Armadillo1
anti-bird grading on engines
Fri Aug 16, 2019 4:49 pm
dont know how in english - lathing, lattice
i believe this topis already discussed, but of course now it will be raised again so will be nice to read previous discussions
flyingturtle
Re: anti-bird grading on engines
Fri Aug 16, 2019 8:13 pm
If the grilles work, a couple of birds will just clog the grille.
If the grilles don't work, the birds will just get diced by the grille, leading to a unpleasantly coughing engine.
Fighter jets that operate from un-improved air strips often have these grilles, but as a protection against rocks. The Su-27 and Mig-29 even have intakes at the top, for the same reason. See this discussion: viewtopic.php?t=1020459
Reading accident reports is what calms me down
Armadillo1
Fri Aug 16, 2019 8:20 pm
only older version of MiG-29 have top intakes. Not for flankers.
so engines need not a grill but grinder, and the fan already doing this?
flyingturtle
Fri Aug 16, 2019 8:51 pm
Somewhat.
And the fact that much of the air flow bypasses the engine core is also helpful.
Armadillo1
Sat Aug 17, 2019 12:23 am
for more fun
from here:
https://igor113.livejournal.com/51213.html
unfortunatly, no more info about test grill.
peterinlisbon
Sun Aug 18, 2019 1:14 pm
It would probably disturb the airflow and add to fuel consumption, which is why I imagine they don't do it.
fr8mech
Sun Aug 18, 2019 2:37 pm
A screen fine enough to adequately protect from birds, would most certainly require anti-ice protection.
I’ll add, that a bird-strike capable of damaging an engine, sufficient enough to shut it down, is not a single bird. It’s a flock of birds. That same strike on a screen would likely a) destroy the screen and drive the whole mess through the engine, or b) obstruct the airflow to the point of compressor stall(s).
RetiredWeasel
Sun Aug 18, 2019 3:06 pm
The A-37 'Dragonfly' had intake screens. However these were designed to prevent FOD to the extremely sensitive J-85s during taxing and takeoff roll. Once wheels were off the ground the screens folded under the intakes. Didn't help for bird strikes unless it was on takeoff.
Viper911
Sun Aug 18, 2019 3:17 pm
In the entire history of modern civil aviation we had what, just 2,3 cases of dual engine failure due to birds ingestion. Developing and certifying such a protection system, for an occurrence that happens once per X millions of flights is just not economical. It's far more practical to develop and implement Some "anti birds" procedures or a systems directly at airport grounds.
Viper911
TSS
Thu Aug 22, 2019 5:28 am
Armadillo1 wrote:
for more fun
from here:
It hadn't occurred to me before but I bet seabird ingestion was a continuous problem for those.
A while back, probably several years ago now, one of the major fighter jet manufacturers experimented with using lots of small holes on the leading edge of the wing instead of single large intakes for each engine. Apparently the benefits of such a design were nil if not negative, but it would have solved the bird ingestion issue.
Armadillo1
Thu Aug 22, 2019 7:04 am
looking at that dints on nacelles i bet it was a problem
afterburner
Thu Aug 22, 2019 7:49 am
It's "grating" not "grading", from the word "grate".
Users browsing this forum: a2b7, GalaxyFlyer and 12 guests
