AirbusCanada
Was it possible to build the MAX on 757 Platform instead of 737
Tue Jul 30, 2019 5:05 pm
Since the root cause of most the 737Max related problems originate from trying to fit bigger diameter engines under low wings, I was wondering would it be easier for Boeing (from a technical perspective) to base the MAX on a 757 platform instead of 737.
Shortened fuselage, both CFM & GTF Engine option, new composite wing, fly-by-wire controls, and updated avionics.
Skip the smallest (7/700) variant, offer three models with capacity ranging from 180 to 230. The larger variant should be able to compete with A321very effectively.
Would it be still faster and cheaper to develop than a clean sheet design?
tootallsd
Re: Was it possible to build the MAX on 757 Platform instead of 737
Tue Jul 30, 2019 5:13 pm
The existing design materials are not digital (according to my understanding) so any rework is going to be complicated.
Tooling does not exist, so you need to create the supply chain, the jigs, everything. And in terms of advanced manufacturing methods -- you have to adapt the design to use those methodologies.
Sounds like as close to a clean sheet as you can get.
WN732
Tue Jul 30, 2019 5:15 pm
Even if Boeing wanted to, there would be no way to bring any version of the 757 back. The tooling is gone. Boeing envisioned the 7E7 at the time would fill that gap and also fill up to the 764's gap. When the 787 was introduced, they were to build the 787-3 to replace the 757. This never happened and it was too late to go back to the 757 for a re-engine. The end.
Revelation
Tue Jul 30, 2019 5:16 pm
Anything is possible if you throw enough money at it.
The real question is if this would have produced a viable product, and the answer is no.
The 757 fell out of favor because it was a strongly built thus heavy airframe that had been stretched as far as it could be stretched.
Better engines would mean you burn less fuel so most of the time you fly around big, heavy and empty wing tanks.
Its supply chain has pretty much all moved on to doing other things, so you'd have to restart all of that from scratch.
So, it's a non-starter.
stxbohn
Tue Jul 30, 2019 5:18 pm
I guess the 737 was digitized at some point? Between 737 classic and 737 NG?
many321
Tue Jul 30, 2019 5:19 pm
I've always had this question linger in my mind. Boeing should have gone in this route, perhaps saved themselves the trouble they're going through at the moment.
AirbusCanada
Tue Jul 30, 2019 5:40 pm
Isn't tooling a less of a problem than unstable aerodynamics, that needs to be dealth with an under the table software fix.
Zidane
Tue Jul 30, 2019 5:49 pm
While I like the sound of a B757-7/-8/-9 family concept, Boeing might as well build a new clean sheet.
hOMSaR
Tue Jul 30, 2019 6:38 pm
Exactly. I still don't quite get the 757 fetish on here. The plane, over the course of its entire history, delivered an average of 3.6 planes per month.
It was good at what it did when it was new. Then lighter planes (including the 737) took over that role as they got more capable. If Boeing had kept the 757 in production for the past 14 years, it would have had its tailcone handed to it in the marketplace vs. the A320 series, and meanwhile the 737NG (which moved into the 757's production space) would have had a much smaller production run on account of lack of facilities. Ignoring the whole "tooling" discussion, a 757 MAX would still be too heavy, and so it would still be soundly defeated in the marketplace by the A320neo. Plus, it wouldn't be able to use the neo engine, because those are 10,000 pounds too weak in the thrust range, so you'd need a brand new engine in the 40,000 pound thrust category (of which there really isn't one at the moment) which would then increase the cost of development even further. So, you'd have a too-heavy airplane with a more powerful (and thirstier) engine competing against lighter and far more efficient airframe/engine combos, costing a lot more per frame. Any one of those factors is likely to hamstring you in the marketplace. All of them put together, and there's absolutely no way an airline would want it.
A hypothetical "757MAX" to compete in the A320/737-800 market makes about as much economical sense as a 737-600 or A318.
The plural of Airbus is Airbuses. Airbii is not a word.
There is no 787-800, nor 787-900 or 747-800. It's 787-8, 787-9, and 747-8.
A321neoLR is also unnecessary. It's simply A321LR.
Airplanes don't have isles, they have aisles.
BlueberryWheats
Tue Jul 30, 2019 6:47 pm
Why though? The point was to try and keep a common type rating with the existing 737. So a 757MAX would be rather pointless, may as well do a clean sheet.
This guy gets it.
strfyr51
Tue Jul 30, 2019 6:49 pm
what are you talking about? The 757 even today performs as good as the A321 which is just a cheap copy of the B757. If Boeing right today announced an updated digital 0version of the B757 the A321 sales would plummet!
longhauler
Tue Jul 30, 2019 7:15 pm
Yes a 757 performs as well as an A321. But, so does a 707 or a DC-8. Wanna resurrect those too?
Boeing stopped building the 757 because no one wanted them any more. And why would they? It was designed in the 1970s on a 1960s wing airfoil design. Engines were too powerful because that was all that was available at the time. The fuselage/wing combination is very heavy ... not to be "strong" like people think, but because that was the only technology available at the time and all that Boeing knew how to do.
Sure, the A321 is a cheap copy of the 757. That's actually quite funny. Boeing sold just over 1000 757s So far A321 orders/deliveries sits at around 4500. It looks to me like Airbus showed Boeing what the 757 should have been or could have been.
A "digital" version of the 757 won't solve the whole weight issue. With its 1970s design, the 757 is just too heavy. Bring it back and the world would laugh.
But .... redesign the wing, the fuselage, update the cockpit, find the right sized engines and you'd have a winner, In other words, start from scratch and that is exactly what Boeing is doing! I think though, they may be too late. While everyone in Seattle sits on their thumbs figuring out what to do with the 797, Airbus is cleaning up with the A321.
mopacair
Tue Jul 30, 2019 7:37 pm
A scaled-down 757 would still be inefficient as a replacement for the 737NG due to its weight and wing design. I’m sure Boeing considered the idea but found that a clean sheet design would be the end-result. Since they were in a rush to have a replacement to compete with the Neo-series, a stretch of the 737 was the easy choice. In hindsight they probably should have gone with a clean sheet design, but that’s not apparently what the analytics (or bean-counters) told them.
As a fan of the 757, I must admit that it was an excellent aircraft when it was developed but by the 2000s, it was an outdated design. What’s crazy is that despite its inefficiencies the 757 is still a very capable aircraft that really has no equal (739/321 are close but not equal). The A321XLR would seem to be the closest in comparison, but it has yet to fly and AFAIK won’t have the cargo capability of the 757. That said, market forces gave their opinion of the 757 years ago when Boeing delivered its last order for the type.
N649DL
Tue Jul 30, 2019 7:45 pm
I'm not really understanding this whole "digital conversion" thing, what exactly does this entail? And Boeing still makes the 767, how did this get converted when the aircraft was launched in 1981?
Boeing shut down the 757 assembly line in 2005. So while very difficult to replicate a design that hasn't been manufactured in almost 15 years, I'm sure there are design components they can take from it if need be.
MartijnNL
Tue Jul 30, 2019 8:09 pm
If Boeing really wanted they could build the 757 again. It doesn't matter that the tooling is gone. They could easily make new tooling.
Revelation
Tue Jul 30, 2019 9:12 pm
757 was designed before computer aided design was rampant.
The designs for it largely live on paper or mylar and not as digital files.
It also was designed before fly-by-wire.
It has a digital cockpit to deal with many aspects of flying the airplane, but you still have cables and pulleys running to the rudder, etc.
Right, and as above they could do so for 727, 707, DC8, etc but it doesn't make sense to do so.
The tooling would be all-new from the FAA's point of view so there is the added expense of getting a new production certification to deal with.
GalaxyFlyer
Tue Jul 30, 2019 9:25 pm
Which is a wonderful answer to the question of “no much has changed in airliner design”. When EAL launched the program with BA, the premise was high oil prices as far as the eye could see and its fuel efficiency was worth the expense. It turned out in the 80s, fuel was cheap and money was expensive. I got in the jumpseat to fly an EA 757 BOS-MCI. The fuel load 27,000 which I, as 727 pilot, couldn’t believe was enough to get there. We had plenty. Captain said, “727 load plus a few with DC-9 fuel burn.” Now, it’s an overweight fuel hog.
GF
September11
Wed Jul 31, 2019 12:06 am
I’m still curious about 757-100
Airliners.net of the Future
N649DL
Wed Jul 31, 2019 12:09 am
Nice, got it. Thanks for that. If that's the case then what's the deal with the 767-300ER? Same systems as the 752 but Boeing can still make the plane right?
Revelation
Wed Jul 31, 2019 1:05 am
I'd say they are similar in terms of design and construction.
They differ in that the last 757 was built ~15 years ago. The supply chain is closed, The production certifications have lapsed.
The 767 supply chain is not closed, The production certifications have not lapsed. Money was put in to the plane and it's production line for the KC46 contract. The tanker contract is expected to go for 179 frames. FX and UPS have large orders and keep making incremental purchases as they are finding it is a good match for their needs.
I would not be surprised if the KC46 work drove Boeing to create digital representations of large parts of the 767. It's hard to imagine them making such major changes while conforming to 1970s design methods. Clearly there is no need to do that for 757 since it's been out of production for ~15 years now.
https://en.wikipedia.org/wiki/Boeing_76 ... deliveries suggests they have 99 more 767 orders than deliveries. Boeing is actually increasing the production rate to 3/month in 2020 ( ref: https://www.boeing.com/company/about-bc ... 25-18.page ).
DL717
Wed Jul 31, 2019 3:13 am
There is yet to be a 200 seat narrowbody that matches the performance characteristics of a 757. Heavy yes, but jumped off a runway like no other. 737-9s are runway pigs and the A321 isn’t much better no matter what people think about it. If the tooling was there, a new wing, new engines, new flight deck and maybe some lighter aluminum skin and additional composites spread around might have been enough.
Welcome to Nothingburgers. May I take your order?
Wed Jul 31, 2019 5:16 am
I doubt it. The 321 would likely beat a revamped 757 on fuel burn per seat. The clincher is that all those 320/321 customers save a lot of money with commonality.
Jumping off the runway is all well and good, but all the aircraft needs to do is meet the regulatory requirements.
aeropix
Wed Jul 31, 2019 6:52 am
ABSOLUTELY YES! I have been saying for decades that one of the biggest mistakes Boeing ever made was to withhold the 757-100. If you study the history of the industry in the mid-1980's there was a huge demand for a 2-class 150 seat airplane, it was a huge hole in the market that was filled up by the A320 in 1987.
Boeing should have rolled out the 757-100 to compete in this segment, ditching the heavy dual-tandem gear for a 737 style single axle main gear. History would have worked out entirely differently, perhaps the A320 would have even been a flop given that the 757-100 had at least a 5 year head start in the market segment.
It was the pressure from Eastern and British for the larger -200 variant that eventually led to the "overbuilt" design that further led Boeing to put out the grossly underperforming 737-400 to compete in that 150 seat space rather than the 20-years newer technology of the 757-100. Airbus made huge inroads into the 150 seat space with the modern A320, the 737 program of that time didn't stand a chance against this clean sheet airbus design. The 757-100 based on a much more modern platform would have cornered the naroowbody market for decades to come, and the large new 737's would not exist, instead this segment would be filled by modernizations of the 757 platform, with the smaller landing gear.
Wed Jul 31, 2019 7:13 am
Since the 757 did not survive, it was never modernised, unlike the 32x. Would modernising the platform really be better than a clean sheet? I seriously doubt it. I don't even know if it would be cheaper.
Just the cost of digitising the plans would be massive. The design would also have to be converted to FBW, because nothing else makes sense since the early 90s.
Boeing has the know-how to produce a class-leading clean-sheet design. There's no need to rehash the past. Would such a design look a bit like a 757? Sure. But that's not the same as re-using the 757 platform.
RalXWB
Wed Jul 31, 2019 7:58 am
You win the Internet today!
WesternDC6B
Wed Jul 31, 2019 9:19 am
I am far from being an aviation engineer, so this question: would a 787-3 be feasible at this point? Or - for the capacity and range - are there better aircraft being offered? Thank you.
Remember: Only one dwarf in seven is Happy.
DL717
Wed Jul 31, 2019 1:01 pm
Except when you need short field performance.
VSMUT
Wed Jul 31, 2019 1:10 pm
The 757-100 would have been doomed from day 1. It is just way too big, in negative ways at that. It uses engines that are closer to the 767s than the A320s, which means much greater fuel burn. Same goes for the wings, 185 sq. meters vs 124. The 757s wing is as big as an A320s and an ATRs combined. That's just dead weight. The landing gear, empennage and so on are the same. The fuselage has similar dimensions to the A32X series, but that's about as far as similarities go. A 757-100 would be overbuilt and heavy, with just about the worst CASM you could imagine.
longhauler
Wed Jul 31, 2019 2:05 pm
While the A321 can be a dog at higher altitudes, it is no slouch off the runway. Normally it has better field performance than the A320.
Max thrust, Config 3 on the advanced wing and it's a real kick in the pants!
That big thick Boeing wing on the 757 will always do better though, but .... dragging all that unnecessary wing around at cruise is very expensive. Its not just the weight that is against it.
DL717
Wed Jul 31, 2019 3:19 pm
It's a slouch bro. 75 kills it every time. Fat or not. Now imagine a 75 with all that fat taken out of it. That would be a kick in the pants.
Then again, they'd probably value engineer out the thrust and turn it into a turd these days because 90% of airports don't have any runway length issues. Cube dwellers don't think much about that 10% like they used to, so we get performance turds.
The closest a recent aircraft has come to a 757 in terms of airfield performance was the 787-3. It was 6,400-feet of runway sea level/hot day at MTOW (7,200' at altitude). Man that would have been a ride.
BravoOne
Wed Jul 31, 2019 3:21 pm
Had this done for some unthinkable reason it would have required a new type rating for most of the existing 737 customer base, and other than the direct operations cost advantages the MAX was supposed to bring with it, there would little incentive for the likes of SWA and other existing customers to line up for this. I'm confident that if there a a moments thought regarding this concept, it was rejected in a nano second.
DL717
Wed Jul 31, 2019 3:25 pm
It wouldn't have been targeted at Southwest. It would have been targeted at 757/767 operators. The 737 should have simply been replaced.
BravoOne
Wed Jul 31, 2019 3:59 pm
Well while don't disagree that the 737 needs a definitive replacement the SWA involvement with the MAX cannot be overlooked. BTW, if there is an airplane that needs to see the bone yard its the 717's at DL.
Redsand187
Wed Jul 31, 2019 4:54 pm
The real question in my mind, which I'm sure has been answered somewhere before. Why couldn't they design taller telescoping landing gear?
In 50 years, I'm sure there has been enough improvement in technology and materials that they could figure out how to build landing gear that would fit in the original location but have additional stages of telescoping ability allowing the plane to sit a couple of feet higher. Thus, allowing larger engines to hang from the same height as the NG's and maintain balance closer to the original.
Wed Jul 31, 2019 6:00 pm
That's the thing though. "90% of airports don't have any runway length issues". So why design an aircraft for the 10%?
Such gear has existed for a long time. The A330 has gear that shortens on retraction and lengthens on extension.
DL717
Wed Jul 31, 2019 6:59 pm
Pfft.
Because that 10% exists, and its usually a constrained airport that needs capacity.
BlueberryWheats
Wed Jul 31, 2019 7:03 pm
Still only 10% though, probably easier just to add frequency with a slightly smaller aircraft with better runway performance.
N649DL
Wed Jul 31, 2019 7:26 pm
Interesting. Also, DL and UA have participated in life extension projects for their 763ERs as well. Some of UA's are 27 years old and have new Polaris interiors.
The 763ER is in a bit of renaissance mode right now but if the 757 was still around, it probably would as well. The 763ER didn't close for (as you said) cargo and military contracts which was never a thing with the 757 except 2nd hand.
Revelation
Wed Jul 31, 2019 8:22 pm
I think DHL bought some 757 P2F new from the factory.
It will be interesting to see how long FX/5X can keep their 757s going.
Seems the only viable alternatives will be to upgrade to 76F or downgrade to 737-8F conversions.
longhauler
Wed Jul 31, 2019 8:56 pm
I don't follow you. Are you saying a "constrained" airport has shorter runways?
I am a bit dubious even of 10%. I can only think of a couple of operations where runway length could be an issue (SNA or EYW come to mind). So I'd peg it more lilke 2% or 3%. Even still, take your 10%. That means 90% of the time, the A321 is far more efficient than a 757. That is huge, and likely why only about 1000 757s have been built and the A321 now more than 4500 built/ordered.
In my opinion, Boeing should have taken the 757 along the evolution of the 737.
The 737-100 to -500 had an amazing short field wing. During design in the 1960s, runway length was a big concern. But ... that came at a cost. Like the 757, pulling that thick wing through the air was expensive. Normal cruise was only about M 0.74. When Airbus introduced the A320, the similar sized 737-400 was at a disadvantage. Not only was it slower, but fuel burns were higher.
Enter the 737NG. A320 size, A320 speed and A320 economics. As we all know, the NG was a winner. Using that new slim wing, it cruised at M 0.80 and burned less fuel. Sure, you couldn't take off from a 4000' runway .... but 99% of the time, you didn't have to.
If Boeing has done the same thing with the 757 wing, it would have better competed against the A321. But I had always thought they saw larger versions of the 737 to be the answer. And it basically is.
VSMUT
Wed Jul 31, 2019 9:06 pm
Or, you know, one of the several A321P2F conversions under development...
Revelation
Wed Jul 31, 2019 9:20 pm
Do tell.
VSMUT
Wed Jul 31, 2019 9:48 pm
Do tell.
EFW, ATSG and C3 are all working on A320 and A321 conversions. ATSG has mentioned a rollout in the second half of 2019, EFW says the start of 2020 and C3 says summer 2020 for its first A320F and end of 2020 for their first A321F.
Hardly new information, has been discussed multiple times on this forum.
Revelation
Wed Jul 31, 2019 9:52 pm
Oh well, guess it slipped me mind.
Thanks for the update.
Nice to see these excellent aircraft go on to have second lives.
XAM2175
Thu Aug 01, 2019 1:23 am
DL717 wrote:
Cube dwellers don't think much about that 10% like they used to, so we get performance turds. The closest a recent aircraft has come to a 757 in terms of airfield performance was the 787-3. It was 6,400-feet of runway sea level/hot day at MTOW (7,200' at altitude). Man that would have been a ride.
The 787-3 was intended more as a 787SR - an evolution of the 767-300 primarily for the Japanese domestic market - than as a 757 replacement. It was dropped to prioritise delivery of the 788, and also because it was established that the operating economics would be trash - to the extent that the 788 was more efficient once stage length got past something like 400 nmi.
But hey, at least it wouldn't be a performance turd :roll:
DL717
Thu Aug 01, 2019 3:20 am
Orange County (gate cap), Midway (built out), La Guardia (slotted), Reagan (slotted), San Diego (slotted inside of 10), Burbank (gate cap). All constrained. All limited operational capacity airports with short runways or terrain impacted runways. The industry needs a 200 seat plane that serve these markets effectively with little or no weight/range penalty regardless of runway directional use.
Prime example. DL has no option to the 757 for SNA to ATL or DTW other than to down-gauge.
LH707330
Thu Aug 01, 2019 3:37 am
We keep arguing about whether B can sell enough 797s to make the case for spending $10B. If there were a case to be made for an A321 competitor with better field performance and a 5% CASM penalty, someone would have done it by now.
Regarding DL's options for SNA, they can either send a 319 or add a stop in SLC so they can make weight. Life will go on without the 757.
DL717
Thu Aug 01, 2019 3:41 am
So adding more flights in smaller aircraft would be possible without adding gates to retain market share is what you’re saying. And seriously a tech stop? Thanks for proving my point.
1989worstyear
Thu Aug 01, 2019 4:11 am
A Boeing engineer who worked on the wing of the -700 and -800 told me this was the case.
He also told me that there is really zero commonality component-wise between the NG and earlier series - the NG was essentially a clean-sheet.
Stuck at age 15 thanks to the certification date of the A320-200 and my parents' decision to postpone having a kid by 3 years. At least there's Dignitas...
Or just limit payload/fuel.
Users browsing this forum: No registered users and 31 guests
