means the pilot sneezed.
AirKevin
Fri Apr 19, 2019 10:25 pm
[photoid][/photoid]
Yes, but you aren't going to be steering with the tiller during the take-off roll or the landing roll, which is what the original question was asking.
Captain Kevin
fr8mech
Sat Apr 20, 2019 12:09 am
True, but I wasn't replying to the op at this point, I was responding to the comment/statement/assertion that:
and, it is not. The rudder "steers" the aircraft aerodynamically, only after the aircraft has accelerated to a sufficient speed. Up until then, as noted a couple of times above, rudder pedal steering is used to maintain directional control (on the runway).
spacecadet
Sun Apr 21, 2019 5:25 am
:checkmark:
I'm not sure if some others misunderstood the question or what.
N1120A
Thu Apr 25, 2019 3:46 am
Just curious!
Sneezing isn't going to do anything, unless it was a really violent, alien sneeze :-P.
Flying is also all about small corrections. That is particularly true in smaller airplanes, but also true in larger ones. You don't feel those small corrections because the weight and stability of large aircraft buffers that. That said, I've certainly had my share of flights on airlines where I could feel fairly sizeable corrections being made on final and especially on roll out.
Thu Apr 25, 2019 3:59 am
Just curious!
The closer you get to the ground, the smaller the margins, and consequently the more decisively you have to correct.
N1120A
Thu Apr 25, 2019 6:36 am
Decisively, but also smoothly and with greater precision, which means you want to make much more subtle corrections.
Thu Apr 25, 2019 7:08 am
That really depends on how far you've strayed from the ideal trajectory. ;)
N1120A
Thu Apr 25, 2019 7:31 am
Well, yes. Sometimes the rudder needs a nice, firm kick.
intrepidflyer
Thu Apr 25, 2019 10:54 am
But on the ground for nose wheel control it's a steering wheel... Or pedals?
Thu Apr 25, 2019 11:51 am
It's both. However, while taking off or landing you'd only use the pedals. The tiller ("steering handwheel" to be exact) has too much authority for very little movement of your hand to use at any significant speed. You'd use it only at taxi speeds.
As an example, the A330 tiller can deflect the nosewheels up to 72 degrees in either direction, and you don't have to move your hand very much to go to the stops. You can make the nose move almost sideways. The pedals only give you up to 6 degrees in either direction, but you have to move your feet significantly to get to the stops.*
* On the A330 the system gradually decreases tiller and pedal authority at high speeds, and I'm guessing this is true of many modern designs, but the point stands.
intrepidflyer
Thu Apr 25, 2019 12:02 pm
Thank you - I think this most succinctly answers the OP.
DALMD80
Thu Apr 25, 2019 1:09 pm
Flew on Spirit BWI-FLL-STT, both flights I could feel the plane swerving back and forth.
The 757-200 with Rolls Royce engines in the US Airways livery is the ultimate in airliner beauty,
Moose135
Thu Apr 25, 2019 1:50 pm
I earned my PPL in the Tomahawk while in college. It was a fun little airplane to fly.
One thing I was taught back in those days, that carried on to the bigger and faster aircraft I flew was to look down towards the end of the runway and aim for that, it made for fewer and smaller corrections to stay on centerline, rather than making a slalom course out of the runway trying to keep it straight.
DALMD80
Thu Apr 25, 2019 2:56 pm
Cool.
Lrockeagle
Fri Apr 26, 2019 2:55 am
My CFIs always jumped right on “look down the runway!!!” when I was off a bit. Looking down to the end also helps judge height above the runway when landing. Biggest mistake I regularly make
Lrockeagle
15 years ago
I got $20 says AA takes their 787's with GE powerplants. Just a hunch. Any takers?
N1120A
Fri Apr 26, 2019 5:52 am
On what? On larger jets, think GIV and up, it is nose wheel for more subtle movements and a tiller for larger turns. On a Grumman Tiger, Cirrus or Diamond, it is a castering nose wheel with differential braking.
intrepidflyer
Fri Apr 26, 2019 8:30 am
Thanks for the replies. My question was regarding commercial airliners/jets and using the tiller for taxiing up to the runway lineup and rudder from there makes perfect sense in how "sensitive" you want your steering corrections to be!
N1120A
Fri Apr 26, 2019 4:51 pm
They aren't using the rudder, at least not till it becomes effective. Larger jets have nosewheel steering, just not to the extent needed for taxi. They use nosewheel steering to stay lined up on centerline on the runway, during takeoff and landing, particularly when the rudder isn't effective enough to do so.
slcguy
Fri Apr 26, 2019 8:55 pm
The tiller is not used during take off and landing, However there is limited nose wheel steering through the rudder pedals, enough to track the centerline on takeoff and landing and even make a high speed turn off taxiway on landing (that takes a little practice to learn when to apply the needed pedal deflection). In reality consider it using the rudder for steering on take off since the nose wheel steering is controlled by the same pedals that move the rudder. The only thing you will notice is the pedals become more effective as speed increases and the rudder itself takes effect.
triple3driver
Sun Apr 28, 2019 2:13 am
You only use the tiller during taxi, once you line up you take your hand off the tiller and place it on your sidestick/yoke/wherever you want if you're not flying. You could use the rudder pedals during taxi if you want, but I don't get why you would do that since the tiller has full authority whereas the rudder pedals do not. Once you takeoff or land you use the rudder to keep yourself centered, subtle movements so that the guy in 29A doesn't spill his coffee. You generally don't feel it simply due to the fact that jets, especially widebodies, are truly massive machines. Using my A330 as an example, the -200 weighs at about 265900lb empty. Meanwhile, my own car is slightly over 4500lb. This means that empty, not counting the various liquids and cargo and bags of meat that you normally find inside both, the A330-200 is about as heavy as 59 midsize SUVs. Needless to say, you feel things a lot more in the car than in the plane, and this is using the smallest variant of a family of aircraft that, when you think about it, aren't really that big compared to quite a few aircraft in the skies.
If you can walk away from it intact, it was a good landing!
Users browsing this forum: No registered users and 22 guests
