Ethan22
Why does the horizontal stabilizer of a Dash 8 droop?
Sun Aug 04, 2019 8:09 pm
While looking at the Dash 8 family, I noticed that the -100 and -300 family of planes horizontal stabilizer attached to the tail always droops while on the ground, but not while airborne...…
I did not notice this on the Q400 family....
YYZatcboy
Re: Why does the horizontal stabilizer of a Dash 8 droop?
Sun Aug 04, 2019 8:35 pm
It probably uses control tabs, the same way an MD series aircraft could have flight controls pointing every which way due to wind. Once the airspeed builds the surface goes neutral and then the control tabs control it.
viewtopic.php?t=735557
see that thread for more about the system.
DH1/3/4 MD11/88 L1011 A319/20/21/30/50/80 717 727 735/6/7/8/9 744 762/3 77E/W E40/75/90 CRJ/700/705 CC150
J/S DH8D 736/7/8 763
CATIIIevery5yrs
Sun Aug 04, 2019 9:02 pm
Q400 has a hydraulic elevator and rudder. That’s why it doesn’t droop on the ground when the hydraulic systems are online.
Balerit
Mon Aug 05, 2019 2:25 pm
[quote="Ethan22"]While looking at the Dash 8 family, I noticed that the -100 and -300 family of planes horizontal stabilizer attached to the tail always droops while on the ground, but not while airborne...…
Thanks[/quote
Are you talking about the horizontal stabilizer itself or the elevators attached to the rear of the stabilizer? Usually the elevators sag after a while when there is no hydraulic pressure.
Licensed Aircraft Maintenance Engineer (retired).
Ethan22
Mon Aug 05, 2019 4:36 pm
thank you
dakota558
Tue Aug 06, 2019 6:41 pm
All the Dash 8s have a control lock that will hold the ailerons wings level and elevator nose down while engaged. The lock is usually always engaged while on ground.
Users browsing this forum: CosmicCruiser and 15 guests
