frederickpkc
Usage ratio of MIL-PRF-23827 to MIL-PRF-81322 grease on A320
Fri Jul 19, 2019 7:04 am
Hi Experts,
I am doing research on aviation grease and would like to know the usage ratio of MIL-PRF-23827 to MIL-PRF-81322 on narrow body a/c like A320. Understand usage varies to a/c model, just wanna know a rough figure of ratio.
Jouhou
Re: Usage ratio of MIL-PRF-23827 to MIL-PRF-81322 grease on A320
Fri Jul 19, 2019 9:45 am
frederickpkc wrote:
Hi Experts,
Do Airbus aircraft actually use US mil spec grease?
fr8mech
Fri Jul 19, 2019 9:57 am
Yes, Airbus does use MIL Spec.
unimproved
Fri Jul 19, 2019 11:31 am
Can't speak for the A320 but on the 747 it's #33 unless specified otherwise. I'd say about 90%.
Lpbri
Fri Jul 19, 2019 2:44 pm
The most common grease I know of is Mobil 28, it's red, and AeroShell 33, and its olive in color. Royco something is used for areas around carbon brakes. It's black. Airbus may use something different.
strfyr51
Sun Jul 21, 2019 7:48 am
Jouhou wrote:
frederickpkc wrote:
Hi Experts,
Yes they do! Airbus uses Milspec Grease as it meets their material requirements. Just like the engines use Milspec oil and Hydraulic fluids.. Why would they Not?
Jouhou
Sun Jul 21, 2019 8:18 am
strfyr51 wrote:
Jouhou wrote:
frederickpkc wrote:
Hi Experts,
Because I work in defense and the mil specs our greases and lubricants conform to make them extremely expensive...
Dalmd88
Sun Jul 21, 2019 1:34 pm
Every manufacturer that I've ever worked on specs the grease as Mil spec. It is the best way to control the quality and all the petroleum companies make their aviation grease to mil spec standards.
As for which is most popular, At Delta for most fleet types if I recall, I haven't greased a plane in years. All landing gear components were Royco 11, black grease. Most everything else was Aeroshell 33, the green grease. Some actuators called for Mobil 28, red grease and a few spots used Aeroshell 7, light tan grease. Now the MD88/90 were pretty much Mobil 28 for most of the airframe and Royco 11 for gear.
acmx
Sun Jul 21, 2019 8:31 pm
According to aeroshell: “Of 359 grease application points on a Boeing 737 - AeroShell Grease 33 lubricates all but 9 of them”. BMS 3-33 meets MIL-PRF-23827C specification. On Boeing’s, it’s definitely the most common grease I’ve seen. Pretty much used all over except a few landing gear fittings.
