Jeanguypatate
Special military activity routes
Tue Aug 27, 2019 3:21 am
Just curious about these routes. I am new to flying in the US and was wondering if there is anything special to do when crossing these routes? The one just south of Jacksonville named IR32 and IR33 specifically.
Thanks in advance for any info
PV
ATCJesus
Re: Special military activity routes
Tue Aug 27, 2019 3:44 am
Nope, there’s nothing to worry about. These routes are inactive 90% of the time, at least in my airspace. If you filed an IFR flight plan ATC will keep you separated. If you are flying VFR, they may advise you. If the IR routes go near an approach that you are flying, it may not be legally separated, so ATC will either hold you or most likely you can fly a different approach or just cancel IFR.
atcsundevil
Tue Aug 27, 2019 11:33 am
PV
Most of these IR routes are pretty rarely used, if at all. I have two in my airspace, and I've never seen them used ever. The VRs we have are used occasionally (maybe once or twice a day), but that's about it. If you're talking to ATC, they'll advise you if it's an issue. Otherwise, no worries!
ATCJesus wrote:
This is an outstanding username. That said, I can't believe it wasn't already taken :rotfl:
HAWKXP
Thu Aug 29, 2019 3:09 am
If you are 600-800 agl, look DOWN!
GalaxyFlyer
Thu Aug 29, 2019 3:06 pm
Tactics have changed to higher altitudes, so much less low level nav than 20 years ago.
Spacepope
Fri Aug 30, 2019 1:25 am
Aren’t there a bunch of dedicated tanker tracks over the US? I seem to recall a n/s track over western Kansas.
GalaxyFlyer
Fri Aug 30, 2019 2:13 am
Tanker tracks and anchors, yes. Fighter/Bomber tactics have come “off the deck” with precision munitions and better defensive weapons and tactics. Most bombing is done in the teens to low 20s.
There’s probably 30-40 tanker tracks and anchors. Tracks are straight line routes while anchors are large holding patterns about a fix. They are mostly at/above 17,000’ in Class A airspace, not a problem for GA flights like VR/IR routes. VR/IR routes were flown by F-111, B-52, fighters at 250-450 KIAS below 1,000’ AGL, significant collision hazard to GA, much reduced nowadays.
GF
BravoOne
Fri Aug 30, 2019 1:39 pm
GF
Not to mention large birds!
Users browsing this forum: planecane and 20 guests
