x1234
How come DL185 (ATL-PVG) is not a polar route today but DL583 (DTW-PVG) is!?
Fri Jul 12, 2019 2:13 am
How come DL185 (ATL-PVG) is not a polar route today but DL583 (DTW-PVG) is!? I find it weird that DL185 has a very long flying time versus DL583 as its not polar. They can probably cut 1 hour off the flying time by flying polar off a flight that is already very long.
glideslope900
Re: How come DL185 (ATL-PVG) is not a polar route today but DL583 (DTW-PVG) is!?
Fri Jul 12, 2019 2:20 am
Atlanta is much hotter than Detroit. The aircraft could experience sudden temperature changes going from the very warm southern US (ATL) into a freezing polar environment. These sudden temp fluctuations could possibly compromise aircraft structure.
Cubsrule
Fri Jul 12, 2019 2:28 am
185 is on a route that doesn't require ETOPS. That may not be a coincidence.
stl07
Fri Jul 12, 2019 2:41 am
Have you ever flown into Los Angles in the winter? You pass over ski resorts and snowcapped mountains right before touching down in 80 degree LA weather.
Instead of typing in "mods", consider using the report function.
Love how every "travel blogger" says they will never fly AA/Ethihad again and then says it again and again on subsequent flights.
sadiqutp
Fri Jul 12, 2019 2:55 am
There are a lot of variables that are taken into account while choosing the optimum route. From wind currents, to navigation costs, to authority approvals. Any variable could make what seems to be two similar routes be optimum to one and not the other!
WHAT NOW?
Fuling
Fri Jul 12, 2019 3:01 am
Really? Has the ME3 caught on yet? If they depart at 45°C (summer) and reach cruise at -40°C, that surely is a worry right?
ScottKBUF
Fri Jul 12, 2019 3:04 am
It doesn't matter where you are on the globe, it's still pretty cold at 35,000ft. From take-off to top of climb its not uncommon to see a outside air temp change of 50-60 degrees C in that 15-20 minute period. Any pressurized aircraft is designed to deal with these extreme fluctuations in temperature.
Buffalo, NY
DylanHarvey
Fri Jul 12, 2019 3:12 am
Someone tell EK, EY, and QR.
DLASFlyer
Fri Jul 12, 2019 3:15 am
I'm sorry but this is right up there with reading that Delta is retiring the MD-90 and replacing it with the A220 due to crew familiarity with a 3-2 configuration. Which was also posted today on these lovely a.net forums.
Lrockeagle
Fri Jul 12, 2019 3:33 am
Yeah that’s why US1549 started sinking so quickly in the Hudson. Water was so cold it compromised the aluminum and it cracked
Lrockeagle
15 years ago
I got $20 says AA takes their 787's with GE powerplants. Just a hunch. Any takers?
strfyr51
Fri Jul 12, 2019 3:37 am
x1234 wrote:
How come DL185 (ATL-PVG) is not a polar route today but DL583 (DTW-PVG) is!? I find it y NOTweird that DL185 has a very long flying time versus DL583 as its not polar. They can probably cut 1 hour off the flying time by flying polar off a flight that is already very long.
Do you know what the winds aloft actually were and whether they would have made any Money going that way? It's probably NOT a cut and dried answer..
socalflyer00
Fri Jul 12, 2019 3:56 am
It seems that before 07/02, DL 185 was taking the polar route quite frequently. Over the last week however there have been primarily non-polar routings including one diversion to SEA on 07/08. Perhaps one of the frames they are using on this route can not operate ETOPS at the moment for any number of reasons. But it does seem that DL 185 *usually* is a polar routing like DL 583.
Even so, the polar route only saved about 38-40 mins
Pavlakakos
Fri Jul 12, 2019 4:11 am
Best comment ever. :D
Although i'm pretty sure it's kinda cold over ATL once you reach FL200 and above. :airplane:
Caryjack
Fri Jul 12, 2019 4:19 am
ATL is south of DTW so an aircraft must fly through the wider southern longitudes to reach the same point as an aircraft from the north.
http://www.gcmap.com/mapui?P=pvg-atl%0D ... 85&SU=mach
Just curious, what do you consider to be a polar route?
Cary
32andBelow
Fri Jul 12, 2019 5:17 am
Is this a joke
Max Q
Fri Jul 12, 2019 5:48 am
Oops,
Another reason to take the train
GGg
hongkongflyer
Fri Jul 12, 2019 7:35 am
Never heard about it. There are plenty of planes using polar route from hot cities. The planes are gradually cooled down before they reaching polar area.
glideslope900
Fri Jul 12, 2019 12:56 pm
I’m joking guys, relax.
SteelChair
Fri Jul 12, 2019 1:27 pm
Are you sure about that? I knew 60 minute routes were possible in the Atlantic but thought they were virtually impossible in tbe Pacific.
Cubsrule
Fri Jul 12, 2019 1:30 pm
I don't know for sure that everything in Alaska is open and available, but if so, take a look at a route like JNU-NRT, which is close to what this Delta flight flew TPAC and stays within 60 minutes with minimal deviation from the great circle route.
N766UA
Fri Jul 12, 2019 3:29 pm
LOL everyone thinks you’re serious. What a bunch of dorks.
747megatop
Fri Jul 12, 2019 3:43 pm
Does anyone know the reason for diversion to SEA? https://flightaware.com/live/flight/DAL ... /KATL/KSEA
747megatop
Fri Jul 12, 2019 3:45 pm
That explains the reason for all the creaks and groans when the aircraft flies from a warm southern US cities and crosses the poles!
a320fan
Fri Jul 12, 2019 3:48 pm
This has to be one of the strangest things I’ve read on this site in the last 15 years. Someone should warn EK about the dangers of their polar flights departing DXB.
A319, A320, A321, A330-200, A350-900, A380, 737-700, 737-800, 777-200ER, 777-300, 777-300ER, 787-8, Q300, Q400
RetiredNWA
Fri Jul 12, 2019 3:56 pm
It appears you are completely unfamiliar with the temperature lapse rate...
Is this website even worth reading anymore?
digitalcloud
Fri Jul 12, 2019 4:19 pm
I love this forum.
AirFiero
Fri Jul 12, 2019 4:26 pm
I am actually very thankful to find out that you were not that dumb. I might suggest though that you put a wink :-) after such a post?
D L X
Fri Jul 12, 2019 4:28 pm
28 posts on this thread so far, and 22 of them are about this comment.
:rotfl:
pnutt
Fri Jul 12, 2019 4:39 pm
Quick comparison: DL185 ATL-PVG took 16h16 (including a circle before landing) and DL583 DTW-PVG took 14h21. If DL185 had first flown to Detroit (say in around 1h30) and then followed the DL583 route, it would have ended up taking around the same time. Plus, if you check out some ATL-DTW routes from yesterday, there are some substantial (weather-related?) detours, which might be a factor too.
jscottwomack
Fri Jul 12, 2019 4:44 pm
:rotfl:
We need someone stick their arm out at 38,000 ft over Atlanta with a thermometer and another over Detroit and get us some readings......
TWA, Ozark, Braniff, Piedmont, USAir, American, Delta, Frontier, Midwest Express, Western, Eastern, Southwest, Northwest, PanAm, United, Mississippi Valley, Britt, Continental, Trans America, Midway, America West, National, American Trans Air, Sun Country
SoCalFlyer
Fri Jul 12, 2019 4:58 pm
Say what now....where the heck did you pull this one from
PhilMcCrackin
Fri Jul 12, 2019 6:06 pm
Lol, what? It's well below freezing at cruising altitudes even over the hottest places on Earth. That would have nothing to do with it.
stl07
Fri Jul 12, 2019 6:16 pm
I love how even after the poster said it was a joke, people continue to make comments about it or the site quality going down.
Eyad89
Fri Jul 12, 2019 6:18 pm
Let’s keep them coming.
birdbrainz
Fri Jul 12, 2019 6:20 pm
Possibly to avoid Russian airspace for some bizarre reason?
ETOPS is also a possible reason, but it's a 777-200LR. Seems odd.
The winds aloft must not be that strong now.
A good landing is one you can walk away from. A great landing is if the aircraft can be flown again.
MSJYOP28Apilot
Fri Jul 12, 2019 6:47 pm
Russian airspace is extremely expensive. If the difference in time and burn is not going to make the flight late or over max takeoff weight, a non polar route like R220 keeps the flight in US and Japan airspace which is much cheaper on the overflight fees. Almost every airline does this especially if the cargo/passenger load is light enough to allow the extra fuel for the longer route, if it is longer than polar.
Depending on the winds, this could indeed be the best wind route for today.
While Non-ETOPS is possible for Asia and Pacific flights from North America, approval for that is on a carrier by carrier basis. I do not know if Delta has authorization for that.
PBADC3
Fri Jul 12, 2019 7:04 pm
I presume that you are looking at DL185/11 and DL583/11?
If so, then look at flight information for both flights on delta.com and you'll have your very straightforward answer.
DL583 departed DTW just over 3 hours late while DL185 is on time. Polar would likely be selected for the enroute time savings vs. non polar for 185. Slots in PVG are tightly controlled as is traffic flow via the LAMEN corridor, so showing up an hour+ early to enter the LAMEN corridor would not be favorably handled by Chinese ATC. Too early.
ukoverlander
Fri Jul 12, 2019 8:02 pm
Wow, just..............................wow.
ukoverlander
Fri Jul 12, 2019 8:22 pm
They should just bus the Atlanta passengers to Detroit and have them fly from there........ problem solved. :duck: :duck: :duck: :duck:
clrd4t8koff
Fri Jul 12, 2019 8:36 pm
So DL only take routes that save time when they're running late?! Why would DL willingly choose to take a longer route, which uses more fuel and would cost more unless there was some sort of international conflict that prohibited it?
I've had many flights into PVG from both JFK and SIN that arrived an hour early and there's never been an issue.
AF773
Fri Jul 12, 2019 9:55 pm
Have you not noticed that all aircrafts landing at LAX in the winter are crooked?
Next flights: SAN-LAX-MEX; SAN-ATL-PNS; SNA-ATL-CDG-SEA-SNA; LAX-CDG; ORY-FEZ; NCE-AMS-TPE-MNL-TAG
stl07
Fri Jul 12, 2019 10:56 pm
Hmmm that explains it
BC77008
Fri Jul 12, 2019 11:25 pm
The reason for no polar-route out of Atlanta is that Delta does not want their more prestigious Atlanta-based customer to look out the window in-flight and see firsthand the devastating effects air travel has had on the climate.
MY favorite airline and hub is bigger and/or better than YOUR favorite airline and hub!
MIflyer12
Fri Jul 12, 2019 11:37 pm
What's Russia's fee for an overflight like ATL-PVG?
CriticalPoint
Sat Jul 13, 2019 1:36 am
Holy crap! That’s some mighty fine BS right there! 10pts!
GalaxyFlyer
Sat Jul 13, 2019 3:06 am
I don’t see the bills, but expensive enough the handlers run the comparison in a bizjet and it frequently is cheaper to add 20-30 minutes to avoid the overflight. Unless, of course, doing so then causes a tech stop.
GF
LAX772LR
Sat Jul 13, 2019 4:08 am
Yeahhhh, let's not.
rbavfan
Sat Jul 13, 2019 4:48 am
Winds usually weaker in the summer months
MSJYOP28Apilot
Sat Jul 13, 2019 7:40 am
The busiest airports around the world are starting to crack down on early arrivals. While in most cases the flight will be allowed to land, the airline will be threatened with fines and loss of slots if they continue to arrive too early.
Late flights also get scrutiny but as long as the delays are not chronic, it is looked at a little differently than an early arrival. Every airline deals with weather and maintenance issues to some degree. Arriving early is more controllable because the airline can plan a longer route, delay the departure, extend the taxi time, or fly slower mach speeds to prevent the early arrival.
The metric most airports wants to see is an arrival +/- 15 minutes of the scheduled slot time.
I haven't yet heard of any actual fines or lost slots due to early arrivals even though there have been threats made to do so.
PBADC3
Mon Jul 15, 2019 1:04 pm
"The busiest airports around the world are starting to crack down on early arrivals. While in most cases the flight will be allowed to land, the airline will be threatened with fines and loss of slots if they continue to arrive too early. "
This is correct, and the most commonly exhibited of this issue is LHR where an early entry in to U.K. airspace will often get you several holding turns to burn time off and get you closer to your slot time.
Users browsing this forum: No registered users and 28 guests
