dr1980
Category 1 ILS DH Variations
Tue Apr 23, 2019 3:59 pm
Hello, given that 200 feet is the most typical CAT1 ILS decision height, I’m curious what kind of local conditions could cause this number to be higher? Flightsimming with charts I’ve seen 215, 250 etc on occasion and I wasn’t sure why.
Dave/CYHZ
LH707330
Re: Category 1 ILS DH Variations
Tue Apr 23, 2019 5:27 pm
Some areas have difficult climbs on the missed, or require some other action that demands more time, which is why they move the DH up.
thepinkmachine
Tue Apr 23, 2019 5:46 pm
Also, there might be obstacles before the runway, rising the decision height. 200 ft is the minimum DH for CAT 1, it can always be higher.
"Tell my wife I am trawling Atlantis - and I still have my hands on the wheel…"
Wed Apr 24, 2019 1:38 am
A couple of examples.
ILS 36 at WAMM - Manado Ratulangi. High terrain on the missed approach. Cat I minimum is 278-316 feet AGL*. https://saripedia.files.wordpress.com/2010/08/manado.pdf
ILS 04 at WAPP - Ambon Pattimura. High terrain on the missed approach. Cat I minimum is 469-489 feet AGL*. That missed approach path looks like it would induce some picker factor if flown at night btw. :)https://saripedia.files.wordpress.com/2010/08/ambon.pdf
ILS 16 at YMML - Melbourne Tullamarine. High terrain on final. Cat 1 minimum is 208 feet AGL. https://www.crc.id.au/xplane/charts/DAPS-2019-FEB-28/Melbourne%20(YMML).pdf
* depending on category.
JustAnFO
Wed Apr 24, 2019 11:57 am
A common reason for increased DH in the US is reduced/non-standard approach lighting.
LH707330
Wed Apr 24, 2019 4:56 pm
A good example of that is KTIW, the plate for the ILS 17 says it's 494/200, but there was a NOTAM for a while that put it up to 655 while they were fixing it.
Web500sjc
Wed Apr 24, 2019 9:48 pm
The ILS 34 at KROA has minimums that are 700AFE due to the climb requirements for the missed. I do not have to question why the minimums are so high, but I do have to question why they even bothered to have an ILS.
Boiler Up!
N1120A
Thu Apr 25, 2019 3:32 am
Other factors are noise abatement and proximity to other airports. For example, KHHR's LPV approach (CAT I quality) has minimums more than twice 200', and that is partly because KHHR's runway is recessed into the ground a bit and also because of the need of separation from LAX, TOA and LGB. KMYF's ILS and LPV approaches both had HATs of 200', but were first NOTAM'd to 250' and are now published as such. The reason there is likely noise abatement.
dr1980
Fri Apr 26, 2019 9:07 pm
Thanks for the info!
Dave/CYHZ
Thenoflyzone
Sat Apr 27, 2019 12:50 am
:checkmark:
Same in Canada.
us Air Traffic Controllers have a good record, we haven't left one up there yet !!
Users browsing this forum: OceanATC, volks92 and 25 guests
