aerolimani
Researchers invent new, permanent, anti-ice coating
Sat Apr 27, 2019 4:26 pm
University researchers in Canada have developed a new anti-ice coating. It looks like a permanent coating which prevents ice from adhering to surfaces. Something like this has the potential to save a lot of money in the aviation industry. I wonder if it will become a reality, in the end, for aviation. Or, will it remain relegated to restaurant ice-makers?
https://www.cbc.ca/news/canada/calgary/ ... -1.5112427
WeatherPilot
Re: Researchers invent new, permanent, anti-ice coating
Sat Apr 27, 2019 4:43 pm
So they made a Teflon for airplane wings.
BWIAirport
Sat Apr 27, 2019 5:04 pm
My first thought is the weight of this coating on the aircraft. And would Boeing make it an option? So Fiji Airways could decide not to order it since they'd never need it?
SWA, UAL, DAL, AWE, ASA, TRS, DLH, CLH, AFR, BAW, EIN, AAL | E190 DC94 CRJ2 B712 B733 B737 B738 B739 B744 B752 B753 B762 B77W A319 A320 A20N A321 A333 A343 A388 MD88
aerolimani
Sat Apr 27, 2019 5:19 pm
I would think that such a thing could be optional.
I wonder if it could ever replace heat based anti-icing for leading edges and nacelles. Or, inflatable boot types?
Or, could it be integrated into the paint so as to less significantly affect the weight? Of course, it would only really be needed on the wings and the horizontal stab, wouldn’t it?
Tugger
Sat Apr 27, 2019 6:16 pm
Devils advocate here! :devil:
Definitely has a loooonng way to go before any application to aircraft. If it is ever offered. Failure of the application or the substance could lead to fatal consequences and exposure to enormous liability.
Beyond that I am curious how high altitude freezing, additional radiation over thousands of hours and friction from atmospheric drag etc. would affect this.
Tugg
There are many kinds of sentences that we think state facts about the world but that are really just expressions of our attitudes. - F. Ramsey
aerolimani
Sat Apr 27, 2019 6:43 pm
Tugg
It’s definitely not something that is likely to happen very quickly, if ever, frankly speaking. There are significant obstacles to overcome. It’s true that many products never leave the research phase.
But, the cost savings on this could be huge. That could drive the research. Imagine eliminating all the costs of de-icing: the fluid itself, environmental recovery of said fluid, the crew hours, the wasted time a plane sits there on the de-icing pad, the cost of purchasing and maintaining the spraying equipment, and on and on.
Okie
Sat Apr 27, 2019 11:40 pm
Makes you wonder what process they use to get it to adhere to the substrate they wish to be anti-ice.
Chemically bonded, baked on, dries from VOC evaporation or water emulsion?
Okie
Francoflier
Sun Apr 28, 2019 4:32 am
If its effectivity is proven, I could see it being implemented as a film applied to sensitive surfaces, inspected on regular basis and renewed as required.
The weight and money savings from foregoing the anti-ice systems and their associated plumbing / cabling and maintenance requirements could make it worthwhile.
It would take a while to get it anywhere close to certification, but I could see it creeping its way into the GA market in the not too distant future.
Redbellyguppy
Sun Apr 28, 2019 2:07 pm
You think Fiji airlines never encounters icing conditions?
Sun Apr 28, 2019 11:28 pm
Indeed. I've walked under the wing with 30 degrees outside and been dripped on from melting ice under the wing.
Redbellyguppy
Mon Apr 29, 2019 7:38 am
Cold soaked fuel frost aside... you and I both know a jet can encounter icing conditions at any time of the year.
Mon Apr 29, 2019 8:35 am
Yep!
CALTECH
Mon Apr 29, 2019 8:38 am
Reminds me of the times in summer when the anti-ice valves need to be locked in the on position, and folks ask why when it's 95 degrees on the ground......
Approx temp at altitudes...
You are here.
BWIAirport
Mon Apr 29, 2019 1:27 pm
Forgive me for possibly sounding naive but I thought significant levels of ice were unable to form on an airborne aircraft since its going so fast?
Buyantukhaa
Mon Apr 29, 2019 3:03 pm
I scratch my head, therefore I am.
mxaxai
Mon Apr 29, 2019 3:25 pm
That is sadly wrong. Particularly super-cooled droplets (liquid water at 0°C or less) are a problem. Warmer droplets can still freeze if aircraft parts are at < 0°C, e. g. during descent. Several crashes have occured due to icing.
https://www.skybrary.aero/index.php/In-Flight_Icing
However, I'm not sure if this particular technology can prevent the in-flight build up of ice.
CALTECH
Mon Apr 29, 2019 6:26 pm
Readup on AF447 and many others. Amazing.......
You are here.
Mon Apr 29, 2019 11:15 pm
Temperatures between +10 (SAT/OAT) and 40 (TAT), with visible moisture, are considered "icing conditions". Regardless of speed. Supercooled water droplets turn into ice on contact, and can stick like glue.
Okie
Mon Apr 29, 2019 11:37 pm
I would have to see this in testing as well.
There is a profound difference in dealing with an ice cube adherence to an ice that has formed in a tray and the weight of the cube such that it can release itself from gravity and Rime ice that forms on aircraft surfaces in flight.
This is especially be important when the Rime ice forms around the leading edge of a wing or slightly aft of the leading edge.
The problem with Rime ice is more about the ice shape disturbing the airflow than the quantity from my understanding.
Okie
CALTECH
Thu May 02, 2019 3:48 am
NASA and others have been looking into it for a while now....
https://ntrs.nasa.gov/archive/nasa/casi ... 002627.pdf
https://archive.triblive.com/news/wire- ... i-icing-2/
You are here.
Willjet
Fri May 10, 2019 5:26 am
Thank you for the pictures. For a lay person, how would airliner deal with ice build up that formed enroute? Do they usually melt away on approach or would the FMS factor in the added weight/lost lift?
Fri May 10, 2019 6:16 am
The FM has no idea about extra drag from icing. It only knows a calculated model based on the history of the airframe, plus any CDL/MEL items added for that particular flight.
There are three things that can be done if you have ice buildup.
- Turn on engine anti-ice. If the build up is heavy, turn on wing anti-ice. These will melt away ice on some of the exposed surfaces.
- Move to warmer air, either laterally or vertically.
- Speed up if possible.
kalvado
Fri May 10, 2019 11:00 am
In a sense, there is at least one implication of extra drag:
as far as I remember pre-takeoff requirements for ice on top and bottom surface of the wing are a little bit different. That is to account for more critical airflow disruption.
Fri May 10, 2019 12:53 pm
Indeed. Some ice on the bottom surface is acceptable, but never on the top. (Type dependent...)
However it's not like we can program a number in the FM to account for drag from icing.
kalvado
Fri May 10, 2019 1:25 pm
I can see two major reasons for that, correct me if I am wrong:
Icing effects are not fixed, they can change outside of pilot's/FMS control. Good luck finding out that there was more drag than expected half-way to Hawaii.
Extra drag can come with strings attached, like disrupted airflow and loss of lift. Again, good luck gambling with those.
So avoidance/elimination strategy seems a wise way to handle it.
Users browsing this forum: ikolkyo, Okcflyer and 26 guests
