ojjunior
What is the dynamics or reason behind the turboprops rotating blades in opposite directions?
Fri May 24, 2019 5:19 pm
Does this generate additional power?
How is it advantageous for the aircraft?
For example, the A400M rotates blades in opposite directions on each wing
The AN-22 rotates blades in opposite directions on the same axis.
Curious about the engineering behind it...
The real reason it does exist...
FluidFlow
Re: What is the dynamics or reason behind the turboprops rotating blades in opposite directions?
Fri May 24, 2019 5:30 pm
It is to balance out the forces. You have less vibrations that way. you can observe this on helicopters, if the rotor in the back fails the cabin start to turn counter to the rotation of the blade. The same force applies on the nacelle of the propeller engine. To balance that our you have counter rotation on the second set of fan blades.
Karlsands
Fri May 24, 2019 5:43 pm
P factor
LightChop2Chop
Fri May 24, 2019 5:45 pm
boats / ships with twin (or more) screws almost always counterrotate for the very same reasons.
kczombie
Fri May 24, 2019 6:08 pm
BTW, I just love the A400. Just a sweet thing to look at.
ojjunior
Fri May 24, 2019 6:17 pm
Makes all sense, thanks for that.
Yes it is.
I'm assuming you enjoyed seeing Mission: Impossible-Fallout Effect, didn't you?
masi1157
Fri May 24, 2019 7:17 pm
That may be true in the case of 2 fans rotating on the same axis, but on the A400M it isn't so, it has 1 fan per engine (axis).
Gruß, masi1157
508 different segments on 100 airlines to 210 airports in 55 countries
WayexTDI
Fri May 24, 2019 7:19 pm
Gruß, masi1157
It still balances the torque effect when the engines are accelerated, and prevents the plane to veer left or right during the take-off roll.
jimatkins
Fri May 24, 2019 7:40 pm
Heard somewhere the A400 has counterrotating props to sweep air up over the wing for more lift. Counterrotating blades like on a Tu-95 or An-22 are to keep the blades shorter to avoid compressibility effects on the tips of a long blade approaching speed of sound as they rotate. Lose efficiency if that happens. Also bad effects from the sound waves produced. Douglas C-133 had skin fatigue issues from the noise of big 3-bladed props close to the fuselage.
Max Q
Sat May 25, 2019 12:16 am
Do they ?
Sounds like a good idea but never heard of that
Guns and the love of them by a loud minority are a malignant and deadly cancer inflicted on American society
dr1980
Sun May 26, 2019 12:35 am
As a counter example, on the Q400 both props spin in the same direction so crews need to make trim adjustments when power changes are made to keep the aircraft level.
Dave/CYHZ
strfyr51
Sun May 26, 2019 4:51 am
the practice also allows for a smaller Vertical stabilizer with less rudder authority.
Florianopolis
Sun May 26, 2019 11:40 pm
Have we considered the possibility that they know it works, but don't know how ?
When developing another quad-engine turboprop with very powerful engines, Lockheed had such a hard time getting their arms wrapped around stall on the C-130J that they just gave up and installed a stick-pusher.
http://www.flightglobal.com/news/articl ... oblem-804/
http://www.flightglobal.com/news/articl ... her-24837/
(Remember the AC-130J written-off after departing controlled flight during a max-sideslip test flight that stalled the vertical stabilizer, and the recovery exceeded the G-limit?)
So perhaps Airbus decided they wanted it to be symmetrical, played around with it in the wind tunnel and CFD, and ultimately determined that "down between the engines" counter-rotating props was the best solution. http://www.flightglobal.com/news/articl ... rs-181755/
Did it solve everything? It probably solved asymmetry problems with propwash, but the airplane still has weird aero problems. Apparently refueling helicopters is still too frightening, and be careful jumping paratroopers out both sides of the airplane at the same time: they might bang into each other behind the airplane. http://aviationweek.com/defense/a400m-h ... ch-project
PS: You know the P-38? They built it with counter-rotating engines, decided the prop rotation was creating unfavorable interactions with the boomed stabilizers, and switched the engine sides. Aerodynamics is weird like that.
LightChop2Chop
Tue May 28, 2019 1:45 pm
Max Q wrote:
Do they ? Sounds like a good idea but never heard of that
Even the twin Mercury 200s on my boat are counter rotating. If both propellers turn is same direction the boat noticeably tilts to starboard when up on plane and you either have to trim one engine slightly higher, shift some weight around or install trim tabs to counteract. it not dangerous just not as efficient.
kurtverbose
Tue May 28, 2019 5:43 pm
From FlghtGlobal in 2004: -
Airbus Military has chosen a unique "handed" propeller concept for the A400M airlifter in a bid to mitigate some of the technical risk associated with integrating what will be the West's most powerful turboshaft engines on to the airframe.
Also known within Airbus as the "down between the engines", or DBE, configuration, describing the downward sweep of the blades between each pair of wing-mounted, 10,700shp (8,000kW) engines - the design will ensure a symmetrical airflow over each wing and allow a simpler flap system and smaller horizontal stabiliser and fin, according to the manufacturer. It will also reduce vibration and noise levels in the cargo bay and allow air-drops to be performed more effectively.
The downside is that while the turbomachinery in all four engines will be identical, two engines will require additional gearbox components, a larger oil system and a mirror-image propeller design, increasing support costs.
Airbus Military commercial director Richard Thompson says "concerns had always existed"about rotating all four 5.33m (17.5ft) - diameter propellers in the same direction, after Lockheed Martin hit propwash problems in the C-130J development programme. He adds that adopting the handed approach meant "we had to do a lot of trade-off studies, which we had the resources to do only after launch.
"This is the most effective solution. It is a risk-reduction measure which has been confirmed by windtunnel tests to be the right direction. The impact on cost is marginal in terms of 30-year life-cycle costs."
Production of parts for the first EuroProp International (EPI) TP400-D6 turboprop has begun and first run is scheduled for August next year at MTU Aero Engines' Ludwigsfelde final assembly site. Series production is due to get under way in late-2007 or early 2008.
The engine programme will effectively require two certifications - one for each gearbox/propeller configuration - separated by around three months, says R-R Deutschland TP400 programme director Dr Christian Poensgen. It is expected that the first flight of the A400M, due in October 2007, will be performed with only one of the two engine/gearbox-propeller configurations certificated.
StereoTechque
Tue May 28, 2019 7:04 pm
Counter rotating props on the same axis are for reducing the counter torque effects produced. You can find the same mechanism on the shafts of PW1000G Engines. Counter rotating props on adjacent engines of the same wing results in changing the gearbox, dont know how will it require a larger oil system..
Looking California.. Feeling Minnesota.... R. I.P. Chris Cornell...
longhauler
Wed May 29, 2019 2:14 am
Karlsands wrote:
P factor
I guess no one read this.
It is the main reason for counter rotating props on twin engine propeller aircraft. Basically, what it means is that the down going blade is producing more thrust than the up going blade at any angle of attach higher than zero.
Counter rotating props, clockwise on the left engine, counter-clockwise on the right engine (when viewed from behind) will have the highest thrust closer to the centerline of the aircraft. In a single engine situation, the amount of rudder is the same regardless of the engine lost. Aircraft without counter rotating props (both clockwise when viewed from behind) will require more rudder with the loss of the left engine than the right. (Termed the "critical engine"). And performance will always be predicated on the loss of the ciritical engine.
As noted above, some new and advanced aircraft, like the Q400, (for example) do not do this. There are many reasons ... things like commonality of engines/props for left/right or that there is so much excess power, counter rotating props are not necessary.
CowAnon
Wed May 29, 2019 6:31 pm
For the Kuznetsov NK-12 engine that runs on the Tu-95 and An-22, I'm guessing that the contra-rotating fans have an equal split of power between the front and back propellers. The Progress D-27 engine has the front propeller absorbing more of the power than the back propeller, though -- a 59/41 percent split, IIRC. Air swirling won't be a problem (capturing that wasted energy is the purpose for contra-rotating fans), but does the unequal power distribution cause balance issues?
vikkyvik
Wed May 29, 2019 7:19 pm
Gruß, masi1157
Why do they have to be on the same axis? Props on different axes are still imparting torque to the aircraft.
Chinooks, for example, don't need a tail rotor because they have counter-rotating main rotors.....on different axes.
stephanwintner
Wed May 29, 2019 9:54 pm
longhauler wrote:
Karlsands wrote:
P factor
Thanks for that explanation. I did actually read Mr. Karlsands' comment.But even as an aircraft engines engineer, I didn't know what P factor meant....I imagine many others didn't either....
masi1157
Fri May 31, 2019 1:34 pm
You are right, for the "static" torque the need not. I was taken away by "dynamic" in the thread title and was thinking about imbalance and vibration, which could in fact partly be compensated with both propellers rotating about the same axis.
Gruß, masi1157
DFW17L
Wed Jun 05, 2019 1:58 am
Yes, the A400 is a sweet bird. I bet the Italians had something to do with it. They have such a great sense of style.
Wed Jun 05, 2019 3:34 am
The cockpit is rad as all hell. Most of the pushbuttons, levers and such are the same as on the A350 so it feels familiar, but the panels are all black for that extra covert ops look. :)
