BAorAB
787-10 In service Performance
Sun May 05, 2019 10:32 pm
We've heard so many mixed views about the actual performance and capability of the 78X. One of my friends at United Fleet Operations stated the aircraft performance, capability and economics have far exceed the expectations of everyone at the airline and they continue to look for ways to push the aircraft's limit. I thought i'd check into his comments and found some interesting history below. Many state it's a 8hr aircarft, some say 10hr, some even say 7hr. He stated he'd heard Scott Kirby said in a meeting that "this is possibly the best all around aircraft ever built"
Looks like United have one deployed TLV-EWR and you'll see from the link below it's up to 11:5hr flight, regularly 11+ hrs. They've also sent to LAX to NRT. My friend confirmed there's been no seats blocked or cargo restrictions on UA 84/85, and at least 3 of the flights since May 1 have flown with 100% load factor.
So 787-10 flies 11.5hrs with 100% passenger load and a sufficient amount of cargo.....thoughts?
https://www.flightradar24.com/data/flights/ua85
Stitch
Re: 787-10 In service Performance
Sun May 05, 2019 11:35 pm
The 787-10 is effectively a slightly longer, slightly heavier 787-9 and the 787-9 is an extremely long-legged aircraft. So it is not surprising it too can handle long missions.
Also, I think people often do not realize how capable the 787 and A350 families are. For example, UA807 IAD-PEK was blocked at almost 14 hours flight time and it took off over 30,000kg below it's maximum ZFW and 16,000kg below it's MTOW at 71% passenger load (which I believe is around average) with 3800kg of cargo and 3900kg of passenger bags. So it still had payload and fuel weight to spare.
And both the 787-9 and A350-900 are doing over 17 hours with 25,000kg-plus payloads.
behramjee
Mon May 06, 2019 12:17 am
Yes what your friend at UA has said on the B781 capabilities are indeed true and thats why it will be an excellent trans-atlantic work horse pre-dominantly during the 2020-30 decade. With regards to flying range, it was never going to be 7-8 hours but always in the 11 hour category approximately. Now we see AMS-SFO + TLV-EWR going to be operated by it which has a 11:55 block time.
I think you thought the flying range was less is because Emirates officially stated when they ordered the B781, that it would be used on flights up to 9 hours of flying time ex Dubai only.
usax777
Mon May 06, 2019 12:28 am
787-10 seems to be performing extremely well. It can handle most of the long-haul mission UA has. I wonder 787-10 can be ultimate choice for UA's 77E replacement. Given the 78J performance we see so far, the chance of UA take delivery of A350 is ZERO.
Stitch
Mon May 06, 2019 12:38 am
The 777-200ER and A350-900 can fly around 1500nm farther at similar payload weights to the 787-10 (55,000kg), but how many of UA's 777-200ER missions exceed the 787-10's usable range is likely sub-20%.
strfyr51
Mon May 06, 2019 2:08 am
Boeing has of late been understating it's range projections, And it's being found that the airplanes have considerable longer legs than advertised. Under promise and overdeliver? Could be!!
BAorAB
Mon May 06, 2019 4:12 am
He stated the A350's are definitely coming because the contract cancellation cost is simply too steep. He stated its common agreement within United leadership that the A350 order was a small mistake that started in 2009 and just kept growing, however given it's solid performance and suitability to replace the 74 -777's in the fleet, the best business decision is to keep the order. Qty 25 A359 was too small as odd ball fleet, was changed to Qty 35 A35X and then back to Qty 45 A359. Still leaves almost 30 777's to be replaced probably by 78X
N809FR
Mon May 06, 2019 4:15 am
I doubt Boeing would under promise to the extent that the -10 has so few orders compared to the -9. I think it’s more along the lines of a.net saying it’s only good for so much, without any real world knowledge.
Similar to people claiming the A350 barely has the legs for a 5,500+ nm flight.
ElroyJetson
Mon May 06, 2019 4:54 am
It is interesting to see these 787-10 threads pop up from time to time. Lightsaber has said the 787-10 can fly 5000nm against winter winds with full pax and bags and meaningful cargo. I have no reason to disbelieve him. Think 35t of payload. Anything TATL is a go and West Coast to Japan, Korea, or Bejing is fine.
The 787-10 is easily an 11-12 hour plane. Beyond that distance their are better choices if you want to carry meaningful payload. The capability of the 787-10 should not surprise anyone at this point. If cannot do everything, but it is a very, very good aircraft.
707 717 727 72S 737 733 737-700 747 757 753 767-300 764 A319 A320 DC-9-10 DC-9-30 DC-9-50, MD-82 MD-88 MD-90 DC-10-10 DC-10-40 F-100
MoKa777
Fri May 10, 2019 12:01 pm
Stitch, if you don't mind me asking, may you please clarify this post.
UA807 you reference was operated by a 787-10 with those figures?
Never be proud. Always be grateful.
Stitch
Fri May 10, 2019 2:10 pm
Yes. Flown on 14 February of this year per the original poster of the data.
reidar76
Fri May 10, 2019 8:06 pm
Any payload - range chart available for the 787-10?
justloveplanes
Fri May 10, 2019 11:51 pm
779?... possibly why they dialed back from the A35X to A359.....
DocLightning
Sat May 11, 2019 12:35 am
I also think people don't appreciate just how long something like 5,000nmi is. Most regular people never take a flight that long in their lives. As much as we talk about 7,000+nmi routes and ULH routes, most people will never fly them.
-Doc Lightning-
-Carl Sagan
Sat May 11, 2019 2:01 am
Only at a very large airline would you call 25 "too small an oddball fleet". :D That's bigger than many whole airlines.
You need about 400 pilots for 25 A350-size aircraft. Seems like a big enough number to support the number of trainers and managers required.
ElroyJetson
Sat May 11, 2019 4:38 am
Agreed. My longest flight was JFK-FCO. Roughly 4000nm and 9 hrs. I've had family fly LAX-LHR or CDG-MIA. But again, all under 5000nm.
Not too many folks will ever fly beyond this distance. The 787-10 can fly 95% of long haul flights very efficiently. Why stress about the few outliers.
Sat May 11, 2019 10:17 am
9 hrs is not considered as being long haul.
thepinkmachine
Sat May 11, 2019 10:21 am
Depends where... Quoting the classic from BBC “People like us - pilots”, anything longer than LHR-AMS is longhaul ;)
"Tell my wife I am trawling Atlantis - and I still have my hands on the wheel…"
Sat May 11, 2019 10:23 am
I hear you :)
MoKa777
Sat May 11, 2019 12:40 pm
Impressive! The 787-10 is more capable than I first thought.
tealnz
Sun May 12, 2019 7:17 pm
I think the fan club might be getting over excited about what the 78J can do at the outer edge of the envelope. It was designed as a higher capacity/shorter range version of the 789. It is clearly a great airframe for regional routes and for trans-Atlantic or US West Coast to North Asia. But it's not going to work for eg trans-Pacific routes from Oceania or Southeast Asia to Western Europe. NZ, for example, have said they are interested in it for their future fleet – but for Asian routes, not trans-Pacific.
PS What's the story with TLV-EWR? From FlightAware it looks as if the -10 has been replaced by the 77W. Is that just a seasonal thing or a permanent change?
gloom
Mon May 13, 2019 6:55 am
a.net experts seem to forget one thing, quite easily.
78J is exactly a larger 789. Longer fuselage, more seats, higher OEW/DOW variant. It was made to move more people over LongHaul rather, as opposed to 789, which was made to carry less people on ULH ranges.
This however would not stop this plane from ULH flights, as it's exactly same tank capacity etc. The difference is less payload over same distance compared to 789 (at ULH means here 5000nm+). So, basically if it's one off, you can probably take full board over 6000nm sector, and it could be cheaper than having another 789 just for the route. It will cost more to fly due to weight, but there's offset you have the plane for main market (may it be TATL, transcon for USA, or intra-Asia flying).
If you're after 5000nm+ sectors and cargo, you're probably off for a different plane, be it a subfleets of 10 and 9 (9 lighter than 10, so more revenue with same TOW), or going to 359 like Finnair did for much more cargo and pax at the same time.
The question is not "is it capable", I guess we all know it is. The question is "is it better positioned than other". It is on all conditions where you can fill the board. If load factors are small enough to take 789, or high enough [cargo] to fill a bigger machine like 359, you're likely to go for split or the other machine (depending on how's the situation across connection network).
Adam
CRJ900
Mon May 13, 2019 2:30 pm
I wonder if SQ looked into using the B787-10 as a ULR - if they installed the current cabin config used on the A359ULR, how far could a 254T B787-10 fly...?
Come, fly the prevailing winds with me
Stitch
Mon May 13, 2019 9:25 pm
Using the ACAP, in a Boeing 330-seat OEM configuration with a 20,000kg payload (which I believe is what has been given as the average for SQ's A359ULR flights) range is around 8000nm. Of course, the ACAP is not representative of real-world flight planning so actual range would be less, perhaps countered somewhat by a lower Basic Empty Weight due to the lower seat count.
All that being said, SQ's A350-900ULRs block a bit over 111,000kg of fuel on SIN-EWR and the maximum fuel capacity of the 787-10 is a bit over 101,000kg. Also, just going by OEM OEW plus maximum usable fuel, you're at 246,000kg so usable payload at best would be around 10,000kg. And with the A359ULR's block fuel load, payload is effectively zero.
Mon May 13, 2019 11:39 pm
A still air distance of 8000 nm is not enough to do JFK-SiN, need a still air range of 8500 nm+.
sciing
Tue May 14, 2019 6:42 am
The 787-10 is quite MTOW limited. The 2nd kink in the payload range chart (start fuel limit) is at quite low payload, as Stich wrote with full tanks you have just 10t left. So larger tanks as for the A359ULR will not help. Less weight always help for range, but better use a frame with lower OEW a 789.
WIederling
Wed May 15, 2019 9:00 am
Reason why the A333 only got the Center Tank enabled with the very recent MTOW markups.
( Apparently not available for the 787 platform.)
Murphy is an optimist
Users browsing this forum: Hosta, smaragdz and 45 guests
