Justbored201
Apu overheat protective shutdown in flight
Mon Jul 01, 2019 5:37 pm
Any idea why Boeing 737 apu Honeywell 131-9 experienced auto shutdown due to overheat in cruise fl 350, no moisture upon landing started normally
Horstroad
Re: Apu overheat protective shutdown in flight
Mon Jul 01, 2019 6:39 pm
You should ask the FIM, not an online forum :D
An APU shuts down due to overheat, when the EGT reaches its limits. Maybe it's a faulty EGT thermocouple or a fault in the wiring.
unimproved
Mon Jul 01, 2019 7:10 pm
Too much power asked for the FL? IIRC the max altitude for packs is around 15,000ft and elec at 37,000.
Redbellyguppy
Mon Jul 08, 2019 2:11 pm
Why were you running it at 350? Overwater? And more importantly, why did you attempt a restart on the ground?
Mon Jul 08, 2019 6:28 pm
Check your APU module BITE, you will get the reason for the shutdown & suspect component.
Since it started normally on landing, it could have been a signal error too.
Best is to troubleshoot it.
Users browsing this forum: edu2703 and 12 guests
