FluidFlow wrote:It is to balance out the forces. You have less vibrations that way. you can observe this on helicopters, if the rotor in the back fails the cabin start to turn counter to the rotation of the blade. The same force applies on the nacelle of the propeller engine. To balance that our you have counter rotation on the second set of fan blades.
kczombie wrote:BTW, I just love the A400. Just a sweet thing to look at.
masi1157 wrote:FluidFlow wrote:It is to balance out the forces. You have less vibrations that way. you can observe this on helicopters, if the rotor in the back fails the cabin start to turn counter to the rotation of the blade. The same force applies on the nacelle of the propeller engine. To balance that our you have counter rotation on the second set of fan blades.
That may be true in the case of 2 fans rotating on the same axis, but on the A400M it isn't so, it has 1 fan per engine (axis).
Gruß, masi1157
LightChop2Chop wrote:FluidFlow wrote:It is to balance out the forces. You have less vibrations that way. you can observe this on helicopters, if the rotor in the back fails the cabin start to turn counter to the rotation of the blade. The same force applies on the nacelle of the propeller engine. To balance that our you have counter rotation on the second set of fan blades.
boats / ships with twin (or more) screws almost always counterrotate for the very same reasons.
Max Q wrote:
Do they ? Sounds like a good idea but never heard of that
Airbus Military has chosen a unique "handed" propeller concept for the A400M airlifter in a bid to mitigate some of the technical risk associated with integrating what will be the West's most powerful turboshaft engines on to the airframe.
Also known within Airbus as the "down between the engines", or DBE, configuration, describing the downward sweep of the blades between each pair of wing-mounted, 10,700shp (8,000kW) engines - the design will ensure a symmetrical airflow over each wing and allow a simpler flap system and smaller horizontal stabiliser and fin, according to the manufacturer. It will also reduce vibration and noise levels in the cargo bay and allow air-drops to be performed more effectively.
The downside is that while the turbomachinery in all four engines will be identical, two engines will require additional gearbox components, a larger oil system and a mirror-image propeller design, increasing support costs.
Airbus Military commercial director Richard Thompson says "concerns had always existed"about rotating all four 5.33m (17.5ft) - diameter propellers in the same direction, after Lockheed Martin hit propwash problems in the C-130J development programme. He adds that adopting the handed approach meant "we had to do a lot of trade-off studies, which we had the resources to do only after launch.
"This is the most effective solution. It is a risk-reduction measure which has been confirmed by windtunnel tests to be the right direction. The impact on cost is marginal in terms of 30-year life-cycle costs."
Production of parts for the first EuroProp International (EPI) TP400-D6 turboprop has begun and first run is scheduled for August next year at MTU Aero Engines' Ludwigsfelde final assembly site. Series production is due to get under way in late-2007 or early 2008.
The engine programme will effectively require two certifications - one for each gearbox/propeller configuration - separated by around three months, says R-R Deutschland TP400 programme director Dr Christian Poensgen. It is expected that the first flight of the A400M, due in October 2007, will be performed with only one of the two engine/gearbox-propeller configurations certificated.
Karlsands wrote:P factor
Gruß, masi1157
longhauler wrote:Karlsands wrote:P factor
I guess no one read this.
It is the main reason for counter rotating props on twin engine propeller aircraft. Basically, what it means is that the down going blade is producing more thrust than the up going blade at any angle of attach higher than zero.
Counter rotating props, clockwise on the left engine, counter-clockwise on the right engine (when viewed from behind) will have the highest thrust closer to the centerline of the aircraft. In a single engine situation, the amount of rudder is the same regardless of the engine lost. Aircraft without counter rotating props (both clockwise when viewed from behind) will require more rudder with the loss of the left engine than the right. (Termed the "critical engine"). And performance will always be predicated on the loss of the ciritical engine.
As noted above, some new and advanced aircraft, like the Q400, (for example) do not do this. There are many reasons ... things like commonality of engines/props for left/right or that there is so much excess power, counter rotating props are not necessary.
vikkyvik wrote:Why do they have to be on the same axis? Props on different axes are still imparting torque to the aircraft.
DFW17L wrote:kczombie wrote:BTW, I just love the A400. Just a sweet thing to look at.
Yes, the A400 is a sweet bird. I bet the Italians had something to do with it. They have such a great sense of style.
