greg85 wrote:I suppose they quietly parked the project.
TSS wrote:greg85 wrote:I suppose they quietly parked the project.
Good one.![]()
Back to the original question, I'd guess they decided the ability drive the plane like a car during the short time it is maneuvering on the ground wasn't worth the weight penalty incurred while the plane is in flight.
mxaxai wrote:TSS wrote:greg85 wrote:I suppose they quietly parked the project.
Good one.![]()
Further:
How well does the system handle the regular shock loads on touch down?
How much additional maintenance does it need? Does it interfere with access to parts that require regular inspection or replacement (e. g. tyres)?
How expensive is it to certify, and to manufacture at the required rates?
I reallly like the idea and it could help to significantly reduce noise on the apron, as well as emissions on airport property. But for now it appears to be shelved.
TSS wrote:Well if you use external tugs, you'd have to provide tugs to and from the runway. Unless these tugs are remote controlled from the cockpit, this adds significant personell cost. I also think that many airport tugs are actually derived from industrial tugs/vehicles, and most industries probably prefer the flexibility and endurance gasoline (diesel) provides over the low noise and high torque of modern electric motors.My question in one of those other threads was why not use the new electric motors to build quiet, efficient electric aircraft tugs instead?
