dfwjim1
Hand flying commercial jets - routes
Sun May 19, 2019 11:38 pm
Just curious...are there any routes out there in which commercial jets are hand flown from take off to landing?
GalaxyFlyer
Re: Hand flying commercial jets - routes
Sun May 19, 2019 11:46 pm
Not where hand flying is required, at captain’s discretion unless required for the approach by policy or regulation. CAT II & III are usually autopilot required as are many RNP AR approaches.
In the old days, 80s, I flew with lots of pilots who hand flew great majority of the time. B727 autopilot was rough enough that it was a cruise device. I’d fly frequent short legs take-off to touchdown in the Global.. The C-5 autopilot was such we hand flew most of the time except late climb, cruise and start of descent, of course PARs and local proficient flying was hand flying. Flew two NAT crossings by hand, one in each direction when the A/P wouldn’t couple.
GF
Woodreau
Mon May 20, 2019 12:09 am
Probably the last flights flown under Part 121 that were routinely flown without autopilot were beech 1900 flights. The airlines just didn’t pay for the autopilot option.
Flights can be flown without autopilot or if the autopilot is deferred under the MEL. Without an autopilot the aircraft is restricted to nonRVSM airspace (below FL290 or above FL410. So flights can occur without an autopilot.
I remember one turn DFW-BUF on a CRJ-700, the autopilot was deferred. I didn’t think we would go and that the captain wouldn’t accept the aircraft but he did. because he was a management pilot he rarely flew and so he was also getting line checked.
So while we’re on the way to Buffalo, the captain is handflying. The flight attendant calls up and mentions that several of the first class passengers declined their meal and if we wanted lunch? Of course the check airman and I wanted lunch. So we’re both having lunch and chatting away while the captain was working his butt off maintaining altitude in cruise.
I would do DFW-ACT or DFW-GRK turns without autopilot because the flight is just 12-16 minutes from off to on.
GalaxyFlyer
Mon May 20, 2019 12:18 am
You’d really cancel for a deferred autopilot? How hard is it to hand fly? Like I said, I’ve done two Atlantic crossings in C-5 and six on non-autopilot-equipped fighters. Do a 7.8 with 7 refuelings or a 10.2 with three ARs.
Actually, RVSM made it easier to hand fly—you had to stay below F285 and much to to hand fly down low.
GF
TTailedTiger
Mon May 20, 2019 12:59 am
GF
I was under the impression that the autopilot was a required item at most airlines. Doesn't the pilot flying load the flight plan into the FMS and the pilot monitoring checks it? I'd be afraid something would go wrong when winging it and breaking out the nav charts. There is a reason commercial flights don't crash on a regular basis like they did up until about the early 80's. Automation and crew resource management have the biggest contributors to aviation safety. If I heard that a critical system like the flight management and autopilot were inop, I'd remove myself from that flight.
meecrob
Mon May 20, 2019 1:24 am
GF
I understand what you are getting at TTailedTiger, but think of it this way: The pilots created the flightplan themselves, then inputted it into a computer for reference. Its not like they put in the departing airfield and the arrival airfield, and the computer came up with the flightplan. Autopilot and FMS are only tools. Would you not drive your car if the GPS nav and cruise control broke? I'd bet you could still manage to drive and navigate, no problem.
william
Mon May 20, 2019 1:56 am
SWA pilots used to hand fly a lot of DAL-AUS and AUS-HOU legs back in the day when SWA did not order its 737s with the latest gadgets.
william
Mon May 20, 2019 1:58 am
On some DFW-GRK flights they perform a maneuver I call the corkscrew about 20 west of Waco, or over Gatesville. Its a maneuver I guess to scrub speed and altitude, but descending in a cork screw. Would you hand fly that?
CosmicCruiser
Mon May 20, 2019 2:12 am
did a couple, one being MEM-SEA with a deferred A/P in a 727. The F/O & I took turns flying the jet.
GalaxyFlyer
Mon May 20, 2019 3:08 am
GF
An airplane should never be allowed to be in position where the pilots can’t take over and hand fly it. The autopilot is an aid to reduce workload, not the system that flies the plane. We use iPad or paper charts all the time.
The reason for better safety records since the “bad old days” is better technology, specifically EGPWS, TCAS, the FMS that displays the flight plan eliminating the pilots’ old need to develop a mental picture of the aircraft’s position. Plus we’ve learned taking off or landing in a TRW is risky and dumb, all crew members are valuable, but Skygods were not as common as thought. I flew with plenty of good CRM proficient old heads. Autopilots, FMS and lots of other equipment are subject to MEL deferral under set rules and captain’s acceptance.
GF
slcguy
Mon May 20, 2019 6:14 am
GF
Hand flying doesn't mean they are breaking out the old paper charts. Pilots can very easily follow the programmed FMS/FMC route, the difference is they are following the FMS/FMC route (the purple line on their displays) controlling the aircraft themselves versus the autopilot/auto-throttle. Most pilots would like to hand fly more but in a lot cases company policies require the use of the autopilot soon after takeoff. In most cases though, the pilots would probably only want to hand fly in good weather and just departures and approaches. For a jet in the flight levels it can be tedious and exhausting to maintain exact altitude, speed and course at cruise by hand and unless a very short trip most pilots would not want to fly the entire trip by hand. I would not want to fly with any pilots that can't fly a plane by hand, Asiana 214 comes to mind, they relied on automation, and didn't even do that well and crashed a perfectly good aircraft in conditions that any pilot would love to fly hand fly.
Mon May 20, 2019 7:11 am
As slcguy says, hand flying and an FM route aren't directly correlated. The flight director will show guidance for the FM route whether the AP is on or not. The flight mode annunciator will display the same modes, and the flight director bars will show where to point the nose. The difference is that the human pilot is following FD guidance instead of the autopilot.
I'm guessing this is the reason our MEL states both autopilots can be inop for three sectors (with certain restrictions) but AP/FD inop is a no-go item.
AABusDrvr
Mon May 20, 2019 9:37 am
On the 737 at my shop, any flight with the auto pilot deferred must be limited to 3.5 hours, or less. On a good WX day, at low traffic airports I'd probably be ok with it. Bad WX, going to a busy airport, or a multiple leg day, I'd lean towards refusing the airplane.
VSMUT
Mon May 20, 2019 12:15 pm
I've handflown an entire trip just for the fun of it once, and I've had autopilot failures a few times necessitating it. In my opinion, it is a good exercise to try to handfly it in cruise from time to time, but it is a tedious and boring task best left to the autopilot under normal conditions.
Takeoffs and landings are a different case completely.
As for flights done completely by hand, on the ATR you would most likely find them on really short flights done under VMC conditions between small airports. Air Tahiti's flight from Papeete to Moorea and similar short inter-island services are a good bet, but could still be done in autopilot.
This, a million times this. Many airlines, Irish ones in particular, have adopted the complete opposite mindset. They consider the autopilot the basic/primary mode of flying, while handflying is to be done only under specific conditions, best avoided completely. Completely bonkers.
Max Q
Mon May 20, 2019 11:44 pm
Used to hand fly the entire leg on the 727 just for fun on the shorter
legs, it was such a delight to fly
I particularly remember sectors like IAH-SAT and EWR-DCA where I never turned on the autopilot
GGg
BoeingGuy
Tue May 21, 2019 12:42 am
IIRC, the Boeing MMEL states you can dispatch without the Autopilot for flights of 5 hours or less. Only if approach minima allow it also. Of course customers can choose to adopt more restrictive policies.
Redbellyguppy
Tue May 21, 2019 4:45 pm
The only thing that makes hand flying somewhat of a nuisance is that the fa and pax keep moving around, so it changes your trim. Other than that it’s easy and frankly, my happy place.
Woodreau
Tue May 21, 2019 4:56 pm
GF
I didn’t think we’d cancel. I thought he would see if he could do a tailswap. Leave the autopilot deferred plane to do short turns.
I don’t remember if we swapped flying back and forth on the flight or not. I do remember me and the check airman eating out lunch and remarking that he was working too hard.
I’m not familiar with the corkscrew maneuver you’re talking about. But for DFW-ACT and DFW-GRK we would routinely do these flights with out the autopilot because the flights were less than 20mins.
ACT is DARTZ.ACT. GRK is DARTZ.ACT TENAT
The controller would routinely leave us high going to ACT so it was always a high speed dive into ACT with the brakes deployed.
I always liked checking in with GRK tower because it was a military field. “XYZ flight 1244 visual one five, gear up.” I assume it annoyed the controller because the answer was always “check gear down”. And our response would be “roger double checked gear up.”
triple3driver
Tue May 21, 2019 5:53 pm
We usually would handfly the CRJ for very short hops, I don't remember how long they were exactly, but I remember thinking whenever I was pilot flying how far I progressed, that not too long ago I was flying little Cessnas and now I was in control of an entire passenger jet. A truly unforgettable feeling. It's a similar situation with the 737, there's only been a few times that I remember when we handflew it for the whole flight, usually on extremely short hops or ferries. The A330 is a different story, since we usually fly it trans-Atlantic, we only handlfly it at the beginning and end of the flight, we don't really fly it ourselbves during cruise due to the length of the flight, although sometimes over the drink we do give handflying a go. I will say though, that I, among many, don't turn on the autopilot until we reach cruising altitude or maybe lower depending on weather, and we usually do our descents manually weather permitting.
If you can walk away from it intact, it was a good landing!
N1120A
Wed May 29, 2019 4:23 am
The US regionals have started encouraging more handflying, especially when outside RVSM airspace. I know airline guys who actually rely more on the AP during short hauls - think LAX-SAN, where you get a bunch of frequency changes and are on a departure, climb, cruise for about 5 minutes and on an arrival and approach - than they do on longer flights where they can sit down and get relaxed. Of course, above FL280, the AP needs to be on.
Yikes!
Wed Jun 05, 2019 4:07 am
With non-complex DP's and/or STAR's, there is no reason a flight cannot be hand flown other than passenger comfort limitations. More and more airlines are encouraging pilots to fly to top of climb and from top of descent to re-familiarize themselves with "flying the airplane" .
With a complex DP, it is well advised to use the AP at the soonest opportunity to avoid space/noise infractions.
FlyHossD
Wed Jun 05, 2019 12:34 pm
When I was IAH based, I used to hand fly IAH-AUS and/or AUS-IAH just for the sake of proficiency. There was one first officer who objected to the increased workload it placed on him, so I used the autopilot in that case..
I also remember a 727 flight with an FAA Air Safety Inspector in the jumpseat. I hand flew it to cruise altitude, but when I tried to turn the AP on, it wouldn't engage. Just a moment later - seconds after I'd pointed out this dilemma - the #1 ADI failed. So I hand flew the entire 90-ish minute flight; the 727 handled so well that it wasn't difficult.
stratosphere
Wed Jun 05, 2019 12:57 pm
GF
At my last employer NW on the DC-9 at least you would almost always see the crew refuse the airplane for an autopilot inop. Auto-pressurization inop is another one the crews would refuse..
GalaxyFlyer
Wed Jun 05, 2019 2:07 pm
Didn’t happen at Eastern, you’d have a conversation with the CP unless it was low weather. Even during the “Max Safety” effort. But then NWA was “Cobra Airlines”.
GF
BravoOne
Wed Jun 05, 2019 2:28 pm
GF
As I recall hearing Eddie Rickenabcker was famous in his early days at Eastern, for not even having autopilots installed on his early piston airliners?? A pilots, pilot:)
I seem to recall flying the 707/720 across the Pacific on one or more occasions without the benefit on an autopilot, especially if you were homeward bound.
GalaxyFlyer
Wed Jun 05, 2019 2:49 pm
True story about Capt Eddie, along with all the other stories. It was like his ghost inhabited Ops. I flew with several guys, Don Staton comes to mind, who hand flew most of the time. Don would hand fly while eating lunch. F/O would always volunteer to take it, invariably, “I got it, son”. He was pretty smooth with old Boeing, too.
Homeward, lots of things are okay. My last hand flown crossing was one. Leveled off the Lippe Radar, couldn’t engage the autopilot. The F/E and I tried everything we could think. About 30W, one of the pilots tried the yoke disengage button and it coupled.
GF
RetiredWeasel
Wed Jun 05, 2019 7:51 pm
Pilots don't arbitrarily say they won't fly the aircraft if the auto pilot is inop. They refer to the MEL and read the restrictions and that's usually after the dispatcher is involved and is fully aware of the restrictions. If the MEL says it is acceptable fly with restrictions like number of flights, hours or days, then refusing to fly it will find the aviator in front of the chief pilot trying to explain his justification. That has happened but rarely. As far as NW 747-200 go, I seem to remember if both autopilots were inop, the MEL prohibited transpacs.
blacksoviet
Wed Jun 05, 2019 10:44 pm
When did Silver Airways retire the Beechcraft 1900?
Zeke2517
Thu Jun 06, 2019 4:12 pm
February of 2014, according to wiki.
chimborazo
Thu Jun 06, 2019 6:56 pm
Out of interest can anyone describe the Airbus way of hand flying at a cruise level. I understand the 737 for example having flown the sim manually but wonder what the difference is with the “trajectory control” and no manual trim switch on a bus. What happens when passengers move..?
Woodreau
Thu Jun 06, 2019 7:02 pm
You point the nose where you want the airplane to go and let go or rather let the sidestick center. The plane keeps the nose pointed where you let go of the sidestick.
As passengers move around or drink carts roll up and down the aisle you move the sidestick to counteract the change just like any other plane. Instead of trimming to hold the new attitude the plane does it for you.
JAGflyer
Thu Jun 06, 2019 8:46 pm
All the pilot has to say is he/she is not comfortable due to "safety" reasons. You can't question one's judgement and once you say it's due to a safety concern most respectable carriers won't push it any further. It's no longer (at least in Europe/North America) a culture of "just do it or you lose your job". As a dispatcher, I can think of more pilots who'd veto flying without a functioning A/P than those who would take the aircraft.
If you flew today, thank a Flight Dispatcher!
GalaxyFlyer
Fri Jun 07, 2019 1:13 am
Maybe I’m old fashioned, but if the A/P is MEL’d, there isn’t an operational requirement for the autopilot and fatigue isn’t a justifiable reason, I’d be hard pressed to turn a plane down. Low IFR, RVSM/RNP required, late in the duty period, yes; but just willfully saying no, I don’t get. You’re a pilot, you can’t hand fly, really?
GF
Fri Jun 07, 2019 2:49 am
As Woodreau says, you just point the nose where you need it, and continually correct any deviations. Just like any other aircraft except for automatic trim. It's very intuitive. You can optionally switch to the "bird" which shows you exactly where the aircraft is going, but the normal flight director is easy enough to follow. On the 350 you can kinda have both by using the velocity vector display, which shows where you are going, in addition to the flight director, which shows where the nose is pointing.
RetiredWeasel
Fri Jun 07, 2019 3:41 am
Well I don't dont know what airline you worked for, but at the one I worked if the MEL said it was OK to fly with or without some restrictions, and a pilot refused (might take a couple of times) then he would most definitely find himself in front of the chief pilots desk to explain his actions. Especially if other pilots are flying the same aircraft with the MEL restrictions and the union hasn't stepped in to defend him. It happened at my former airlines, and the pilot was basically grounded for medical reasons. (not autopilot issues but other). Now having said that, I'm pretty sure there were autopilot MEL restrictions (like both not working) that kept the 747 from launching on extended flights. And I don't know any pilot at the old NW who would enjoy flying an 11 hour transpac without at least one autopilot working.
N766UA
Fri Jun 07, 2019 2:46 pm
Just put the thing in the flight director! For the 2 times a year you face a deferred AP it isn’t that challenging.
So here’s a question: under what circumstances is autopilot actually required? A deferred AP keeps us out of RVSM airspace and prohibits Cat II approaches, for example. What about ETOPS? I was riding on UAL to Hawaii once and we flew in circles burning gas for hours before returning because the autopilots weren’t working...
GalaxyFlyer
Fri Jun 07, 2019 4:24 pm
Curious, that, i wonder if they had enough fuel to fly out at F280.
GF
Fri Jun 07, 2019 10:56 pm
With the caveat that this is operator MEL, and not the manufacturer MMEL, a quick check shows no ETOPS with both APs inop on the A330. However, no such restriction on the A350.
AABusDrvr
Sat Jun 08, 2019 2:33 am
It's not about "challenging", it's about overall safety. I find hand flying straight and level mind numbingly boring, but on a departure, or arrival, in complex airspace it multiplies the work load exponentially. When you hand fly the jet, you load the other pilot up, and distract them from actively monitoring everything else, like they are supposed to be doing.
As long as I could articulate why I wasn't comfortable taking an airplane with anything MEL'd, I'd never hear another word from my chief pilot.
Our 73's have the HUD, so CAT II/III approaches are always hand flown, as long as the HUD is working, we are good to go. But with the autopilot MEL'd, we cant do RNP approaches at all, or "other than ILS" approaches with weather worse than 1000' and 3.
N1120A
Sat Nov 09, 2019 2:18 am
I bet the reason for the 3.5 hour limitation is partly financial. On most days, it is much more expensive to be limited to FL280 on longer flights.
Nicoeddf
Sat Nov 09, 2019 10:54 pm
Well, in my opinion it doesn't make a whole lot of sense to handfly with FD.
If handflying, I suggest doing it basic and raw data, if following the FMS "needle" would even be considered raw data.
Flying shorter hops in the CRJ by hand take off to landing is nice once in a while, but really quite boring and no challenge.
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
CosmicCruiser
Sat Nov 09, 2019 11:35 pm
GF
Required only for certain tasks like CATII, III approaches and as several have said RVSM airspace. Just because you hand fly the route doesn't mean the flt pln falls out of the FMS. You still follow the flt director and have full FMS. Before RVSM we hand flew a 727 from MEM to SEA. We just took turns and it wasn't a big deal. You may find your chief pilot interested in having a chat if you removed yourself for that reason. And BTW what you call that reason?
Nicoeddf
Sun Nov 10, 2019 10:57 am
CosmicCruiser wrote:
GF
Sorry Boss, I am not sure I can fly the plane I'm certified to fly... ;-)
CosmicCruiser
Sun Nov 10, 2019 1:43 pm
That would be about it. At the least you'd be removed from the trip without pay. Not a good trend.
Woodreau
Sun Nov 10, 2019 2:20 pm
It would go over just as well as the FO that told me we couldn’t go because the weather is below his personal minimums. (The weather he was complaining about was 200-1/2)
I thought he was cracking a joke but it turned out he was serious. I told him he could call the chief pilot and tell him that.
CosmicCruiser
Sun Nov 10, 2019 4:14 pm
oh that's funny. Did the chief pilot tell him to go back to his Navajo job? lol
dfwjim1
Sun Nov 10, 2019 10:32 pm
For those you in or formally in the military is autopilot ever used in air-to-air refueling?
GalaxyFlyer
Sun Nov 10, 2019 11:10 pm
By the tanker, usually; by the receiver, never. In C-5s, as the receiver pilot, we had to demonstrate both tanker autopilot ON and autopilot OFF refueling. We could push the tanker around pretty badly, if we weren’t smooth coming into contact and staying there without a lot of “big” moves. In fighters, I suspect they didn’t know we were back there, except the A-10 which was so slow the tankers sometimes needed to put some flap out. Like all formation flying, it’s about anticipation and smoothness in handling.
GF
VSMUT
Mon Nov 11, 2019 2:57 pm
GF
What guides the autopilot onto the tanker?
GalaxyFlyer
Mon Nov 11, 2019 3:41 pm
The tanker flies on autopilot, the receiver pilot hand flies from the rejoin thru the entire refueling and separation from the tanker. The receiver enters the track or anchor 1,000’ below the tanker, this can be on autopilot, once tanker is in sight, it’s all autopilot off for the receiver pilot as he/she climbs to join up. About a mile astern, put the tip of the boom on the nose of the tanker puts you on a nice line to go to pre-contact, that’s about 50’ aft of the boom. It’s pretty basic formation flying from there, keep the tanker in the right place in the window, monitor the lights, if it helps. Be smooth, small corrections. 20-30 minutes is a workout.
As to finding the tanker, air-to-air TACAN, ATC radar or, if equipped like fighters, airborne intercept radar. I always did it TACAN and visual as the planes didn’t have AI radar.
Users browsing this forum: No registered users and 17 guests
