planecane
Physial design of control of 737 jackscrew
Sat Jun 08, 2019 1:55 pm
While researching documents and watching videos about runaway stabilizer on the 737, I came across the information that the manual wheel has the highest priority and will override any electric trim (automatic or manual). I even saw a video of a pilot in a real 737NG cockpit hold the thumb switch and grab the trim wheel and the trim stopped moving.
I am curious how this is actually implemented in the design of the motor and cable interface with the jack screw. I don't think they can be connected in parallel with each other because I can't imagine a human grip is strong enough to stop an electric motor which is powerful enough to easily move the stabilizer under flight loads. Does anybody have a picture or diagram showing the actual interface of the cable from the manual wheel and the electric motor with the jackscrew?
Please do not turn this into a discussion of MCAS or runaway trim.
Lpbri
Re: Physial design of control of 737 jackscrew
Sat Jun 08, 2019 2:46 pm
I have a good schematic but I don't know how to post it
planecane
Sat Jun 08, 2019 3:51 pm
maybe a moderator can help you. It would be very interesting (to me, at least) to see it.
Sat Jun 08, 2019 11:02 pm
If it is an image file, you can upload it to a free service like Imgur and then embed it here using the "insert image" button. If it is a PDF you can put it on DropBox or the like and link to it.
Balerit
Mon Jun 10, 2019 7:40 pm
Licensed Aircraft Maintenance Engineer (retired).
GalaxyFlyer
Mon Jun 10, 2019 8:18 pm
Is it really a single drive motor assembly with a single channel electrical actuator path?
fr8mech
Mon Jun 10, 2019 10:15 pm
I can’t imagine it’s much different than a B727. The motor had a clutch that engaged when the trim was engaged electrically. When electrically inactive, the clutch was ‘off’ and the manual trim wheel could be used. I can’t recall how manually trimming, using the wheel, disengaged the electric clutch.
GalaxyFlyer
Mon Jun 10, 2019 10:54 pm
In 1979, the Challenger has dual channels controlling two motors, it seems more primitive than I imagined.
GF
CALTECH
Tue Jun 11, 2019 12:15 am
Moving the column in the opposite direction of Stab Trim stops the motion, then the Stab Trim cutout switches kill Stab Trim. If the manual wheels are moving in main trim, they'll break your wrists. Nothing to really grab on to, as the handles are usually stowed. Autopilot Stab Trim, is a slower rate, one might be able to grab the wheel but stab trim should be stopped electrically, then pop the handles out and adjust stab trim manually.
The gun is a precious Symbol of Freedom
Criminals are the deadly cancer on American society
Those who believe otherwise are consumed by an ideology
That is impervious to evidence of tyrants who disarm their citizens
planecane
Tue Jun 11, 2019 2:06 am
CALTECH wrote:
I will try to find the video but a pilot in a real cockpit of a 737 (not a simulator) held down the thumb switch with his left hand and grabbed the wheel between his thumb and fingers of his right hand and the wheel stopped. As soon as he let go it started spinning again. There is some mechanism that allows the manual wheel to override the electric motor. I can't remember which manual but I read in a Boeing published manual that the trim wheel overrides all other trim.
milhaus
Tue Jun 11, 2019 7:44 pm
I tried it some time ago. I had extended trim wheel handle, held it and then momentarily applied trim command. It is possible to hold it but force is very high and I think it is possible to catch it and hold when it turns.
strfyr51
Tue Jun 11, 2019 7:51 pm
planecane wrote:
that's also a physical maintenance ground test when ops checking Stab trim. you have to know it can be overridden
planecane
Tue Jun 11, 2019 8:19 pm
Here is the video. I want to find out what in the design makes this possible.
https://youtu.be/cQirIH_DuAs
7BOEING7
Tue Jun 11, 2019 9:39 pm
Just to be clear, there is a technique for grabbing and stopping the trim wheel if you have a runaway and the previous checklist items don’t stop it. The last thing you want to do is try and grab the wheel with the handles extended — you will suffer extreme pain.
strfyr51
Wed Jun 12, 2019 4:25 am
The Jackscrew motor has a Main and Standby Motor. the standby is considerably slower than the main. If either fails It will Cancel the flight.
milhaus
Wed Jun 12, 2019 3:01 pm
I am just engineer not pilot . I just wanted to feel power of the system..
jakubz
Wed Jun 12, 2019 4:53 pm
Mods, is it possible/warranted to correct the title to "Physical"? I'm pretty sure that is what OP meant.
Either way, feel free to delete this comment after you consider the change.
KORD>RJAA>KORD day trip? Why not! The beauty of non-reving.
Yes, I use ICAO codes
Flown: PA-28, PA-38
Passenger on: A319/A320 737, 747-400, 757, 767, 777, 787-8/9
Finally got on a 747!
I work for United Airlines, but I don't speak for the company.
Users browsing this forum: No registered users and 21 guests
